Go Back   6Post.com | BMW 6-Series Forum > BMW 6 Series Forum > BMW M6 Forum (F12 / F13)
      06-30-2019, 03:16 PM   #1
GostaFly
Drives: 2014 M6 CP
CEL after Dinan stage 1 install
I have a P010a Mass or Volume Air Flow "B" Circuit CEL after my Dinan Stage 1 install on my 2014 M6. I have rechecked all the connectors and mAF connections and nothing is sticking out as an issue. Anyone see anything similar? I disconnected battery for over and hour and also have cleared the codes twice and it comes right back.
Any help would be appreciated.
      07-06-2019, 10:13 AM   #2
Whipple
Whipple's Avatar
263
Drives: 2015 BMW M6 Gran Coupe
Thats a hard code you can't just disconnect the battery to remove it
I think you should contact Dinan they will let you know whats up
      07-08-2019, 10:32 PM   #3
GostaFly
Drives: 2014 M6 CP
I opened a support case with them a few days ago but they have not come back with a response. It looks when I use my Schwaben code reader that one of the MAFs isn't seeing any lb/s input data when the Dinan is connected. When it is not, it reports in fine. I have plugged and unplugged connectors and don't see any bent pins. Used connector cleaner/lubricant all to no avail. Hopefully they get back to me soon.
      07-27-2019, 05:39 AM   #4
Danilsav
Drives: 2016 BMW M6 GC Alpinweis 300
Hey GostaFly ,
Did you manage to get anything out of Dinan ?
I am currently having even worse problem with my stage 1 , ECU is causing misfires and completely killing engine.
It began when , car sat with battery flat for couple of month ( was away) , charged it and the hassle began.
Eventually I disconnected it and the issue went away ( now driving stock )
Contacted Dinan, they said that most probably ECU is dead, has to be replaced... On the other hand they might try re-flashing it, however nobody wants to bother.
What is your experience ?
6post.com
