01-14-2020, 01:39 PM | #1 |
25
Rep 71
Oil Change time and plugs - help needed.
Good afternoon all. Im coming over here since there are more of you with M5s.
I have a 2014 M6 Gran Coupe and its time for an oil change. Car has just over 20k miles on it, catless down pipes, RK intake, and BM3 stage 2 tune and I live in mostly warm coastal NC. Done some reading but wanted to get opinions on type of oil and weight. Should I move to using Liqui Molly? Also, I should probably change spark plugs and coils also.... dose anyone have part numbers and where I should source these? Thanks for the help.
1997 HMC4 Hummer H1
2003 KSC2 Hummer H1 1969 Jaguar XKE 2014 M6 GC |
01-14-2020, 06:06 PM | #3 |
541
Rep 1,064
Drives: i5 M60, M5's, 535.335, M550i
In my 13 M5 when I moved to liquid molly I noticed my temp gauge would move a little higher than with the "bmw" oil, and was quick to fluctuate upwards on hard driving. I went to molly after a lot of reading and my bmw speed shop recommending it. But was always curious why temp would fluctuate and why it got hotter so quick than it ever did before.
2013 535i M, Carbon black 20' 6 M wheels, totaled.
2018 750M , 2013 M5 , Individual Silver, Bolt ons-Straight piped 2019 M550 686BK Black Chrome 20"wheels, filters, Evolve Stage 1, Res delete 2024 i5 M60 Cape York Green |
01-15-2020, 12:32 PM | #4 | |
79
Rep 108
Drives: 2015 BMW M5
I like a 5w-40 for extra protection on the bearings. Troy Jeup swears by Red Line 5w-50 both for his builds as well as for those on the original motors; it's got a crazy high HTHS of something like 5.0.
Look up Ravenol VST 5w-40, look at the specs, and tell me if you find one that's better. (LM isn't it.) You can get it at Blauparts to your door here in the States. BMW went to their 0w-30 in early 2015 from the 5w-30 they were previously using, but BMW LL01 says you can run up to 5w-40. Actually, with the sulfur taken out of US gasoline now via EPA Tier 3 Sulfur standards that began on 01.01.17, you can actually run a BMW LL04 if you wanted (half the sulfated ash content; ≤0.8 SA vs. ≤1.6 SA.) I might consider Ravenol Racing RUP 5w-40 if I can still even get it, for my next annual oil change. 0.8 SA and a 6.0 Noack with an HTHS of 3.9 - hard to beat that. No more exceptions for small refineries beginning 01.01.20 - it's 10ppm sulfur in US content gasoline now just like it has been in Europe for years. https://www.epa.gov/sites/production...20-webinar.pdf Quote:
2015 BMW F10 M5 | Competition Package | Driving Assistance Pkg | Executive Pkg | Bang & Olufsen | 343M 2NZ wheels
Born 02.27.2015 in Dingolfing Last edited by AirBull; 01-15-2020 at 12:49 PM.. |
01-15-2020, 04:11 PM | #5 |
On the Go!
79
Rep 235
One of my fav topics again!
My thoughts: 1. Use any but the BMW oil. 2. Use a good quality brand (e.g. Total, LM, Motul, etc.). 3. Ensure you drain the old oil for at least 30 minutes (BMW SAs told me they do it only for 10 minutes). Do this at least the first time you change to a different weight. 3. Use a good weight oil 30w is what BMW uses, most tuners / engine builders say you need to use 50w or 60w. I personally use Motul 5w 40 (this was offered at a good deal just when I wanted to make the switch) - its LL01 per BMW requirements and since my car is in warranty I am going by their brochure of recommended oil weights. I change my oil every 4500 miles (Note that I do not track my car). I use OEM spark plugs but change it every 20,000 miles. I believe BMW intervals are 30,000 or higher. My car is mechanically bone stock and I have only changed it once as I am yet to cross the 25,000 mile marker. Again, anything but the BMW oil will be an upgrade, once you pick the one you like, its important that you stick to it. Not all BMW shops will allow you to use the weight / brand of your choice. You have a bigger spectrum to choose given your proximity to warmer climate. Good luck!
It doesn't matter if you win by a mile or inch, Winning is WINNING!
01-15-2020, 10:12 PM | #6 |
627
Rep 648
Why stick to the same? Isn't it okay to switch viscosity from time to time depending driving habits or temperature variations?
01-17-2020, 10:42 AM | #7 |
On the Go!
79
Rep 235
You can.
I follow it as advised to me by several, incl. some of my close pit-crew friends. I stick to it and see the 2-3 reputed tuner shops on the west coast and here in the northeast follow it. It may well be a myth as there is no scientific research to support it.
01-19-2020, 09:16 AM | #9 | |
830
Rep 1,254
5w40 should be fine, I'm in Raleigh so a little less temperate than Wilmington but I keep it in the garage.
2009 E92 M3 build thread: https://www.m3post.com/forums/showthread.php?t=1754875
Follow me on IG - www.instagram.com/the_driven_enthusiast |
01-19-2020, 09:22 AM | #10 |
830
Rep 1,254
Also, LM is fine, I think that's what most of us use; you should also consider getting a blackstone oil analysis to get a baseline for rod bearings. From there, change oil ever 3-5k, compare blackstone reports to your baseline and you should be fine. If there's an anomaly, blackstone will tell you and you can take precautionary action. RB's on this car should be around $3500 or so.
01-20-2020, 06:59 AM | #13 |
25
Rep 71
Yeah, they told me, you could run pretty much any high quality 0W30 and would be fine but stick with 0W30.
1997 HMC4 Hummer H1
01-20-2020, 08:28 AM | #14 |
I'm The Captain Now
501
Rep 1,811
Drives: X5M/X7
Garage List 2021 BMW X7 MSport ... [0.00]
2018 Raptor [0.00] 2015 X5M (SOLD) [0.00] 2014 BMW M5 (SOLD) [10.00] 2014 BMW M5 Totaled [10.00] 2014 Jeep SRT (SOLD) [0.00] 2012 C63 AMG (SOLD) [0.00] 2015 BMW M4 (SOLD) [0.00] 2011 Porsche Cayenn ... [0.00] 2007 911 Turbo (997 ... [0.00] 2013 335i M Sport ( ... [0.00] 2002 Porsche 911 Tu ... [0.00] 2008 BMW 135i (SOLD) [6.00] 2002 BMW M3 SOLD [10.00] |
Ive been running 0w40 in everything for years. I was told by my tuner the other day they use 15w50.
01-20-2020, 02:30 PM | #15 |
1416
Rep 1,564
I switched to Liqui Moly 2331 Leichtlauf High Tech 5-40 and add 1.5 cans of their Mos2 additive in each oil change and never looked back. I use this for all of my vehicles now, IMHO BMW's 0-30 recommendation is for mileage only, it does nothing for longevity.
When I made the switch, I noticed immediate improvement in "operational smoothness"... hard to quantify but you will notice a smoother idle and through the rpm band. But don't just take my word for it, here are pics from my N63 powered X5 with over 150K on it. I took it down to do the valve seals & decarbonize as well as do a mild port and polish but as you can see, the cam journals and and cylinder walls look excellent for this many miles. |
F13.KENN603.50 |
