09-01-2008, 09:16 AM | #1 |
337
Rep 8,811
6MT - Pulling away in 2nd
Because 1st gear is so powerful, I sometimes find it easier and smoother to pull away from a standstill in 2nd gear instead. Are there any issues with doing this and will it cause extra stress on the clutch?
Would welcome any thoughts and views |
09-01-2008, 09:44 AM | #3 |
337
Rep 8,811
So its completely fine to pull away in 2nd? So long as I don't use lots of revs as I did it the other day and burned the clutch a little - whoops!
09-01-2008, 09:45 AM | #4 |
Rep 184
As long as you are not bogging down the engine, everything should be fine.
If all the animals below the equator were capable of flattery, then Thanksgiving and Halloween would fall on the same day.
09-01-2008, 09:49 AM | #5 |
Moderator
7517
Rep 19,368
Sure you can do it, but the car is really only as powerful as you want it to be. In fact, have you tried engaging first gear with no gas applied at all? It will work fine. So, just go easier on the pedal and you won't really need to use second to take off. Also, if you are in sport mode or sport plus mode, try the next lower mode too as it will allow you to modulate the accelerator easier.
09-01-2008, 10:04 AM | #6 |
337
Rep 8,811
Cool. Its just because I burned the clutch a bit the other day, I was worried that maybe using 2nd and a few revs was a bad move. I'm happy to use 1st instead its just a bit more lively (which isn't a bad thing!)
09-01-2008, 10:21 AM | #8 |
Moderator
7517
Rep 19,368
Ok, well "burning the clutch" is bad no matter what. You are slipping the clutch too much it sounds like. Even in second, it should be possible to launch the car with little or no throttle and very little clutch slippage. Practice it, you'll get the hang of it.
09-01-2008, 10:28 AM | #9 |
337
Rep 8,811
Cool thanks! Anyone else pull away in 2nd on a regular basis?
09-01-2008, 10:54 AM | #10 |
Moderator / European Editor
1545
Rep 6,754
Not on a regular basis but every now and then, yes.
Best regards, south
09-01-2008, 01:10 PM | #12 |
NASA SpecE30 Racer
82
Rep 1,307
I will disagree with everyone and say it is a bad idea. In order to get the car launched in second without stalling you will definitely need more RPM or more clutch slipping both of which will damage your clutch quicker. The car doesn't make much torque or horsepower at 1500 RPM, so you should be able to take off in 1st gear with no problem. I suggest you work on your clutch skills and take off in 1st not 2nd.
King Tut
2012 BMW M3 Individual: Sold lsb.ridedomain.com 1987 BMW 325is SpecE30: spece30.ridedomain.com 2009 BMW M3 Coupe: Sold e92.ridedomain.com |
09-01-2008, 01:24 PM | #13 |
22
Rep 288
Drives: E92 M3 AW/Blk sunroof 19s
Its not a good idea unless you are rolling downhill - the clutch is taking extra strain and will wear out faster. Rather use first with small throttle opening.
09-01-2008, 03:16 PM | #14 |
602
Rep 5,448
dont spin the clutch too much. I only do this from a slight roll or a slight downhill.
Fore Sale Rare 6 speed manual X3 3.oi silver over grey. PM me
09-01-2008, 09:30 PM | #16 |
242
Rep 735
Don't worry, it's completely fine. I start in 2nd all the time in slippery conditions to avoid wheel spin.
Current: BMW F32 435iA M-Sports; BMW E92 M3, M-DCT; Mercedes W221 S550 4matic; Ford Fiesta ST; Nissan Silvia S15 Spec-R Retired: BMW E93 323iA; BMW E85 Z4 3.0i, SMG; Lexus IS 250 AWD; Lexus GX 470; Mercedes W203 C230 Sportscoupe; Peugeot 206 S16; Peugeot 206 RC |
09-01-2008, 09:58 PM | #17 |
53
Rep 297
hmmmm yeah, sometimes i pull up using 2nd gear, and this thread makes me think about it, any more insights or views about this topic?
2008 AW E92 M3 (sold ) Amuse Ericsson Exhaust, Amuse Trunk, Vorsteiner Lip, BMW Performance Seats, AA SSK, AA Pulley, Gruppe-M Intake, BBS 19" LMs, AP Racing BBK
1994 BMW E36 M3 Euro (Track Car) |
09-02-2008, 04:49 AM | #18 |
337
Rep 8,811
Good answers everyone and its interesting to hear the differing views
09-02-2008, 07:24 AM | #19 |
374
Rep 8,033
There is no issue with this as long as you aren't trying to load the engine significantly. In other words, if you are stopped on a flat road and want to pull away "normally", 2nd gear would be fine. That should not cause more clutch slippage as long as you don't over-rev (the clutch will fully engage as you get going at a lower engine rpm in second gear compared to 1st due to the gearing difference). Once the clutch is engaged, and if your clutch is functioning properly, it doesn't matter if you are in 1st or 2nd.
09-02-2008, 10:13 AM | #20 |
NASA SpecE30 Racer
82
Rep 1,307
Seriously if you guys can't keep wheel spin in check when starting in first gear in the rain then perhaps you need to go back to a 325i and never ever take off traction control for the safety of the other drivers on the road. You should be able to get your car to start off in first gear with no input from the accelerator just from the idle RPM now try that in second gear and let me know if you can do it. You need more RPM to keep the car from stalling when starting off in second gear.
King Tut
09-02-2008, 10:27 AM | #21 | |
374
Rep 8,033
09-02-2008, 10:32 AM | #22 |
Moderator
94
Rep 1,920
It is fine to start in 2nd...just do NOT slip the clutch too much. Clutches wear when they SLIP...so just don't slip it too much! Higher rpm and mucho slip = mucho wear. Simple as that.
Tim <--- apparently likes "3" cars
2014 E63S -- The Rocket 2014 F30 328i -- Kids car 2008 E90 M3 -- Sold 2004 GT3 -- Sold 1997 M3/4 -- Sold 1995 M3 -- Sold |
