09-02-2019, 12:01 AM | #1 | |
MAGA
39
Rep 159
Which Fuel to Run in Our Diesel's?
Ran across this post and was wondering what I should fuel up with.
I have #3 easily accessable and I have a biodiesel station that isn't too far either. Let me know your thoughts. Quote:
09-02-2019, 11:05 AM | #2 |
54
Rep 174
I ran diesels from 1993 to 2017.
Diesels need clean fuel, clean air and clean oil. They will lasts hundreds of thousands of miles if you do those three things. The surest way to spend thousands of $ is to experiment with non approved fuel. D2 is blended by region with D1 to prevent jelling. Buy fuel from a place that has a lot of turnover. Change your fuel filter annually or on miles. Did you know diesel fuel can support the growth of alge? Well actually it's the water. Here is the best lubricity adder by test, as of 2 years ago. Opti-lube https://opti-lube.com/?gclid=EAIaIQo...iAAEgK80PD_BwE |
KnudsonM339.00 |
09-02-2019, 03:28 PM | #3 | |
MAGA
39
Rep 159
The diesel near my house has this fuel, "Contains Up To 15% Biodiesel or Renewable Diesel". We live in an area where all the diesel stations have good turn over. |
09-02-2019, 03:53 PM | #4 |
482
Rep 317
Up to 5% is ok, the fuel cap says B7% is the allowed maximum limit. However in extreme circumstances you can run 15% if there’s only high biodiesel blend is available (very notorious in the northeastern states to run B20% only) for a limited amount of time (one tank limit). I was stuck in a sticky situation while visiting New Hampshire and most of the diesel pumps has B10% or greater, fortunately I filled up in Albany, New York ran to Manchester, New Hampshire and return to Albany without pumping a drop of in New Hampshire 350+ mile round trip. It’s tough to find low Biodiesel blends, Im my home state all pumps are B 5% however I’m noticing in Texas (I travel a lot there) it’s becoming more common to see pumps with B10%, another reason to delete the egr and DPF in the near/far future.
Cheche10.00 |
09-03-2019, 10:48 AM | #7 | ||
54
Rep 174
I ran it in an older diesel motor home. The problem with with ULSD is that the spec is a bit "dry". That is, lubricity is low without the sulphur. Manufacturers were slow to make the fuel pumps with durable materials. Since diesel fuel injector pump are very pricey I view it as insurance. BMW is concerned with EGR and DPF reliability. Does the BMW diesel have fuel heaters? I don't read of problems on these forums with durability. |
09-03-2019, 10:57 AM | #8 | |
54
Rep 174
09-03-2019, 05:17 PM | #9 | |
MAGA
39
Rep 159
09-04-2019, 10:24 AM | #10 | ||
54
Rep 174
09-04-2019, 04:05 PM | #11 |
Premium Monkey
50
Rep 80
I noticed several of the Exxon/Mobil stations near me are now carrying "Synergy Diesel Efficient" branded diesel:
https://www.exxon.com/en/synergy-die...ient-passenger I have been unable to find a datasheet. Does anyone know anything about it? Price doesn't seem to be any higher than any of the other stations in the area. |
09-04-2019, 04:30 PM | #12 | |
54
Rep 174
It's a detergent additive package. They also claim additional lubricity, |
09-05-2019, 10:12 AM | #14 |
54
Rep 174
https://www.msds.exxonmobil.com/IntA...;docFormat=PDF
I can't find a cetane rating. The claim is 2% increase in fuel mileage, however, it has been shown that the driver and his technique account for 20% of fuel mileage all else being equal. Exxon is doing to diesel what top tier is to gasoline. I have stopped buying fuel from no name stations, the pay at the pump apps give a discount plus it protects my credit card number. |
09-05-2019, 11:54 AM | #15 |
Premium Monkey
50
Rep 80
BTW, there is already a TopTier standard for diesel, but very few retailers participate: https://www.toptiergas.com/toptier_diesel_fuel/
Maybe ExxonMobil will pursue it now? |
09-09-2019, 03:29 PM | #17 |
ex deus machina
124
Rep 968
I run Opti-Lube summer blend so far, happy with results around 1-2mpg improvement
I also tried XPD in several tanks and saw 3-4mpg improvement, which seems really high, so maybe it was the driving or brand of fuel, or something else. I have the winter formula on standby once they weather cools down and see how that does, We have winter diesel here that’s good to about -5F but it does get below -20F very easily
Daily: G30 M550i, Bluestone, JB4, 1 step colder plugs, 6WB retrofit
Winter Beast: Audi S4 4.2L V8, Supercharger, brakes, suspension & exhaust mods Wifes': F15 M50d clone, DUDMD tune, WMI, MPBK Gone: E92 335i N54 468rwtq |
09-10-2019, 08:45 AM | #18 | |
54
Rep 174
