01-13-2020, 10:22 AM | #1 |
821
Rep 684
Repair the M3 Undertrays DIY
Im a DIYer who enjoys the challenge of taking care of things myself.
A while ago i asked the forum about a way to fix the under trays on my M3 that where pretty much destroyed. The majority of responses that I received were that they cannot be fixed and to just toss them and purchase new ones. I have no idea why i listened, moreover, why did i listen to people who haven't tried and wouldn't try to figure this type of stuff out for themselves. Enough complaining. The undertrays are made up of some type of plastic/composite and a layer of felt type fabric on the outside. To repair cracks, holes, delaminations and so on requires the use of a plastic welder. I used the soldering iron type of "welder". I failed a few times using the plastic that came with the kit so i ended up shaving small chunks of the actual undertrays themselves and using it like a skin graft. If you can do this, it is the best practice because chances are that it will be very difficult to find the exact plastic that they used to initially build the part. manufactures ABS might have a different compositions from one to the next. 1. clean, sand with sandpaper the damaged area. 2. heat up the damaged area with a heat gun or the welder. 3. when the damaged area is almost melted, lay down the clean grafted pieces of plastic and use the welder to melt them into the damaged area until they are completely mixed in. 4. sand and clean up the area as you desire. Remember to use a caul, clamps or whatever else you might need while working on the part as you want to work on it in its final shape because the heat can change its shape. For my repairs i built them up with new plastic much larger and thicker then the factory and melted some medal screen into a few of the more damaged areas. And if the damage area was 1 inch I would repair about a 2 inch area. Stop listening to the masses. -Mark |
01-13-2020, 11:55 AM | #2 |
3085
Rep 2,747
Great now they can get destroyed again...
The original felt piece is suspended and made to withstand a few bumps and damage from parking curbs. It's also an integral part of the oil cooling system. The reason the majority of people in the thread your referencing said toss it and start with an aluminum one is because it's a far more robust design that doesn't hang so low and resistant to damage. It's a solution to the problem.. I guess it's tough to recognize that though up there on your soap box.. 😂
9ers
01-13-2020, 12:30 PM | #3 |
5258
Rep 10,636
Pictures of repairs? I did some patching and zip tying on mine to get more life, but eventually bought the aluminum flat plate that deansbimmer sells and have not had any scrapes since. My car is lowered so that made the scraping and damage worse than on a stock car.
LakeSurfer821.00 |
01-14-2020, 06:58 AM | #4 | |
821
Rep 684
Again buying new panels sort of defeats the purpose of fixing the old ones doesn't it? Which is the entire point of this post. You can fix them without paying $700 for a piece of aluminum that has a slight bend in it and some holes cut out. Its not about the money though its the principal. "But you'll just break it again" My car is a 2011 and the panel has lasted 9 years so I fixed it like new and it will last another 9 years. Yes the aluminum panel sits up higher but what would happen if you hit a curb or a parking block with it installed? you'd surely do more damage opposed to the OEM. the OEM part is sacrificial and will break, bend or twist long before anything else. yet again not the point. I also disagree with the importance that this part plays in oil cooling. It to me appears to simply help the air escape after smashing into the radiator. The from bumper cover is far more important then these plastic pieces. But again not the point. I would bet you can run your car as usual without the panels and not notice any difference. -Mark |
NekMinnit9.00 |
01-14-2020, 07:05 AM | #5 | |
821
Rep 684
mine lasted 9 years so i took it off to see how bad it was and just started messing with it. I was actually planning on ordering from Deansbimmer and perhaps still will at some point but the repairs turned out so much better than I thought, i might wait on it for a while. -Mark |
01-14-2020, 07:37 PM | #6 |
340
Rep 1,293
A few months ago, I decided to laminate all three pieces in Kevlar and carbon fiber. I had previously done the same on the outside pieces, but the bottom leading edge eventually wore threw. On the new pieces, I made what looks like a horse shoe for the bottom leading edge out of 1/8” sheet aluminum, and fastened it with low profile sidewalk bolts. I’d post a picture if I could figure out how to post with a iPhone. In any case, this “horse shoe” has been holding up extremely well. I suspect you could use this horse shoe approach without laminating the pieces with carbon fiber and it would fend off 99% of the wear.
LakeSurfer821.00 |
01-15-2020, 02:19 AM | #7 |
185
Rep 780
Badass, cool write up and nice option for anyone not wanting to fork up the replacement cost of one
LakeSurfer821.00 |
