06-16-2019, 06:56 PM | #1 |
42
Rep 87
unmolested 2008 6MT SSII E90 M3 speed cloth, low miles, BE RB done
TL/DR: Selling a clean, unmolested, low option, all California E90 M3, BE rod bearings done. 2008 e90 M3 Color: Silverstone II 476xx mi All-California car No accidents Title in hand Options: Silver stone metallic Anthracite black interior Speed cloth seats Sycamore anthracite wood trim 6MT EDC Heated seats Moonroof iPod USB adapter 18” wheels with Bridgestone S-04 E90 M3 sedan floor mats Detailed photos available upon request Exterior: 8/10 - Overall in great shape, looks like new from 10 ft, especially for the mileage. If you look closely there is road rash on the front and impact areas behind the wheels. Rear bumper has some marks from the few times it was street parked to visit people. Overall the paint still has a mirror like finish as evident in the photos. Interior: 9/10 - Super clean interior. Typical wear marks on soft touch plastic such as around window switches. Steering wheel surface has typical bubbling problem. Original steering wheel was replaced but new steering wheel still had the same issue. It seems pretty common. Minimal wear on bolsters and seats. Rear seats were almost unused. Mechanical: 10/10 This car runs and handles like new. Good blackstone reports. Shifts smoothly, and clutch engages smoothly. Steering is tight and has no play. Brakes 11mm pad remaining on all brakes. The Bridgestone S-04s on the stock rims have 4mm on the rear, and 4-5mm on the front. New OEM TPMS sensor set as of 7/2019. I love this car and it was supposed to be my first and forever car, but I got bitten by the car bug, and need to make space for newer things. I'm looking for someone who would enjoy and care for this car for a long time. This car still looks and feels new and deserves a garage space. I've had some indelible memories with this car, and I'll be sad to see it go, but if I can find an enthusiast who can take care of it, I'll be glad to see it go to a new home. The E90 is an awesome car. You get so much for the price. >8k rpm redline, individually controlled throttle bodies for precise throttle response, 414 freaking horses, an engine that makes most of its torque and power near the screaming redline, terrific steering feedback that communicates the road surface and the loading experienced by the front tires on turn-in. Being the one of the last naturally aspirated V8s, and last hydraulic steering cars, this E90 is destined to become a classic some day, especially with its manual transmission. If you want a car to keep long term, you want it to be simple, and this car really strips down on the options. There's no nav hump to look dated; instead the dash is clean and timeless, with it's driver centric amber LED controls that minimize blindness when driving at night. It’s a great “no distractions” car in contrast to the gadget-laden stuff coming out today, probably the last generation of car to be designed around the driver, that is unless you venture into 6-figure car territory. This car also comes with the uncommon option of sticky speed cloth seats, which is more suited to spirited driving than slippery luxury leather. It also has a solid back seat that doesn’t fold down (i.e., no pass through) for added torsional rigidity for those who care about these things. And it also means when something is locked in the trunk, it is locked. Unless someone steals the car and sawzall through the trunk, they are not getting in there quickly. This car is mechanically perfect. It drives like new, and feels like new especially from the inside. It's not cosmetically concourse-quality perfect, having blemishes befitting a car with 47k miles, but on first impression, everyone I’ve met think this car looks brand new, and are surprised how clean it looks for an 08. If you value an owner history of OCD, mechanically sympathetic owners over cosmetic perfection (and TBH, which car at 47k miles has no blemishes or rock chips whatsoever?) this is the car for you. (The PO was so OCD he never removed the plastic wrap on the dead pedal. I took it off because plastic wrap deteriorates over time.) I think it's just the right balance of being driven enough to avoid major problems, and not having too many miles with the consequent wear and tear. I've been following the Mike Miller "old school" maintenance schedule for fluid changes. I submitted oil to Blackstone for used oil analysis on every oil change. When I decided to do the rod bearings, I went for the highest cost, premium option of BE rod bearings (I’m sure you’ve read through all the RB threads if you’re looking for a car on this forum) and bolts, and while the subframe and oil pan were out, added the BimmerWorld dipstick kit, and replaced the engine mounts with OE. The dipstick address one of the most common complaints about servicing newer cars that only have an electronic dipstick, which can take 10-20 minutes to give you an initial reading, and sometimes give you an inaccurate reading if faulty. The physical dipstick is a nice second option and also provides access to draw out oil if for some reason you wanted to do that. The new engine mounts noticeably improved shifting feel and reduced 1st gear jerkiness on throttle application and lifting i.e. in stop and go traffic. This in combination with the UCP clutch pedal mod made this car actually bearable, almost comfortable, to drive in traffic, whereas before it was a real chore. Out of OCD, I’ve kept the original RBs for you to see and frame if you’d like. I also have the original clutch pedal if for some unfathomable reason you prefer that piece of flimsy plastic to the smooth operation of the UCP. Being a 2008 has certain advantages: The flywheel was changed between 2008 and subsequent cars. The flywheel in 2008 was lighter, and produces some motorsport-like NVH, which caused a revision in 2009. All I can say is enjoy the light flywheel while you can. It revs easily, and RPMs drop like a rock when clutching in to up-shift. It’s really exciting to shift this car, makes you feel like you’re driving a racecar, but it’s got 4 doors! Also I actually prefer the look of the 2008 sedan rear compared to the bangle butt E90 LCI tail lights. Especially because this car has OE blackline tail lights. The rounded edges look more Euro and consistent with the lines of the car. Exhibit A: This car is otherwise all stock except for the cosmetic mods, and is up to date on all recall work. No tunes nor turbos nor any suspension/chassis upgrades. I bought the car at 27k miles 4 years ago and it has a complete service record. During the car’s 4 year, 20k mile tenure with me, it has mainly been used for long road trips and a long highway commute. The last year, it’s been a great backroads commuter when I want to avoid traffic, otherwise I take the Mazda 3, which TBH is a better commuter in stop and go, but the backroads take a toll on the Mazda, whereas the M3 gets some needed exercise. We drive the car with a lot of mechanical sympathy. We never rev above 4k before the oil temperature comes up to the middle of the dial and actually I try to keep it below 3k with light throttle application. People must think what’s wrong with this BMW driver accelerating more slowly than a Prius. We never take short trips with this car and avoid starting the car just to move it. If I do have to move it, I let the oil come up to temperature before shutting down to avoid fuel dilution and water condensate. We’ve never launched the car with a clutch drop, and avoid taking the car all the way up to redline but we do rev it out once in a while when warmed up since they say it’s good for the engine. Please note the E90 is not a drag racer. You can search the threads on this. The low torque at low rpms means most minivans will get a jump on you at stop lights. The E90 shines at 45 to jail mph speeds. The 6MT is not meant to be shifted instantaneously (see the threads for shifting 1-2 gear), you have to be patient and let the synchros match up to shift optimally. It makes a lot of drivetrain noises because of its motorsport DNA, which is what makes it awesome. Did you know that the hood of the E90 M3 is not steel? It isn’t magnetic and it’s lightweight. It feels like aluminum to me. The E90 also has a front end panels (bumper, fenders) made of some kind of plastic (ABS?). The PO and I have both kept the car on Californian roads so no salt, snow, or even much rain to worry about. This car has never been put through a car wash or detailed. I do it all myself. Meaning the clear coat has never been abraded with a mechanical buffer. Last time I checked at the detail shop considering getting a detail done, he said the clear coat was at full thickness. I just vacuum, wash, clay, and wax with Klasse acrylic sealant, plush sometimes multiple coats per application, and remove with a plush purple premium microfiber made in Korea (the highest quality kind). A bunch of spare parts included. Extras (original Value): Black line tail light set, originals included Llumar Pinnacle formula 1 ceramic tint 30% sides and back $400 UCP adjustable clutch pedal, original included $350 Bimmer world dipstick $230 rod bearings replaced with BE bearings and bolts $3000+ US Mill Works front plate bracket $80 BMW Velcro oil holder bag kit $5 Anker roav dashcam $99 Spare parts: BMW 10w60 oil 4.5 L Mahle oil filter kit 1 E90 Mahle air filter 2 E90 corteco cabin filter 1 CHF11S 1 bottle Transmission plugs 2 Transmission oil filter 1 Aluminum bleeder valve 1 Aluminum radiator drain plug 1 OEM brake pads, lightly used (8-9mm remaining) 1 set Touch up paint kit Notes: Rigid back seat No Nav Blackstone report every oil change Maintenance schedule following Mike Miller’s schedule Red line MTL Red line 75-140 NS diff oil BMW 10W60 oil changes Always garaged Kept on battery tender Always warmed up before hard acceleration Driven with much mechanical sympathy Avoided short trips. Mostly longer trips or commutes. Porterfield R4-S brake pads installed as a lower dust alternative to the OEMs, 11mm thickness remaining. Prefer to deal locally. Last edited by tubedreamer; 07-31-2019 at 11:44 AM.. Reason: fix grammatical errors |
06-17-2019, 08:03 AM | #3 | |
136
Rep 401
06-23-2019, 06:41 PM | #4 |
42
Rep 87
Ok SLR photos didn't come out better than iPhone photos.
see https://www.m3post.com/forums/showpo...6&postcount=59 Lots of extras included here and a very clean car. |
06-24-2019, 12:18 AM | #5 |
553
Rep 822
Your car is literally the same as mine! Mine is just a 2011. So awesome! Great price, someone is getting a gem!
Previous - '11 E90 M3 6MT Stripper Full Cloth
Current- GT3RS,MR e90 and SG E92 Comp |
07-02-2019, 01:04 PM | #12 |
42
Rep 87
I made an appointment to move the TPMS to the stock 18" wheels. Thinking of parting out the ARC-8 wheels separately to make it easier to sell.
EDIT: Actually I'm ordering a new set of TPMS for the stock 18" wheels now and having it installed over the weekend. Last edited by tubedreamer; 07-02-2019 at 03:06 PM.. |
07-02-2019, 02:57 PM | #13 |
Rep 134
07-02-2019, 03:07 PM | #14 |
42
Rep 87
07-18-2019, 07:59 AM | #19 |
never could compete with Lloyd Braun
5276
Rep 5,378
Love it! GLWS!!
2022 G80 M3 6MT | Skyscraper Gray | Kyalami Orange
2018 F87 M2 6MT | Alpine White (sold) 2016 981 Cayman 6MT | Jet Black (sold) 2015 F80 M3 DCT | Tanzanite Blue | Gold Brown (sold) 2013 E92 M3 6MT | Mineral White | Fox Red/Black (sold) |
