01-07-2020, 07:19 AM | #1 |
12
Rep 60
Seafoam or similar on S63 engine?
Hi guys,
Just wondering if anyone has done seafoam or similar intake manifold / valves cleaners on S63 engines. Probably good to do it as regular maintenance as direct injection engines get messy around the valves, just wondering if someone had some experience with this and recommend where to inject it. Cheers! |
01-10-2020, 07:00 AM | #4 |
252
Rep 606
Drives: 2000 M5, 2001 M5, 2013 M5 6MT
I don't have any specific knowledge trying seafoam on this engine but I would guess you don't want it going through the turbos. I suppose it's for a limited time so it might not be a problem but personally I wouldn't take the chance because I don't know enough to take the chance.
01-11-2020, 04:54 AM | #5 |
12
Rep 60
surely no good to go through the turbo, and I dont think it will clean all that much that way because it needs to expand and foam up.
The idea of the product is to have it fill/foam up the intake manifold which will break down the carbon deposit/gunk/oil etc and wash them off and burn. I wonder if removing the stock air filter boxes would give me me any access to the intake manifold. |
01-13-2020, 02:20 AM | #6 | |
50
Rep 140
I found this on f82 platform, hope it gives you some ideas |
01-13-2020, 02:37 AM | #7 |
60092
Rep 19,558
Instead you can use Redex with every fuel fill,available from Costco it will slowly clean up your engine, keep injectors sweet and reduce Co2 emissions.
01-13-2020, 04:05 AM | #8 | |
77
Rep 169
Of course it will do injectors and rings, but how do we clean valves?
BMW F10 M5 Competition
Hyundai i30N Porsche 986 Boxster S |
01-13-2020, 04:37 AM | #9 |
I'm The Captain Now
501
Rep 1,811
Drives: X5M/X7
Garage List 2021 BMW X7 MSport ... [0.00]
2018 Raptor [0.00] 2015 X5M (SOLD) [0.00] 2014 BMW M5 (SOLD) [10.00] 2014 BMW M5 Totaled [10.00] 2014 Jeep SRT (SOLD) [0.00] 2012 C63 AMG (SOLD) [0.00] 2015 BMW M4 (SOLD) [0.00] 2011 Porsche Cayenn ... [0.00] 2007 911 Turbo (997 ... [0.00] 2013 335i M Sport ( ... [0.00] 2002 Porsche 911 Tu ... [0.00] 2008 BMW 135i (SOLD) [6.00] 2002 BMW M3 SOLD [10.00] |
boots recommended it for some that had minor smoke issues.
boots623.00 |
01-13-2020, 04:44 AM | #10 | |
60092
Rep 19,558
I use it with every tankful when I fill with Shell. |
01-13-2020, 06:26 AM | #11 | |
12
Rep 60
Ideally want to spray this directly to the intake manifold while engines warm but off so it can fill the area with bubbly foam and break the build up down. |
01-13-2020, 06:45 AM | #12 | |
12
Rep 60
The issue with GDI engines like ours is that the intake manifold or intake valves won't see any fuel at all, just air and some airborne oil with it which creates mess around the valves and valve seats. |
M5Rick60091.50 |
01-13-2020, 06:47 AM | #13 |
12
Rep 60
Hmm this advertising material from the CRC product claims that it is safe to spray before the turbo and it actually cleans the impeller too. Maybe I should try that product
01-20-2020, 12:33 AM | #17 |
50
Rep 140
01-20-2020, 05:02 AM | #18 | |
Curve Thrasher
623
Rep 3,773
2013 Bmw M5-Alpine White/Black-Oem gloss blk powder coated wheels-Expel clear bra-35% tint-Rpi Gtm Exhaust-Rpi Downpipes-Rpi Scoops-Halim Cazimi Performance Tune-KwV3 coilovers
Country run |
01-20-2020, 08:27 AM | #19 |
I'm The Captain Now
501
Rep 1,811
Drives: X5M/X7
Where are you adding it?
01-20-2020, 03:33 PM | #20 |
1416
Rep 1,564
I have always been curious if these actually do anything and this thread has inspired me to do a bit of testing. I just pulled the intake valves out of a N63 (valves are nearly identical as S63's) with its infamous valves stem seals, going to place the valves in jars of each of the popular valve treatments (Seafoam, CRC, LM, Berryman, Marvel MM, etc) heat it all to 200F, let it sit for 20min, then see what the difference is with the before and after.
While not exactly the same environment of a running engine, it should give us an indication if they actually do anything at all. All of the treatments and the hotplates to do this are on order and will be here today, will post results within the next day or two for all those Interested. |
01-21-2020, 10:44 PM | #21 | |
Curve Thrasher
623
Rep 3,773
Country run |
01-23-2020, 03:22 AM | #22 | |
77
Rep 169
