06-17-2019, 02:59 PM | #1 |
8571
Rep 19,982
Drives: 911, Cayenne Turbo, Disco 4
Camber plates that don't add noise?
Would like to add some negative camber to the front, but my car is a daily driver and I'll do 20k+ miles a year in it, so really would like an option that's stays quiet. Anyone found anything like that?
Ground control seems to get mixed reports from searching, but more recent experience might be helpful in case that's improved.
Current: Porsche 911 991 C4S, Porsche Cayenne Turbo, Land Rover Discovery 4. Gone...G01 X3 M40i, Cayman S 987, F31 340i, Cayman GT4, F82 M4 CP, Lotus Exige V6, G20 330e, F30 330e, Boxster S 987, F31 335d, Mini Cooper SD, E89 Z4, E90 330d 320d, E60 520d, E46 330d 320d, MX5s, E30 325i
06-17-2019, 06:40 PM | #2 |
528
Rep 855
I don't think there's such a thing as all camber plates use a spherical bearing to make contact with the stock spring perch.
The only way you could get more neg camber without plates would be to add a height adjustment kit and lower the car until you get the camber you need. |
06-17-2019, 11:03 PM | #3 |
BimmerPost Supporting Vendor
1331
Rep 872
Speed & Tech Motoring
23585 Overland Drive, Unit 178 Sterling, VA 20166 (Headquarters) 23541 Pebble Run Place, Unit 140 Sterling, VA 20166 (Satellite shop) |
Tengocity8571.00 Brickologic32.00 |
06-18-2019, 07:07 AM | #4 |
31
Rep 90
I’m i the same boat. I want more camber but not the extra noise.
You can try https://www.bimmerworld.com/Suspensi...-F82-M4_2.html they add 0.5* of caster. Not sure how much camber that is. |
06-23-2019, 11:09 PM | #5 |
2896
Rep 3,728
GC plates for the last 10k miles. No noise at all.
Obviously I would service them if they did produce noise. The f80 in stock form needs more negative camber. |
