08-11-2019, 05:39 PM | #1 |
40
Rep 111
Oil Change Questions
I am about to replace my oil pan gasket and I'll do an oil change as well.
Where would you suggest I buy my oil/oil filter? Thanks! And I need 5w30? correct? |
08-11-2019, 08:05 PM | #2 |
5022
Rep 6,870
Your local bmw dealership will have the correct oil and filter or you can try any Walmart or auto parts store for an LL01 rated oil.
Or you could always order it online. |
08-12-2019, 12:41 AM | #4 |
264
Rep 769
Based on my research it should be anything from 0w-30, 5w-30, 0w-40 and 5w-40. Im going to try 5w-40 my next oil change because thats what Pennzoil website suggests. 0w-30 and 5w-30 are recommended because of emissions reasons from my understanding. But i dont really care about emissions and would rather keep my engine running well
08-12-2019, 09:57 AM | #5 |
1558
Rep 2,505
I just changed my own oil yesterday in my 2019 M2 with S55 engine (same as M4/M3).
Get the 5w-40 Pennzoil Euro Platinum it is BMW LL01 approved and it is better than what BMW sells at the dealer. You need 7 quarts. https://www.amazon.com/Pennzoil-Plat...NsaWNrPXRydWU=
2019 M2 Competition- October 2, 2018 ED
2011 BMW M3 Sedan Alpine White Picked up via ED 9/27/2011 & Redelivered 11/23/2011 **SOLD** |
08-12-2019, 07:36 PM | #6 | |
5022
Rep 6,870
LL01 is a specification which you can find several grades of oil ranging from 0w30 to 5w40. Just look on the back of the bottle for the oem specifications to make sure either LL01 or LL01FE is listed. If you don't want to order oem oil online I recommend Castrol 0w40 which can be found at both Walmart or amazon for around $27 for a 5qt jug and it's LL01 approved. For oil filter I would stick with oem. Just order one online if you can't go to the dealership. |
08-13-2019, 09:56 AM | #7 |
384
Rep 488
I guess this is officially already another oil thread. Who am I to stop it. +1 Castrol 0w40 LL01 is what I ended up using for a recent oil change. I would avoid the LL-01 FE variants as they are thinner/will deliver slightly more fuel efficiency at the expense of slightly reduced engine protection.
08-13-2019, 10:59 AM | #8 |
307
Rep 971
Bimmerworld seems to think you can/should go to 10w40. I'm leaning toward Redline 0w40.
https://www.bimmerworld.com/Engine/E...ilter-Kit.html |
08-13-2019, 12:35 PM | #10 |
415
Rep 689
08-13-2019, 07:37 PM | #12 | |
5022
Rep 6,870
08-14-2019, 07:26 PM | #13 |
303
Rep 587
08-14-2019, 08:30 PM | #14 | |
5022
Rep 6,870
08-14-2019, 10:40 PM | #15 |
307
Rep 971
It's a hotly debated subject. I'd never use Redline on BMW's change interval, but if you keep it fresh it's good. I've always used it in my high boost turbo engines and had good luck. Probably just habit more than merit at this point. It's not that much more expensive bought in bulk. Around $11/qt. Even see it at $38/gallon sometimes.
08-15-2019, 07:21 PM | #16 | |
5022
Rep 6,870
08-15-2019, 07:47 PM | #17 | |
186
Rep 131
Lowest I've ever seen it. |
08-16-2019, 09:14 AM | #18 |
11
Rep 17
Drives: 2015| M3 | Manual Transmission
Here is the link to MANN filters specification:
https://catalog.mann-filter.com/EU/e...00000000149024) They are the same: 11 42 7 854 445 - Original BMW Number HU 8011Z - MANN For Air Filters BMW use MAHLE filters: 13 72 7 843 283 - Original BMW Number LX 2075 - MAHLE/KNECHT 13 72 7 843 284 LX 2074 - MAHLE/KNECHT |
08-17-2019, 10:55 AM | #19 |
956
Rep 624
I'm about to change my oil as well. Got 5W-30 Castrol full synthetic. I read that's the correct oil but after reading this thread it seems like most are going with 0W-40. Is 5W-30 correct or should I get 0W-40?
08-17-2019, 11:37 AM | #20 |
5022
Rep 6,870
Re-read the thread. It's not about 5w30 or 0w40. It's about having the proper spec which is LL01 or LL01FE. There are numerous viscosities which carry these certifications. The 5w30 you have probably does not carry the approval that BMW requires because I don't think Castrol makes an LL01 5w30 any longer.
08-17-2019, 11:47 AM | #21 | |
956
Rep 624
gatorfast5021.50 |
