01-06-2020, 09:01 PM | #1 |
412
Rep 737
Sparco QRT-Rs installed in F80
Finally pulled the trigger and got some race buckets. Car will be heading to Mark McMahan for a 1/2 cage. Waiting until that’s in before installing Schroth 6 points. I’ll update this thread with that stuff in the future. Currently leaning toward completely removing 3 point belt functionality.
I’m trying to get detailed here to help anyone looking into seats and/or mounts in the future. I’ve seen a lot of posts about seats but none had all the info I wanted. Sparco QRT-R seats OMP sliders VAC floor mounts Sparco 600QRT side mounts VAC floor mounts installed with the factory torx bolts. Sparco QRT-Rs almost fit perfectly in the cockpit. The front widest part of the seat is 500mm. A lot of the reason I went with these seats is because most other seats are wider than this. I copied the fore and aft travel of the stock seats. At 75% forward travel (for shorter people), the seat begins to contact the tunnel. I used the bolt holes closest to the tunnel on the VAC floor mounts. The side mount slots are maxed all the way toward the tunnel as well. In fact, the easiest way to install the sliders is outside of the car. Bolt side mounts to seat, mount slider to tunnel side mount and bias the bolt in slot all the way toward tunnel. Tighten that tunnel side slider. Then measure exactly 370mm to the other slider holes and tighten. Slide seat all the way rearward. Set seat on floor adapters and align holes. Install front bolts first (4th bolt hole from the front) and tighten as there is no pressure from the tunnel. Now you can “force” the seat to hit the forward limit of the sliders but it takes more than a push while standing outside the vehicle. If seated, your momentum to slide forward overcomes the carpet compressing. Then bolt down the rear. Slider is mounted in the 11th hole from the back of the floor mounts. I could’ve mounted more rearward but I mimicked the travel of the stock seats. The passenger side I relieved from tunnel so that the seat only makes contact in the most forward position... but there is no steering wheel to center. I had to use shorter bolts in the back when mounting the sliders or else they would contact the seat. Use of the rear most slot in the side mount was also needed because of the bolt hitting the seat. I had to use the highest mounting hole in the rear of the side mount to clear. The seat sits pretty close to where the lowest point of the stock seat was. I think it’s perfect for track use with a helmet. Maybe a tad low for me if daily driving. The worst part about the sliders was the bent handle. The handle is suppose to angle up but hits the seat before unlocking. So I flipped it and facing down the handle is not even a finger thickness off the carpet. So grabbing the handle you have to sorta compress your finger and press down the carpet. Just get sliders with a straight handle if you’re reading this. I’ll be using VAC lap belt mounts and VAC anti sub mounts. Both items mount to the VAC floor adapter. I know, not legal by most race sanctioning bodies but the best I can do with the interior in place. Last edited by bimmerboyE92; 02-23-2020 at 06:36 PM.. Reason: Revised side mounts |
Kev608180.50 chetrickerman10443.50 ctgeorge313.50 FriedPiston1972.50 BetrayMyWord62.50 richf8079.00 irunalot1518.00 drroc420.00 |
01-07-2020, 06:10 PM | #3 |
412
Rep 737
I have a middle-age chubby build if you know what I mean. 5’8” 195lbs. 36x32 in jeans. Width wise is good, height wise my shoulders are 1/2” into the shoulder holes. So if you’re taller and weigh a bit more it’s good. But this is for race seat fitment... I wouldn’t daily this thing! My manhood gets kinda squeezed when you first “plop” into the seat and you have to adjust them out of the way if that makes sense.
But I find a Corbeau FX1 (the regular version for up to 38” waist) too big in hips and shoulders. And I also find the Recaro Profi SPG XL too big mostly in hips. |
01-07-2020, 06:52 PM | #4 |
BimmerPost Supporting Vendor
8254
Rep 18,843
Drives: BMW
GRT-Rs are a fantastic seat, its essentially a taller Pole Position and allows the harness cutouts to be above the shoulder points on taller drivers.
johnc_m491.00 |
01-08-2020, 05:07 AM | #5 |
412
Rep 737
Got these from EAS during their Black Friday sale. My primary question besides personal body fit was which seats fit into an F80 with a full interior. TOM’s answer was the QRT.
The shoulders are 560mm - could probably go with 590mm before contact with the B-pillar. The issue is the seat base. The QRT-R is 500mm which is one of the smallest out there. And at 500mm is already contacts the trans tunnel. That is gt he critical dimension for anyone shorter than 6ft IMO. |
tom @ eas8253.50 |
01-10-2020, 05:12 PM | #7 | |
ECUTek Master Tuner
10444
Rep 1,734
Drives: F80 M3 YMB
Looks awesome! Im sure it dropped a lot of weight as well.
01-22-2020, 10:38 PM | #8 |
966
Rep 5,033
Those look amazing. Easily 30lb weight savings I would guess.
behindthen0thing839.50 |
01-25-2020, 05:21 PM | #10 | |
336
Rep 591
02-23-2020, 06:46 PM | #11 |
412
Rep 737
Decided the VAC mounts were a little too low. Spoke to Sparco and they recommended the QRT-R specific mounts.
Pros Driver seat is now perfectly centered! The slots were just big enough to push the seat far enough toward the tunnel to center it. Actually 3mm from completely over. The passenger seat is 10mm further away from the tunnel compared to the driver. Seat sits 35mm higher in the rear and 75mm higher in the front vs the VAC mounts. And there is still one more hole to recline if need be. Round hole in the rear is more robust during a rearward crash Cons Steel construction is not as light as the VAC Also mounted rubber bump stops and VAC lap belt mounts to use with 3 points. I used eye bolts just because I had them from left over from a harness install. Had to put them on top of the floor mounts instead of underneath. Not sure it would really have made a difference but according to NASA (the space people), pull out force is 4000lbs per bolt. I’ll have the cage builder put in proper mounts for the 6 point harness. Used 2016 X5 rear seat belt receptacles. I’ll be using seat belt extenders with the 3 point belt. VAC anti sub was mounted 20 deg behind crotch hole per Schroth instead of VAC’s instructions all the way to the rear of the floor mounts. Alex @ Alpine coded out the airbags and seat belt receptacles. So I’m assuming that the steering wheel and passenger dash airbags will still function in the event of a crash. Last edited by bimmerboyE92; 02-23-2020 at 06:52 PM.. |
06-21-2020, 05:05 PM | #13 |
412
Rep 737
Here it is complete with McMahan bolt in half cage. Photos don’t do it justice! Rear bars have welded in tapping plates. Front hoop has plates the size of a cookie sheet top and bottom of floorpan. Schroth Enduro harness is worth it just for ease of adjustment as well as installation.
01-15-2021, 12:29 PM | #14 |
582
Rep 238
Picked up some qtrs for my m2. Hopefully you see this! Similar situation, 5'9 175 and sit kind of high w/ stock seats. I don't like super low seats; did the sparco plates work for you? Any better with them for daily use? Thanks!!
01-15-2021, 12:34 PM | #15 | |
412
Rep 737
Being my wife's car, she says these seats are almost made for women and have hip room compared EVOs.
01-15-2021, 01:45 PM | #16 |
10841
Rep 3,715
If not too personal can I ask what your height/weight/waist is? I want to get a set of QRT leather seats but the one QRT sample seat I was in was a bit tight. 6'2/190/32
01-15-2021, 02:13 PM | #18 |
3663
Rep 3,422
Nice work. The slotted side mount base for lateral movement tight to tunnel is a must for getting centered to the wheel.
Do you have a flappy buckle for passenger seat but not driver?
M4 GTS, GT3, C63 S | E90 M3s, E39 M5
01-15-2021, 02:33 PM | #19 |
412
Rep 737
5’8” 180. All race seats fit tight when you’re not used to them. The seat is actually too big... could be tighter for track use. DO NOT daily drive this seat! It’s a pain to get in out of because it’s so deep. For DD go with the Cobra Nogaro.
01-15-2021, 02:41 PM | #21 |
1582
Rep 1,976
Wow you lost 15pounds! and during a pandemic of all times. congrats!
