07-31-2019, 05:17 PM | #1 |
2316
Rep 12,654
Auto Talent | FULL-Race Turbo Upgrade (NO CORE REQ) | Local Special $5495 installed
Auto Talent has been working with Full Race for 15 years! We were excited to see their release of their turbo kit for the S55 Platform. This product does NOT require the use of a core exchange and is readily available for plug and play installation. New o-rings for the lines are recommended for the installation, but these are direct a direct fit and manufactured by Mitsubishi for Full-Race LLC. We are offering the turbos for $5495 installed, includes: - Full Race Turbos: $5,000 - Installation: est 8.5 hours/ $1,275 - New Hardware + Install kit $180 - Before + After Dyno: $150 value - Bootmod3 License $595 - OBD2 to Ethernet Cable Retail Value $7,020 | Potential Savings - $1,525 Optional: - Dyno Tuning via Jordan Tuned - Dyno Access This set up has only been tested with E85 so far with the following gains: Product Description from Full-Race: Full-Race’s BMW S55 twin turbos are purpose built, a stock-appearing and stock-location performance upgrade. A true plug and play bolt-on from the OEM manfuacturer, nobody can visually tell these are not OEM without measuring upon disassembly. Utilizing a larger Mar-M turbine wheel with billet compressor wheel – large airflow increases allow for strong topend gains. Manufactured with validated components from the OEM supplier MHI (Mitsubishi Turbo) – these turbos are proven during multiple 24H endurance races, each turbo is hand built and high speed balanced for maximum reliability and durability. Wastegate actuators are pre-calibrated for easy installation. Stock tunes can be utilized with all stock components. For maximum gains, a custom tune is recommended. Features: - Performance-optimized Billet compressor wheel with latest generation blade aero - A direct bolt-on replacement; all connections to the vehicle utilize OE inlet and outlet to retain factory intake plumbing and exhaust routing. - Manufactured with 100% brand-new OEM components – Not remanufactured and no core charge - Ready to install out of the box, with pre-set electronic wastegate - Step-Gap oil seal on Turbine side - Multipad Thrust Bearing Assembly - Watercooled Center Section Last edited by AutoTalent; 07-31-2019 at 05:23 PM.. |
07-31-2019, 05:58 PM | #3 |
Go Spurs Go
3921
Rep 2,877
What modifications to the car were made to achieve the power on the graph posted? Other than these turbos of course
Damn good price though , stop tempting me , my wallet has taken a beating enough lol |
07-31-2019, 06:53 PM | #4 | |
2316
Rep 12,654
I believe the dyno is based on chetrickerman's car. |
chetrickerman10442.00 pikkagtr3920.50 |
07-31-2019, 07:19 PM | #5 | |
ECUTek Master Tuner
10442
Rep 1,733
Drives: F80 M3 YMB
I made that power at 6000 ft altitude with downpipes, exhaust, intakes, and my tune
pikkagtr3920.50 |
07-31-2019, 07:22 PM | #6 |
2316
Rep 12,654
07-31-2019, 08:48 PM | #7 |
Go Spurs Go
3921
Rep 2,877
much appreciated !
AutoTalent2315.50 |
03-14-2022, 08:32 PM | #8 |
Car Enthusiast
480
Rep 1,131
03-14-2022, 08:41 PM | #9 | |
ECUTek Master Tuner
10442
Rep 1,733
Drives: F80 M3 YMB
