Coby Wheel
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > Mechanical Maintenance: Break-in | Oil & Fluids | Servicing | TSB | Recalls
      09-16-2019, 05:18 PM   #1
yasavguy
40
Drives: '17 BMW X5M
front license plate w/o drilling
Is it possible to install a front license plate without drilling into the bumper?
What is the best way to do that?
      09-16-2019, 05:33 PM   #2
coldfish
76
Drives: Alpine White 2018 M3 F80
STO N SHO
Google this.
      09-17-2019, 01:34 AM   #3
hellokitty
hellokitty's Avatar
2896
Drives: '17 M3 ZCP DCT
http://www.usmillworks.com/bmw_front..._tow_hook.html
      09-17-2019, 10:24 AM   #4
yasavguy
40
Drives: '17 BMW X5M
I do not want my LP to be on the side like that. I want it to be in the center of my bumper. Any good way to do it?
      09-17-2019, 10:45 AM   #5
coldfish
76
Told you to check STO N SHO up.....
      09-19-2019, 01:28 PM   #6
NVA2L8-II
20
Drives: F80 / M3
Sto n sho
      09-20-2019, 12:07 AM   #7
StanislavK82
86
Drives: 2016 BMW M3
+1 on the sto n sho. The installation instructions say to use the adhesive tape and a screw, but mine is holding well with the supplied tape only. You can screw it in if you'd like, the location of the hole wouldn't be easily visible.
      09-20-2019, 01:11 AM   #8
CachacoF80
911
Drives: San Marino Blue F80 - ZCP 6MT
Dual lock 3M. If you car is dark, it's the best solution.
      09-21-2019, 03:01 PM   #9
andrei.m4
113
Drives: bmw f82
I use double tape from Tesa, i used for 2 plates around 5 meters of tape, is cheap and strong, 10 dollars
      09-21-2019, 03:54 PM   #10
MrAvus
12
Drives: F80
STO-n-SHO still requires one hole to be drilled for proper installation...but the hole is drilled upwards from underneath the bumper. No one will ever know it's there.
      11-10-2019, 08:40 AM   #11
PhatLyfe
PhatLyfe's Avatar
985
Drives: 2018 F83 AW/SO ZCP
Originally Posted by hellokitty View Post
I have this and it's a bad design, I've tried every angle and the front sensors keep on going off., the design fault of the player hold needs to move 1/2 inch to the right away from the right middle sensor. Plots the pin they provide get lost often, poor customer service also. I don't recommend them at all.
      11-11-2019, 12:21 AM   #12
hellokitty
hellokitty's Avatar
2896
Strange. Mine fits perfectly... I also have pdc and no issues with the sensors being triggered.
2017 F80 M3 ZCP / AA GESI DPs / Akrapovic Evo / BBS FI-R 19" / Bend Calibration ECUTEK Flex Fuel | Bilstein B16 DDC + CS EDC / BMC Filters / BMS OCC / CSF HE / ESS CP / Nitto NT555R2 / PD Crank Hub / SPL Suspension / Uniden R7 / Wagner Top Mount IC
2021 Mini GP3 / BMC Filters / BM3 / Cary Jordan E30 / Wagner IC / Remus Race
      11-11-2019, 05:32 AM   #13
Psychotic Mouse
Psychotic Mouse's Avatar
South Africa
88
Drives: Sakhir Orange M3
I stripped my bumper off and clued 5 x Neodymiun (rate earth) magnets behind the bumper. (20mm Diameter 5mm thick)
I then glued 5 of those to a number plate bracket, stuck some soft rubber pads to them so that they don’t scratch the paintwork.
This way I can remove the plate whenever I want and just pop it back on.
If you do the above then the best is to mount magnets onto the Numberplate first. The line it up on the bumper using the magnets on the inside. Once level while the magnets are in place, then apply the clue to the ones in the bumper. If that makes sense.
      11-16-2019, 10:17 PM   #14
marvinp
274
Drives: '18 M3, '09 135i
Carbonio is great: https://carbonio.com/collections/bmw...se-plate-mount
      11-17-2019, 03:46 PM   #15
HazChem
HazChem's Avatar
262
Drives: 2019 BSM M2C
+1 on Carbonio. I’ve had it since I bought my car and it is great. Easy on and off.
      11-25-2019, 09:01 PM   #16
RCF80M3
Drives: F80 M3
https://www.painlessproducts.com
      11-27-2019, 09:15 PM   #17
aerostar
746
Drives: 2018 F80
You're installing them wrong or you bought the wrong version. There's one for sensors and one for no sensors.
      11-29-2019, 04:14 PM   #18
PhatLyfe
PhatLyfe's Avatar
985
I've purchased the one with the sensors and I'll have to see if I can reinstall this at an angle and see if that make a difference
      12-05-2019, 09:36 PM   #19
SD ///M4
///Multiple
SD ///M4's Avatar
2992
Drives: M4 Coupe | M3 | Z4M Roadster
Originally Posted by marvinp View Post
I also have the Carbonio, although I only plan to use it if I should get a no-front-plate fix-it ticket here in CA. Put it on, get the ticket signed off, and then easily remove it.
The Coupe: 2016 M4 | Sakhir Orange | Black Full Merino Leather | CF Trim | M-DCT | More | ED 5/13/16
The Sedan: 2018 M3 | San Marino Blue | Black Full Merino Leather | CF Trim | M-DCT | ZCP | ED 7/18/18
The Roadster: 2006 Z4 | Interlagos Blue | Black Extended Nappa Leather | Carbon Leather Trim | Purchased 7/19/12
      12-09-2019, 07:36 PM   #20
Crazy Penguin
117
Drives: Jet Black
That holder is shit. Look at its placement.
Sto n show is the only one you guys should buy.
It doesnt require any drilling. Thats optional.
18BMWX5M569.00
      12-31-2019, 04:20 PM   #21
fknlo
89
Drives: s2k, f80, Prius
I went with the carbonio. It's working fine so far. I didn't want to drill for the sto n sho and I don't trust double sided tape alone to keep the plate on.
f80post
