02-01-2020, 12:02 PM | #2 |
2141
Rep 3,647
02-01-2020, 02:39 PM | #4 |
158
Rep 172
Funny this popped up, if my friend still has his tires from his gtr I will try and put them on my wheels. The front would have to be 295-30-21. I literally looked this up the other day.
02-01-2020, 03:38 PM | #6 |
77
Rep 659
Once again I don't ask the full question, my bad.
I'm going to get custom rims 21x13 in the rear and I really want the 355 in the rear, I'm just curios what others have fit in the rear with aftermarket rims that are wider than stock. |
02-01-2020, 03:43 PM | #7 |
716
Rep 1,449
I would suggest the question being posed is inaccurate and should be either one of the follow:
1. What is the widest tires someone is running on OEM spec size rims? 2. What is the widest tires someone is running on non-standard rims? As our rides do not have 4 wheel steering there really is no limit on width if you are on non-standard rims. Aside from visual appearance and height restriction to prevent rubbing there would be no limitation to width with the right rim. If you are using a standard spec rim then you are limited to what size tires can safely be mounted on the 21's rim which has a 11.5" width.
No. Try not. Do. Or do not. There is no try.
-Yoda |
02-01-2020, 03:44 PM | #8 |
716
Rep 1,449
Ah, see above...we must have been typing at the same time
-Yoda |
