10-18-2019, 03:31 AM | #3 |
69
Rep 469
The best any alignment shop could do is -1.5 on the rear. It just chews through tires with aggressive driving. Idk if this is just a fluke with my car or just a “pay to play” kind of thing. I’m thinking maybe tune it back to stock power levels to ease the tire wear as well.
10-18-2019, 04:28 AM | #4 | |
60092
Rep 19,560
10-18-2019, 04:45 AM | #5 |
69
Rep 469
Standard wheels. And yes they used a 4 wheel alignment machine.
10-18-2019, 05:02 AM | #7 |
69
Rep 469
Definitely a larger car. I’ve been through all the tire models trying to find a solution lmao. SS, cup 2’s, now I’m using Bridgestone re-something. I’m thinking it has to do with the power, I’ll tone it down tomorrow.
10-18-2019, 06:53 AM | #8 |
711
Rep 1,107
If they can't get it in spec on stock suspension, then something is bent. Was the car ever hit? Take it to another shop to confirm it can not be put in spec. I'm on KW HAS and pretty low, my rear camber is within spec. No unusual tire wear. GL
'13 Black Sapphire Metallic - BPM Stage 1 Tune - RPI Exhaust - KW HAS Kit - 12mm spacers all around- Carbon Fiber front lip - High Kick Trunk Spoiler - Rear Roof Spoiler - IND Kidney and Fender Grills - 20% Tint all around 50% Front Windshield - PPF
10-18-2019, 07:39 AM | #9 |
69
Rep 469
I’ll try another shop. The car was never hit, could bushings be bad or something? It has 75k miles on it.
10-18-2019, 07:42 AM | #10 | |
711
Rep 1,107
10-18-2019, 09:09 AM | #11 |
252
Rep 606
Drives: 2000 M5, 2001 M5, 2013 M5 6MT
Please note that camber is not the only thing that affects rear inner tire wear. Toe settings will also wear out the inside edge. Toe settings that cause inside wear can also cause excessive wear across most of the thread width because the tire is not tracking "straight" but rather at too much of an angle. -1.5 degrees of camber is not excessive btw.
10-18-2019, 03:54 PM | #12 | |
711
Rep 1,107
10-24-2019, 06:29 AM | #13 | |
69
Rep 469
10-24-2019, 07:02 AM | #14 | |
69
Rep 469
