      09-02-2019, 02:52 PM   #1
imported_mega
No_Country
123
Drives: various bmw's
Data logging canbus/obd2
Anyone data logging at the track?
I have a racecapture mk2 and I"m data logging canbus, obd2 and a couple analog sensors on my R53 mini.
OBD2 is too slow for most things, except nice to have like IAT, anyone else pulling canbus? If so what channels are you logging?
Hoping oil pressure is easy to get, aim dl did not have it listed but did have quite a few other channels
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
Driving e82, e72, e85, R53 Gone but not forgotten..
1974 2002, many various 3s.
      09-09-2019, 06:20 PM   #2
NinjaDog
NinjaDog's Avatar
Australia
20
Drives: BMW 135i
My MHD doesn't appear to be monitoring oil pressure.
Does the car require new sensors?
      09-09-2019, 06:24 PM   #3
imported_mega
No_Country
123
from what I found there is no pressure sensor, just an idiot light sensor that triggers at like 7psi
      09-09-2019, 06:51 PM   #4
gmx
166
Drives: VO 1M
N54 doesn't support it nor has it been patched for it. If enough people hound MHD, they'll do it. Until now, they don't really give a shit about anything except straight line performance. Took a couple posts years ago to give us waterpump control when it was already in public XDFs.
      09-09-2019, 06:58 PM   #5
NinjaDog
NinjaDog's Avatar
Australia
20
Drives: BMW 135i
Wow that sucks. How is everyone monitoring it then?
      09-09-2019, 09:30 PM   #6
gmx
166
Drives: VO 1M
Another sender/ext gauge/logger is your only option. Keep hounding MHD...
      09-10-2019, 06:35 AM   #7
imported_mega
No_Country
123
MHD cant fix it, there is no pressure sensor on the engine. It has an on/off switch that triggers at 7psi but that's it
      10-08-2019, 09:09 PM   #8
imported_mega
No_Country
123
where is everyone else tapping into the canbus? I need to log off the pt-can pair
      10-09-2019, 08:20 PM   #9
gmx
166
Drives: VO 1M
They *can* if they use a "spare" 0-5v input and N55 sensor. It's the same thread IIRC.
But everyone just wants to use ethanol and flex fuel. As I said, they only care about the masses.
      10-20-2019, 09:17 AM   #10
imported_mega
No_Country
123
anyone know the pt-can ID/offset/lengths for what I'm missing? mainly looking for wheel speed and brake pressure at the wheel so I can monitor what the DSC is doing
RPM ID 170 offset 4 length 2 signed little endian conversion raw x .25 / 1
pedal position
TPS ID 170 offset 2 length 2 unsigned little endian conversion raw x .00154 / 1
wheel_spd_fr_lf
wheel_spd_fr_rh
wheel_spd_rr_lf
wheel_spd_rr_rh
clutch_switch
Steering ID 196 offset 0 length 2 signed little endian conversion x -.04395 / 1
brake_pr_fr_lf
brake_pr_fr_rh
brake_pr_rr_lf
brake_pr_rr_rh
brake pedal pressure id 414 offset 6 length 1 unsigned little endian no conversion needed
temp_outside
oil temp ID 464 offset 1 length 1 unsigned little endian conversion x 1 /1 +-48
map
gear
1addicts
