BMW X5 and X6 Forum 2014-Current
      10-07-2019, 12:05 AM   #1
UAEX6M
71
Drives: X6M 2016
Muffler delete or resonator delete
Hello,
Have anyone done a muffler or resonator delete? How does it sound? And does it drone?
Thanks
X6M ?16
      10-07-2019, 10:23 AM   #2
VETTEPRO
248
Drives: 2021 X5M Comp, Grigio Telesto
I took out the resonators, which didn't do much.
We do a trick with the late model Corvette mufflers at my shop. I did the same thing to my 550i, M5 and now my X5 M.
I cut a window in the top of the muffler, pulled out all the packing and made a piece of sheet metal that would cover all the perforations in the pipes inside. I tack welded it in place and then heated it so it would conform to the shape of the pipe using a hammer and small chisel. Then I welded it all around and welded up the window I had cut.
It sounded pretty good, but still a little too quiet.
I took the muffler back off and did the same thing to the bottom of the muffler.
Now it sounds really good and has no drone. I get a lot of compliments on it.
I put on Akrapovic carbon fiber tips (knockoffs) and it look and sounds as good as anything out there.
I think I'm going to put an x pipe where the resonators were just to see.
2021 Individual Grigio Telesto Gray Pearl Metallic X5M C, BC Forged, Dinan tuned, Dinan suspension, MAD Downpipes, Dinan Exhaust. More to come.
Owner, Designer, Tuner- A&A Corvette Superchargers
WWW.AACORVETTE.COM
shimmy232350.00
      10-08-2019, 10:24 AM   #3
F3085258
81
Drives: 2016 X5M
VETTEPRO
check out this post https://f15.bimmerpost.com/forums/sh...php?p=25102197
Guy did electric cut-outs. He also tried adding an X pipe. He said x pipe was quieter and didn't sound as good.
I have done a few x pipes on NA cars and found that the sound and tone was improved. Maybe not with turbos??
I am either going to do a muffler mod like suggested or e cutouts. E cut-outs will be louder and can control with a separate remote to open/close anytime I want.
      01-13-2023, 08:04 AM   #4
Tcarter7777
12
Drives: BMW X6M
Originally Posted by UAEX6M View Post
Hello,
Thanks
I recently did a Muffler delete only on my 2015 BMW X6M. Love the way it sounds may add in X pipe soon right after mid resonators.
I haven’t had time to record good videos but will post link showing a cold start no revs because it was really early and loud lol. Also a short video of a normal start with a couple of revs in normal drive mode.
normal start/drive mode
cold start
      01-13-2023, 10:07 AM   #5
shimmy23
F15 daddymobile
shimmy23's Avatar
2350
Drives: GS X5
^ does that drone tho?
      01-13-2023, 05:49 PM   #6
Tcarter7777
12
Drives: BMW X6M
There is definitely some drone not bad tho in my opinion. Adding the X-pipe like I plan on doing should definitely help with drone.
shimmy232350.00
      01-13-2023, 11:30 PM   #7
9vapors
652
Drives: CB X5M
I did the same, deleted the muffler, left the resonators this time, added an xpipe. Love the sound, it doesn’t drone in M mode, but in the regular non M mode I find there is definitely some drone, but not enough to bother me. The refined sound with the X pipe makes it sound like an exotic car.
      01-14-2023, 08:17 AM   #8
Tcarter7777
12
Drives: BMW X6M
Hey when you added X pipe besides refining sound in your opinion did it seem less loud compared to just muffler delete? Im doing x pipe soon but I want it to still be loud lol
      01-14-2023, 11:34 AM   #9
9vapors
652
Drives: CB X5M
Nope, it’s still loud, just refined the note a bit, removed the raspiness.
      01-16-2023, 11:10 AM   #10
Tcarter7777
12
Drives: BMW X6M
You were right! Did the x-pipe this morning love this sound much more!!
normal start with muffler delete and x pipe
9vapors651.50
      01-16-2023, 01:03 PM   #11
9vapors
652
Drives: CB X5M
Sounds great. The M5 has it stock, not sure why we didn’t get them.
      01-21-2023, 01:24 AM   #12
MBoss_F86
MBoss_F86's Avatar
138
Drives: 2016 BMW X6M
Since there are no valves involved, does it sound the same in
economy/ sport / sport plus modes?
      01-21-2023, 12:20 PM   #13
9vapors
652
Drives: CB X5M
No, because of the rpm’s, shift points etc, it’s obviously much more tame in the other modes and tends to drone. I am hardly ever in those modes though, sometimes when passing police and it I need it at its quietest.
      01-23-2023, 12:38 AM   #14
mvrt
mvrt's Avatar
50
Drives: 2011 M3 Competition
did you get a CEL after the install because of the missing valves, or is it not a thing on this platform?
If you did, was it a bypass through coding / a simulator?
      01-23-2023, 11:04 AM   #15
Tcarter7777
12
Drives: BMW X6M
I haven’t had any CEL due to muffler delete yet I just had them unplug from valve and tuck wires. I unplugged it before muffler delete in the past as well, and rode around with valves open and didn’t have a CEL issue so I guess it’s same concept.
Appreciate 2
9vapors651.50
mvrt49.50
      01-25-2023, 04:08 AM   #16
MBoss_F86
MBoss_F86's Avatar
138
No CEL for muffler deletes. If you go catless downpipes, then you will get CEL
xbimmers
