02-27-2020, 09:59 AM | #1 |
92
Rep 402
F10 M5
Thinking of purchases a 2014 m5 with 29k miles and stage 2 tune. Been hearing a lot about staying away from these cars when tuned because they blow up but was wondering if anyone could give me input. Car is equipped with CCB and is in very good condition and maintained very well. Any help would be greatly appreciated. Tuned by RK tunes in NY. Thanks everyone. The seller has been very very transparent with me as well. Great guy.
02-27-2020, 10:25 AM | #2 |
60122
Rep 19,577
If you want one with a tune go for it, you can also ask him what his procedure was for cold start and running etc.These motors need min 2 minute tick over when cold then kept at low revs until oil temp is hot.
Check the CCB's that they are in good order with no chips at the edges or any flakeiness,should be shining smooth. |
Speenybean91.50 |
02-27-2020, 12:41 PM | #3 | ||
92
Rep 402
02-27-2020, 01:07 PM | #4 | |
5721
Rep 4,209
Drives: '13 F10 M5 | '15 F15 X5
02-27-2020, 01:23 PM | #5 | ||||
92
Rep 402
02-27-2020, 01:35 PM | #6 |
17
Rep 47
Speenybean91.50 |
02-27-2020, 07:39 PM | #8 |
85
Rep 170
I was always told you needed the oil to be warm because it lubricates the turbos, may not be any truth to it but a mechanic told me once and it stuck with any of my turbo cars. I never hit it until my oil is at running temp. I also honor the cold start, more because it's a pain in the azz to drive it when it's revving, he he.
02-27-2020, 08:08 PM | #9 |
56
Rep 146
How long does it take yours to warm up to near operating temp, just on a normal commute? Even on a warm day it seems like I have to go a good three miles before the needle even moves. I'm not sure which oil is in mine but I'm changing it tomorrow to Castrol Edge 5-50 and will be able to compare.
02-27-2020, 08:56 PM | #10 |
85
Rep 170
Yeah, it takes awhile. My M5 takes a lot longer than my 3-series did. With turbos you also don't want to turn it off right after hitting it. I was taught to make sure the engine is not "stressed" when you turn it off.
02-28-2020, 05:15 AM | #11 |
76
Rep 298
I think leaving turbo cars to idle was something I was also told with the Alpina B10 biturbo's.... sounds like a sensible idea even now.
2015 M5 CP Blue
[SIGPIC] Previous Cars:- 2015 GTR > 2014 M5 CP > 2006 M6> 2007 M5 E61 > 2014 F31 328xi >2001 E39 530i > 1995 E34 M5 > 1999 Alpina B8 > 1992 E34 M5 > |
02-28-2020, 05:43 AM | #12 | |
60122
Rep 19,577
02-28-2020, 11:06 AM | #13 |
56
Rep 146
From doing some research people seem to be running all varieties of brands and weights. As long as you do the proper warmup and use a proper oil change interval (not the 10k like BMW suggests) then the motor should be fine. On my E60 I went 4-5k, or about once a year since I don't put many miles on my vehicles.
Basically, this https://f10.m5post.com/forums/showpo...90&postcount=5
2014 Frozen Silver M5, CP, B&O, 601s
1995 Mustang Cobra - 347 stroker Last edited by texsn95; 02-28-2020 at 11:16 AM.. |
02-28-2020, 02:37 PM | #14 |
711
Rep 1,107
My M5 sits in a climate controlled garage. She still warms up for at least a good 10min before I go out. Even then it's another few minutes before I get to the open roads. I don't go over 2-3k until I see the oil temp up near normal temps. When I return I always let her sit idling while I unload the car at least 5 min before putting her away. I run Castrol edge 0W40 but the car is stored during winter months.
'13 Black Sapphire Metallic - BPM Stage 1 Tune - RPI Exhaust - KW HAS Kit - 12mm spacers all around- Carbon Fiber front lip - High Kick Trunk Spoiler - Rear Roof Spoiler - IND Kidney and Fender Grills - 20% Tint all around 50% Front Windshield - PPF
Larry7784.50 |
02-29-2020, 12:08 PM | #15 |
285
Rep 634
when I had my car at BMW I talked to the Tech about tunes.
He said that BMW would allow a wide variety of tunes to the car, however if the tune was outside BMW's parameters a warning message would appear on the diagnostic tool that all warranty and goodwill was voided. If its a tune from a reputable tuner, you should be safe. It mostly comes down to how it's been used, as for any car really. On idling warm-up/ cool down. I typically drive very gentle until the oil is past 70celcius, rarely pass 2500rpm. on returning after a spirited drive I let the car idle for a minute or so before shutting it off. this too cool down the turbos, as they have been spinning at 40.000rpm and is very hot so I let them cool down a bit. |
03-02-2020, 08:56 AM | #16 |
56
Rep 146
Well I did my first oil change, after a few delays due to not having the right filter wrench (different than the E60s) and getting some jack pads, it went pretty smoothly. The motor starts to warm up much faster, I’d say within a mile now instead of ~3 miles before. Very smooth and seems to rev a bit more freely now (but maybe that’s wishful thinking). Added 9qts and got a level reading of ~70% so onward we go.
1995 Mustang Cobra - 347 stroker |
03-02-2020, 10:48 AM | #17 | |||
79
Rep 108
Drives: 2015 BMW M5
2015 BMW F10 M5 | Competition Package | Driving Assistance Pkg | Executive Pkg | Bang & Olufsen | 343M 2NZ wheels
Born 02.27.2015 in Dingolfing |
