BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > M3 (E90 / E92 / E93) > Regional Forums > Australia
      06-12-2019, 09:40 PM   #1
RiCoda
Drives: Shopping for a E92 M3
GPS Upgrade ?
Hi all
I'm the proud new owner of a 09 e92 m3 and during the drive home with it, I noticed the gps didn't show a lot of the new roads, how do i go about upgrading it to the latest maps and is it expensive
cheers Dave
      06-12-2019, 09:48 PM   #2
ItsGary
ItsGary's Avatar
1458
Drives: 2009 E90 M3
https://f30.bimmerpost.com/forums/sh....php?t=1456836
You can generate the code for the maps yourself.
As per getting the map data for Australia,
https://cartechnology.co.uk/showthread.php?tid=31935
torrent file is on there
'09 ///M3 Sedan - Jerez Black/Fox Red Ext.
'09 335i Coupe - Alpine White/Black - SOLD
      06-13-2019, 01:49 AM   #3
RiCoda
Thanks ItsGary, from the comments it looks like that torrent isn't available anymore ... and they want $20 to join the forum on the off chance that it is available
      06-13-2019, 02:26 AM   #4
eriktufa
3r1k
eriktufa's Avatar
Australia
30
Drives: 2008 MY08 BMW E92 335i
Here you go
https://drive.google.com/drive/folde...ZGRmbjWA9nrYWh
12.836 @ 109.75mph (Cobb - Accessport & VRSF DP)
Appreciate 2
RiCoda0.00
ItsGary1457.50
      06-13-2019, 04:07 AM   #5
RiCoda
Originally Posted by eriktufa View Post
Thanks Mate, much appreciated
      06-13-2019, 06:14 PM   #6
Ingenio
Ingenio's Avatar
Australia
180
Drives: 2008 Space Grey E92 M3 (6MT)
And how do you generate your own activation key? :
      06-13-2019, 06:18 PM   #7
ItsGary
ItsGary's Avatar
1458
Drives: 2009 E90 M3
Originally Posted by Ingenio View Post
And how do you generate your own key? :
instructions on the google drive link
      06-13-2019, 09:57 PM   #8
Fezza
Fezza's Avatar
Australia
149
Drives: '11 Japan Red E92 M3
https://www.e90post.com/forums/showp...3&postcount=13
      06-16-2019, 12:44 AM   #9
Ingenio
Ingenio's Avatar
Australia
180
Sounds like I need to have some of the hardcore software tools to make a key yeah?
      06-16-2019, 05:46 AM   #10
Fezza
Fezza's Avatar
Australia
149
No just a USB stick and files in the link above
      06-16-2019, 05:57 AM   #11
Ingenio
Ingenio's Avatar
Australia
180
Ok.... I'll give it go but I still don't understand how I get the key that the CIC will ask for when I try to update the maps..?
      06-16-2019, 07:24 AM   #12
Fezza
Fezza's Avatar
Australia
149
It's in the instructions when you download the files. It's got a script so when you insert the USB into the glove box, it'll run the script and get the code from your CIC then you open it in notepad and your code will be in it.
      06-16-2019, 09:07 AM   #13
Ingenio
Ingenio's Avatar
Australia
180
Really??? Sounds cool... Do you know the filename of the script?
      06-17-2019, 02:22 AM   #14
RiCoda
I got the 1b.hex file off the car and loaded it in the BMW_CIC_FSC_Generator v1.9 by Jagaer and none of the codes are accepted by the car (tried different, settings to get different codes) any idea what i'm doing wrong?
      06-17-2019, 07:25 AM   #15
Fezza
Fezza's Avatar
Australia
149
no idea, it worked the first time for me. just had to select the right map for the generator and entered the code and it worked. i used the map that was linked in the e90 post above.
I'd go through the whole e90 post I linked above. What year is your car? I read "CIC High with a build date prior to 03/2010 requires a firmware update." so that may be your issue. if so, the usb method won't work other option is through the enet cable.
      06-18-2019, 05:29 PM   #16
RiCoda
mines 2009 i went to bmw.com to see if there was an update, and according to my Vin it's up to date
m3post
