BMW X5 and X6 Forum 2014-Current
      10-09-2019, 01:29 PM   #1
satish1015
65
Drives: BMW F85 X5M
H&R VTF issue
Hey guys I had H&R VTf's installed about a month ago or so but I rarely drive my F85. After it was installed on full lock I heard a single bang which occurred a few times. Spoke to my installer and they said that what they see is that the spring is turning on itself when on full lock. Didn't hear the sound since then.
Yesterday, I took the car to the dealership to replace the brake sensor since it fried and when leaving I began to hear the. Lose again. Dealer took a look at it and said the same thing. They said it shouldn't be a problem as long as I can live with the sound, but I don't think I can live with my suspension making noises. It sounds like the spring is going to pop! Anyone else have this issue?
      10-09-2019, 08:06 PM   #2
r33_RGSport
r33_RGSport's Avatar
12971
Drives: G09 XM, G05 X5 40, 991.2 T
I had a customer who had that issue.
I sent H&R the video of the spring binding, and they couldn't figure out why.
I told them that my suspicion was that they change the spring spacer between main spring and helper spring to plastic instead of solid fiber glass piece.
The plastic spacer doesn't slide as easy as the fiber glass piece when the spring twist during a full turn.
But, they don't buy it.
Customer swap to Eibach at the end and I sent the VTF back to H&R.
So, there is solution pretty much.
It start happening on the later batch when H&R changed the spring spacer material.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com
PM for Everyday DEALS!!
MSS • iSweep • RaceChip • Sterckenn • AutoTecknic • Akrapovic • Vossen Wheels • Eventuri
Active Autowerke • KW • H&R • Ohlins • Remus • and more...
MJRPA28.50
      10-09-2019, 11:10 PM   #3
donut_boi
998
Drives: 2015 F85 X5M DGM
Bin, would it be possible to order from other manufacturer the spring spacer in the right material to eliminate the noise. I know it may be tough to find the right size but may be a great option for people that still want to run the VTFs.
2015 BMW X5 ///M | Donington Grey | Aragon Brown
MRF Engineering | RG Sport | BMW Performance | Dinan | KW | Vorsteiner | Zito | iND | BMW Parts Pros | Coby
2010 BMW 328i AT xDrive E91 Touring ///M Sport | Alpine White | Saddle Brown
Appreciate 2
r33_RGSport12971.00
MJRPA28.50
      10-09-2019, 11:27 PM   #4
r33_RGSport
12971
Possible.
Just need to do some research.
Been trying to do that, but you know me. Lots of things on my plate.
Others just milking from my information and not even helping out. Haha.
Appreciate 2
donut_boi997.50
MJRPA28.50
      10-10-2019, 02:06 PM   #5
daytonaviolet
OEM CSL Whore
daytonaviolet's Avatar
Philippines
1250
Drives: 2017 F85 X5M
Possible.
I wonder if tap plastic can make one ?
      10-10-2019, 02:17 PM   #6
r33_RGSport
12971
Can you measure what is the Inner Diameter and Outter Diameter of that plastic ring?
I saw Swift make 3 different sizes.
      10-10-2019, 03:48 PM   #7
satish1015
65
Drives: BMW F85 X5M
Hmmm.. does this only happen to some? Because the set installed on my brothers F85 doesn't do it and his is actually set lower than mine. I hate hearing this sound!
      10-10-2019, 04:02 PM   #8
r33_RGSport
12971
So far you are the 2nd guy I know that having this issue.
      10-10-2019, 04:49 PM   #9
daytonaviolet
OEM CSL Whore
Philippines
1250
I sold the vtf. But let me ask the buyer 🤪
r33_RGSport12971.00
      10-10-2019, 05:06 PM   #10
r33_RGSport
12971
      10-10-2019, 06:37 PM   #11
daytonaviolet
OEM CSL Whore
Philippines
1250
The buyer installed them today 🥴
r33_RGSport12971.00
      10-12-2019, 11:35 PM   #12
satish1015
65
Drives: BMW F85 X5M
So maybe the set I have is defective? Would H&R replace them?
r33_RGSport12971.00
      10-12-2019, 11:39 PM   #13
r33_RGSport
12971
You can try to call them.
It is very complicated process.
      10-13-2019, 05:27 AM   #14
MJRPA
29
Drives: BMW X5
I had a similar issue with them. Mine had a thump noise every now and then when I would be in motion and turning the wheel. Turns out they weren't installed properly. Had another shop take a look and they fixed it. The inside cup was loose one one side and was just spinning by itself, not sure if that was the exact issue but it stopped making the noise. Could be a combination of that and the spring settling. Now I'm dealing with another issue lol, the right side of my car is about a quarter in lower than the left. I'm most likely switching to the Eibachs.
xbimmers
