08-07-2019, 02:36 PM | #1 |
Rep 37
Steering light on dash
Over the past few weeks I've been getting a steering warning light and the wheel will get real tight. It is inconsistent however it is not going away. Help a brother out!
08-08-2019, 09:09 AM | #2 |
4446
Rep 7,488
Have you done any of the simple things first...like check the power steering fluid level? And do you have any upgraded steering options like IAS (integral active steering) where the rear wheels can turn along with the front wheels?
2015 F06 650ix Gran Coupe`(Moonstone/Cohiba Brown)| 2014 F15 X5 50i MSport (Space Gray/Mocha)
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. |
08-08-2019, 09:10 AM | #3 |
18
Rep 67
Had the same issue a few years back. Same intermittent light and loss of power steering. Turned out to be a bad trunk seal allowing water into the part of the trunk nearest the tail lights.... The module that controls some of the power steering functions is on the back wall of the trunk very near where the license plate is mounted... Mine had corroded electrical connections from moisture being present for quite a long term... The module and electrical connections were replaced, and having the trunk seal corrected has prevented the problem from returning... Hope that helps!
Flying Ace4984.50 |
08-08-2019, 05:03 PM | #4 |
Rep 37
Going to sound pretty stupid but for the life of me I cannot find the power steering reservoir?? Somebody told me it may have electric assist steering?
08-08-2019, 05:04 PM | #5 | |
Rep 37
08-09-2019, 03:32 PM | #6 | |
4446
Rep 7,488
You may also want to look for a lid that has CHF 11 S written on the label as the type of fluid to use (many high performance BMWs use Pentosin CHF 11 S hydraulic fluid). Below is some info from the online TIS website...taken from this page using an f13 M6 coupe (not sure which of the three M6 models you have): https://www.newtis.info/tisv2/a/en/f...ring4/EEpdEE0c
08-09-2019, 03:50 PM | #7 | |
Rep 37
