09-29-2019, 09:46 AM | #1 |
117
Rep 448
Oil Around Drain Plug 15 M3
While changing my oil Friday I noticed there was oil around the drain plug.
Wiped it it off and continued with oil change. Decided to check this morning, on the ramps I see a little oil again around the drain bolt. Any one else experience this? Is this an indicator of a oil pan gasket going bad? Or maybe a turbo leaking? I have Geico MBI so my concern is not great but looks to need fixing. Any help would be appreciated. |
09-29-2019, 04:44 PM | #3 |
117
Rep 448
Yes, when ordering from getBmwParts you pay for a new drain bolt with crush washer. Mine is a 07/14 build with the magnesium drain pan.
Weird, I have done all the oil changes other than the free maintenance ones and this is the first I am seeing of oil around the drain plug. |
09-30-2019, 11:54 AM | #4 |
5001
Rep 6,864
I would keep an eye on it but doesnt sound like its anything to worry about at the moment. If its only around the bolt and not actually leaking onto the ground it must be an extremely small leak/seal problem.
10-01-2019, 03:51 PM | #5 |
117
Rep 448
Took it into dealer. Oil filter housing gasket and oil cooler gasket needed to be replaced. Price close to $2400 parts and labor. Insane.
Geico MBI took care of it. |
10-04-2019, 06:51 AM | #6 |
///M SubDriver
1837
Rep 2,784
Drives: 2017 M3, 2020 X7 40i
What was the mileage on your car? I am curious to know when I need to watch out for when the OFHG will start to fail on the S55.
Many BMW engines share the same basic oil filter housing design and it is not uncommon for that gasket to start leaking at the 60-70k mile mark (sometimes even sooner). I just DIY'ed that job on my son's 128i with N51 engine.
///M3 COMPETITION 6MT - 2017 F80 Smoked Topaz Metallic
BM3 / MP-HAS / GC Camber Plates / Carbonstructure Interior X7 XDrive 40i ///M-SPORT - 2020 G07 Arctic Grey Metallic X3 XDrive 30i - 2019 G01 Mineral White (wife's) / 128i 6MT - 2009 E82 Jet Black (son's) |
10-04-2019, 02:20 PM | #7 | |
79
Rep 98
10-04-2019, 11:55 PM | #8 | |
I'm Batman!
3948
Rep 1,477
S55, 2JZ, M48.00 |
10-05-2019, 08:55 AM | #9 | |
///M SubDriver
1837
Rep 2,784
Looking at the S55, the process appears to be very similar based on the basic engine design and layout. Cost of parts will be a bit more (2 gaskets, vice just one for the N51/N52), but still easily under $50 or so. More "stuff" needs to be removed before you can actually get to the OFHG though so the job will most likely take longer depending on your experience level. I have not seen an actual DIY for the S55, but have seen some for the N55 which is very similar. Here is a Youtube video I found for the N55 after a quick search: https://www.youtube.com/watch?v=gF5VONWqM0I
Kilabyte3948.00 |
10-05-2019, 11:57 AM | #10 |
40
Rep 157
I have a tiny amount of oil dripping when I park my car overnight-2015 m3 w 45k. I have an appointment with service Wednesday. Reaaaally hoping it's just the drain plug itself.
10-07-2019, 10:50 PM | #11 |
117
Rep 448
Total parts were $192 for all the gaskets and associated o rings plus the brake parts cleaner.
I didn't see any oil around the lower half of the housing, only the resultant oil by the drain plug. Which led me to believe that it could be the oil pan. I did notice my car seemed to be burning more oil than normal. Talked to the tech and he said there was oil around the front part of the engine. But you would need to take parts off to see, so they cleaned that up as part of the repair. My car has 52,500 miles. |
10-08-2019, 06:00 AM | #12 | |
///M SubDriver
1837
Rep 2,784
https://www.bimmerworld.com/Engine/B...th-cooler.html It included the two gaskets, three new mounting bolts, two new plugs and a new pressure switch. Not sure replacing the hardware and pressure switch is absolutely necessary, but for the price (and time to do the repair) it is probably one of those good things to do while you are in there.
Kilabyte3948.00 |
10-11-2019, 11:54 AM | #13 |
117
Rep 448
Part Number Part Description Parts Total: $ 192.44
PKN55OFH N55 OIL FILTER HOUSE BM83-19-2-451-315 BMW NON-CHLOR. BRAK BM11-42-7-540-759 ASA-BOLT BM11-42-8-683-168 O-RING BM11-42-8-637-820 GASKET BM11-42-8-637-821 GASKET BM11-61-7-547-242 SET OF PROFILE GASK BM17-22-7-800-958 O-RING BM11-42-7-540-763 ASA-BOLT BM83-21-2-449-994 BMW GROUP LL-01 FE BM82-14-1-467-704 ANTIFREEZE BM17-22-8-604-345 O-RING |
