06-14-2019, 07:14 AM | #1 |
300
Rep 543
new (to me) M5, need to top off oil, what to use?
Heyo,
Oil level warning came on. When the dealer changed it they put in either Mobil 1 or Castrol. Am I good to just buy a quart of Castrol Edge 0W-30 (or 0W-40) and top it off, regardless of which of those two it is? Last edited by vafan13; 06-14-2019 at 09:35 AM.. |
06-14-2019, 09:46 AM | #2 |
5727
Rep 4,209
Drives: '13 F10 M5 | '15 F15 X5
Hello, yeah you can put in either one really. I would recommend knowing exactly what oil they use OR do the oil change yourself and buy some extra for top-offs. I personally use liquid moli 5w-40.
06-14-2019, 10:20 AM | #3 |
M Enthusiast
36
Rep 172
I usually buy a couple extra liters of the oil i used to change the oil (use BMW 5w-30) but i once topped off using Mobil 1 5w-30 because i wasn't going to be home for a few days and it did the trick, no issues.
06-14-2019, 10:37 AM | #4 | |
300
Rep 543
When I talked to the dealer on the phone just now they said most likely it was mobil 1 they put in it, so I'm just going to grab a quart of mobil 1 0W-40, given that's what's LL01. |
06-17-2019, 11:01 AM | #5 |
79
Rep 108
Drives: 2015 BMW M5
They likely didn't take the time to drain all the oil correctly, nor the time to fill it correctly. There is a big oil cooler on the front of the engine, right where the grill takes a big gulp for fresh air. For the price and availability, you likely will not go wrong with the M1 0w-40 Euro Formula. I think the key to protecting the bearings is in the selection of a good full synthetic 40w viscosity. (Find the one with the lowest Noack that you can.)
2015 BMW F10 M5 | Competition Package | Driving Assistance Pkg | Executive Pkg | Bang & Olufsen | 343M 2NZ wheels
Born 02.27.2015 in Dingolfing |
06-25-2019, 12:33 AM | #6 | |
38
Rep 179
I pray the tech simply didn't fill oil to correct level and it's not your oil pump |
07-02-2019, 11:09 AM | #7 |
300
Rep 543
Sorry, should have specified: there was ~2350 miles between the dealer doing the oil change and me getting the low level light. Based on what I've read about this car's oil consumption, that seems like a completely reasonable amount of time to burn through a quart. (correct me if wrong).
Rmfive1.50 |
07-02-2019, 08:22 PM | #8 | |
Licensed Drug Dealer
743
Rep 2,272
12-22-2019, 03:55 PM | #9 |
11
Rep 105
12-22-2019, 04:20 PM | #10 |
743
Rep 2,272
12-26-2019, 06:58 AM | #11 |
252
Rep 606
Drives: 2000 M5, 2001 M5, 2013 M5 6MT
I'm glad to hear you will change it yourself going forward. It's quite easy on these cars, albeit a bit messy for the filter change.
I use Mobil 1 0w-40. Been about 20,000 miles since I bought the car. I change it every 5k miles. My consumption has decreased as well. I top off 1/2 quart at a time (as measured by the OBC). I get about 3,000 miles per quart so generally I put in 1 quart and by the time it's low enough to top off again I'm ready to change the oil so I don't bother. 1 quart between changes is like heaven! haha. I'm used to my e39 M5 that averages 1 quart every 1,000 miles like clockwork for the past 295,000 miles. |
