02-02-2020, 12:30 PM | #1 |
74
Rep 223
Drives: F86 X6M // E53 X5 4.8is
F85/F86 Operating oil temperature
Guys, please share what’s your NORMAL driving condition oil temperature?
Mine always sits after the first dot in the oil temperature gauge. After about one hour drive, I opened the hood and I did smell coolant from drive side of the engine bay(where coolant tank sits) is this a sign of coolant leaking? My F86 currently has 54k km. |
02-02-2020, 12:39 PM | #2 | |
3552
Rep 1,062
Drives: F15 xDrive50i M-sport
I wouldn't be alarmed at getting a whiff of coolant when the engine's warm. The reservoir is the open part of the system where it "breathes," and when the engine's warm it'll push some coolant out of the engine and into the reservoir, resulting in some fumes being pushed out as coolant displaces air. Just check it several times when the car's totally cold, preferably at about the same ambient temp. If the level isn't going down, you're good.
2017 F15 xDrive50i M Sport | Superformance GT40 Roush 511 IR FE
Lighting.Grey74.00 |
02-02-2020, 05:56 PM | #3 |
165
Rep 199
Mine sits right on the dot during normal highway driving. And hits right where yours is if I push the car hard for a bit.
excu6me on Instagram.
OEM X6M Build |
02-02-2020, 06:22 PM | #4 |
F86, G05, E91
455
Rep 778
First dot (F) when around town.
Track days hits midpoint. |
pennsiveguy3552.00 KFF_X5M44.00 |
02-03-2020, 05:20 AM | #5 |
213
Rep 607
Any consistent odor of coolant is a slight concern. If it's not consistent than u should be fine. Seals and gaskets don't last forever. I had a F86 which needed oil pan gasket at 65k miles. It was a huge job (13 hours on the book). Keep an eye on your coolant levels. Good luck
2017 F86 X6M
2014 F10 M5 2015 F85 X5 M 2015 F86 X6 M (Retired) 2014 F10 M5 (Retired) 2010 E70 X5 M (Retired), 2010 E92 M3 MT (Retired) 2006 E60 M5 (Retired), 2000 E39 M5 MT (Retired) 1999 E39 328i (Retired), 1995 525i (Retired) 1987 325i (Totaled - that was fun!) |
02-03-2020, 10:53 AM | #6 | |
F86, G05, E91
455
Rep 778
I don't smell any coolant or oil after driving. Maybe some spilled after checking or topping off. |
Logical212.50 |
02-05-2020, 01:56 PM | #7 |
83
Rep 122
I'm at about 23,000 miles on my F86 with a bm3 stage 1 tune. In Hawaii weather and traffic (which is horrible) mine sits just barely past the first dot. Never smell coolant. I'd be looking for an issue with that. You shouldn't smell coolant.
02-28-2020, 02:15 AM | #8 |
74
Rep 223
So how often do you top up your coolant?
02-28-2020, 06:34 AM | #9 |
F86, G05, E91
455
Rep 778
I have never had the need. Not sure if dealer has when in for service. No odor ever.
08-07-2021, 04:26 PM | #10 |
986
Rep 1,349
Techinally the dot is 95 C degree and the thermostat we have in the water/coolant pump is 105C degree . But because the water pump flap and thermostat works individually in our F85/86s If the vehicle in Sport Plus mode DME aims engine temperature to stay in 95C instead of waiting thermostat to open in 105.
So pushing the car in Normal mode vs Sport Plus mode makes differences in oil temperature. In mine, if i drive normal in any mode, it stays in 95 C solid and sometimes also goes down to 93C. If i drive hard with Sport Plus Mode then it goes in between 95 C to 120C. which is about 105C-107C which is completely normal. Operation Temperature on our vehicle is 110-115C.
E93 M3 6MT , Nav, Prem, Cold Weather, Sports package, & CA, RGBW DTM with RGB Demons + Eisenmann Race + BE + ARP + Brembo GT 380s, $3AG, $5AC, $508, $6NF, $601
Please "Appreciate" If you like my post! DIYs : OEM Camera Retrofit, FLA Retrofit , Drive Shaft Ticking , Starting Issue, , F85 ACC Retrofit Last edited by SaNGRia; 08-08-2021 at 11:38 AM.. |
08-08-2021, 12:16 AM | #11 | |
74
Rep 223
SaNGRia986.00 |
08-08-2021, 08:44 PM | #12 |
423
Rep 900
Coolant should never need to be topped off. If the level is lower than spec (indicated on the reservoir), then there's a leak somewhere or air in the system (after work has been done on the cooling system). If you’re noticing that you have to keep refilling the coolant, it’s important to have the cooling system inspected to figure out why the coolant loss keeps occurring. Low coolant could lead to overheating and eventual catastrophic engine damage.
