BMW X5 and X6 Forum 2014-Current
      09-11-2019, 06:13 AM   #1
va335i
22
Drives: G07 X7 M50i
Band and Olufsen carplay is weak
I have very noticeable difference in sound (power, loudness) between the Sirus XM or Radio vs. using bluetooth apple carplay. I just wanted to check and see if anyone else notices a difference. Not sure if it is the Phone on the B&O.
I did not have this issue in my last X5 with Harmon. At first I was really worried the B&O was alot weaker than the HK I had in my 2012. Then I happened turn to Sirus radio the other day and the system is noticeably much more powerful with Sirus or regular radio.
So anyone else experience this? Thanks
2007 335i sport sedan fully loaded, fmc, downpipes, PTF custom tune. Sold
2012 X5 50i fully loaded. ESS TUNE
2017 X5 M Donington Grey
      09-11-2019, 09:23 AM   #2
pennsiveguy
pennsiveguy's Avatar
3552
Drives: F15 xDrive50i M-sport
I have the same issue in my F15 with the B&O. Ditto for bluetooth audio from my phone and screen mirroring. Maybe since they don't have control of the device's output level, they err on the side of caution when setting the gain level for such things...? Just a guess.
2017 F15 xDrive50i M Sport | Superformance GT40 Roush 511 IR FE
      09-11-2019, 01:49 PM   #3
daytonaviolet
OEM CSL Whore
daytonaviolet's Avatar
Philippines
1250
Drives: 2017 F85 X5M
have you tried turning off the screen mirroring and only use the carplay option?
      09-11-2019, 02:03 PM   #4
va335i
22
Drives: G07 X7 M50i
Not that I know of. Do you mean if I use carplay, but have the BMW menu screen up? Thanks
      09-11-2019, 02:20 PM   #5
daytonaviolet
OEM CSL Whore
Philippines
1250
Do you have an iphone and using the mirror option?
      09-11-2019, 02:34 PM   #6
va335i
22
Drives: G07 X7 M50i
Sorry, not trying to seem dumb.
I connect my Iphone to car via Carplay. It ask for me to turn on wifi if I have it turned off when I get in to connect.
      09-11-2019, 02:40 PM   #7
daytonaviolet
OEM CSL Whore
Philippines
1250
in carplay mode, you can also toggle from FM, Sirus and music from your iphone. so at this point, your hearing volume issues ? in my car, the volume sounds the same as i toggle through them.
      09-11-2019, 02:47 PM   #8
va335i
22
Drives: G07 X7 M50i
FM and sirus are much louder than Pandora/prime music when I toggle while keeping Carplay on the screen. I have made sure that system says Bang and Olufsen and not Speach mode as well.
      09-11-2019, 04:06 PM   #9
daytonaviolet
OEM CSL Whore
Philippines
1250
i'm guessing pandora/prime is coming from your iphone while in carplay mode wifi/bt mode. strange i'm not seeing these volume issues on my car.
      09-11-2019, 04:47 PM   #10
Mitch P.
12
Drives: '17x5M
Have you tried to raise volume up on your iPhone while in this mode?
Mitchell Phillipi, CCA#189329
'01540ias, '17x5M
past:'96Dinan3, '11M3 ZCP, '11X5d, '15X5 5.0, '07AMdB9
      09-11-2019, 04:54 PM   #11
daytonaviolet
OEM CSL Whore
Philippines
1250
this is usually the case when connected outside of carplay. but in carplay mode, the volume button has no effect on my car.
      09-12-2019, 06:33 AM   #12
va335i
22
Drives: G07 X7 M50i
What model of Iphone do you have? Yours not having this issue leads me to believe that the problem is my Phone. Thanks
      09-12-2019, 07:25 AM   #13
pachieh
245
Drives: '17 X5M
I have the same problem in my 2017, have an iPhone X (but will have an 11 pro soon). It's annoying, but it wasn't always like this. It used to play a lot louder. My guess is that a software update either on iDrive or iOS some point in the last year did it...
My bigger annoyance is that Bluetooth connections for me at least can be intermittent. It'll hiccup and then keep playing music. It's not a LTE issue. Plus Bluetooth compresses music quality more which negates having a kickass B&O system. I wish BMW would enable CarPlay via USB like my wife's minivan. Sound quality is MUCH better via USB.
2017 X5M, Donnington Grey, Aragon Brown
Eisenmann Pro, Dinan Intake, BM3 Stage 1, XHP Stage 3
21" Vossen VFS-1 on Michelin PSS
      09-12-2019, 12:17 PM   #14
pennsiveguy
3552
I haven't tried that. I only use CarPlay when my GF is riding shotgun and wants to use it, which is rare. I'm on Android, so it's not applicable to me.
I can compensate for the low volume by cranking up the phone volume to its max setting. I guess having to do that is better than having a really hot gain setting and blowing an amp or speaker with a distorted or over-driven signal. I just have to remember to turn the phone volume back down when I'm done.
      09-12-2019, 12:32 PM   #15
daytonaviolet
OEM CSL Whore
Philippines
1250
Ipxs max ios 13 beta 8. Perhaps sync another phone to the car and give it a try.
      10-09-2019, 01:22 PM   #16
SmallSoldier
Drives: 2017 BMW X5M
If you are using a new phone, try going into Sounds / EQ and pick one... That solved the issues I had with a different car after changing phones.
xbimmers
