02-24-2020, 09:58 AM | #1 |
2516
Rep 2,079
Need help with tire size for the track
Hi There. I used to rtrack my OEM 513M wheels with stock tire sizes 255F 275R 40 sidewall.
I recently picked up a used set of four Apex EC-7 ET25 and hoping for a square setup to be able to rotate tires better. Can I run 275/40/18 all around? I know some suggest 35 sidewall but that is just so much smaller than OEM. Will I rub with 275/40 in the front? And if so, will spacers fix the issue? I plan on getting Toyo Proxes Thanks! |
02-24-2020, 09:41 PM | #2 | |
1019
Rep 859
https://f80.bimmerpost.com/forums/sh....php?t=1686961 |
SYT_Shadow11500.00 |
02-25-2020, 06:57 PM | #3 | |
18776
Rep 14,121
Drives: G82 M4C X-Drive
2022 G82///M4 Competition X-Drive - KW-HAS, EBC Bluestuff, Millway Race Camber Plates, Cup2 Connect*, PSI High Flow Midpipe, Lightweight Front Lip, M Perf Flow Through Wing Previous • 2018 F80 ///M3 CS • 2016 F80 ///M3 IG: Raging_G82 Last edited by jmg; 02-25-2020 at 07:07 PM.. |
03-04-2020, 06:13 PM | #4 |
///M Powered for Life
11500
Rep 10,332
Run 275/35 18 like everyone else
03-04-2020, 06:39 PM | #5 |
533
Rep 1,415
just an FYI but be prepared to run DSC off if you want to run a square setup.
I did this my first year out and was way down on power with MDM on + square setup. Once I went back to staggered the power issue went away with MDM on. I met a guy at Watkins last year who had the same problem, thinking I had a tune as his car was slower than mine. His was a competition and mine is base with the problem being his square setup. |
