09-04-2019, 08:42 AM | #1 |
Merlin
476
Rep 730
Drives: 2012 BMW M3 6MT w/ZCP
Worth using non OEM Air Filter?
Greetings,
Sorry for likely dumb question, but is there any point in using non-OEM air filter for the S65? Are there any: confused2 performance improvements whatsoever in using aftermarket air filters? If there performance gains albeit small, what do people recommend for brands to look into? Thanks, Merlin
2012 E92 M3 ZCP | 2008 E90 335xi | 2008 E90 335i | |
09-04-2019, 09:08 AM | #2 |
1105
Rep 1,389
I use the Macht Schnell drop in with stock elbow.. Small performance benefits from using an aftermarket filter... a tad more if it's replacing a 2008/2009 filter from what I was told bc those MY are more restrictive. I plan on replacing mine every 8-10K miles just to keep it fresh since it is less filtration.. I get mine from IND. Nothing negative from my experience and can tell a small improvement in throttle response and probably it would dyno 5-8 HP better, just from what I've researched.
EDIT: Forgot to add... I definitely saw an increase in MPG of about 1-2 mpg |
09-04-2019, 09:58 AM | #3 |
102
Rep 141
While the element itself can provide minor increases in performance. The biggest contributing factor is the elbow itself for performance gains. However, sticking to just the filter element, a nice benefit is going to one that you can simply clean when needed versus paper disposable. In the long run this can be a cost savings with little difference in filtration for most drivers. Another benefit is that some filter mediums are less restrictive and also provide better fuel economy. My experience going to a performance intake with elbow replacement has been approx 1.5-2.5 MPG's. YMMV
Known brands are probably your best bet for recommendations: Macht Schnell, AfE Power, Turner, Dinan, and others.
-Kai
09-04-2019, 10:08 AM | #4 |
64
Rep 181
I put the AA Green filter in my 08 a few weeks back. The induction noise is definitely more audible now. I've also noticed a very very slight bump in power, but honestly what I like most is the added noise.
2008 E90 M3 - Sparkling Graphite Metallic / DCT / slicktop / single hump
09-04-2019, 02:48 PM | #5 |
BimmerPost Supporting Vendor
8249
Rep 18,839
Drives: BMW
Swapping the filter is will provide marginal gains over stock. A full intake system like the Macht Schnell Stage 2 intake will provide a filter and eliminates a really nasty restriction coming from the airbox - increasing airflow (and power).
For example, here's a comparison of the intake charge pipe (left) vs Macht Schnell (right). The OEM filter mounting flange (not pictured) also has this restriction, a replacement is provided with the Macht Schnell intake: The MS piece also does not have the "accordion" type bend as seen on the stock charge pipe. A less restrictive flange, larger charge pipe and high-flow filter (along with ICS scoops) all work together as a package, resulting in best hp gains - which is why the entire system is included as a kit. Hope this helps.
