BMW X5 and X6 Forum 2014-Current
      05-10-2019, 01:40 PM   #1
MizikeTSK
144
Drives: 2015 XDrive 50i MSport
H&R Sport Spring (Non VTF) and Bilstein B6 shocks
Forgive me if this has been discussed already but is there anyone out there running H&R's and Bilstein B6? I'm curious to know if that will get rid of the bouncy/harsh ride. Most i found was peeps still using them with stock shocks. And no I will not be going the KW route as a sure cure all.
2015 F15 XDrive 50i MSport
      05-12-2019, 01:39 PM   #2
Maverik259
Maverik259's Avatar
4140
Drives: F90 M5 / F15 50i
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
Shocks won't stop the harshness. Swap em for eibach or rebranded acs.
'07 Yamaha R1 (sold)
'06 C55 AMG (sold)
‘?20 M5, MP Carbon Pro Spoiler, MP Carbon Diffuser, MP Black grille and gills, MP Carbon Mirrors, CF side sills, 789M w/ Ti studs, eventuri, Dinan X pipe
'14 X5 50i (wife’s now)
      05-13-2019, 11:08 AM   #3
M302_imola
M302_imola's Avatar
843
Drives: '15 X5 35i Xdrive Mineral Whit
Appreciate the insight. Does the ACS offer more of a drop than the Eibach's?
      05-13-2019, 05:16 PM   #4
Maverik259
Maverik259's Avatar
4140
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
No....they're the same springs lol
'06 C55 AMG (sold)
      05-13-2019, 05:23 PM   #5
MizikeTSK
144
Thanks! I also got this info from Bilstein. If folks wanted to replace their OEM shocks with aftermarket. While the B6 has minimal difference when collapsed, the rear are close to .5" lower than OEM.
B4 OE front –
22.20 extended and 16.26 collapsed
B6 Performance front –
22.30 extended and 16.24 collapsed
B4 OE rear –
20.75 extended and 14.78 collapsed
B6 Performance rear –
20.77 extended and 14.31 collapsed
      05-14-2019, 06:38 PM   #6
mikew2069
mikew2069's Avatar
413
Drives: F30 335i MSport
I personally think the B6 will pair well with the H&R springs. I tried to go this route but gave up after I waited for months on the B6 back order. Go for it and report back!
2013 F30 335i ///M-Sport
Forgestar/Challenge/BMS JB4
Wagner/Evo Race/M-Performance
2016 F15 50i ///M-Sport
BM3/H&R/Borla
      05-14-2019, 07:48 PM   #7
TOPEC
<3 Flat Four
217
Drives: 335is LM Blue
B6 is meant for aftermarket lowering springs thus the slightly shorter length, not sure y the fronts arent any shorter than the B4s.
2011 335is Le Mans Blue
2016 X5 xdrive 35i Alpine White
      05-14-2019, 10:15 PM   #8
yewlock
yewlock's Avatar
698
Drives: X5
It is still back order on tirerack.
      05-15-2019, 06:38 AM   #9
1norseman
398
Drives: X5 50i
I contacted Bilstein, to see if they could answer the question of what the difference is between stock and B6's, but they didn't have anything truly helpful to say.
Below is a part of the reply I received:
We cannot comment/compare on a product we don’t manufacture.
The B6 units are a high performance OEM replacement unit. Tuned for comfort and control
Kinda disappointing that they expect one to buy into their line of shocks, despite not being able to tell us any good reasons in regards to why one should consider using their B6's over stock.
Kind of put me off wanting to buy from them!
I'm sure their R&D department has compared the OEM shocks with their B6's, and they could create a better description of what makes their shocks different/better than OEM according to them.
Considering Bilstein is part of ThyssenKrupp, maybe they are too big of a company to care...
Anyway, considering the Bilstein rep not being able to give me a good reason to why I should update, and the OEM's having the possibility to last a few more years, I'm in no rush to update, until I can get better data. (unless I decide to switch to KW V3's)
      05-15-2019, 10:06 AM   #10
unluky
unluky's Avatar
7528
Drives: 04 z4 3.0 Sport & 15 X5 35i XD
I went with a H&R / Bilstein setup on my Z4 - not even close to the same platform, but I wanted something between OEM and teeth jarring tight - this nailed it. Big bumps are a little jarring due to the limited movement needed to keep from bottoming out, but the travel and stiffness on normal roads is perfect. Tight and in control on the corners, but not rough when cruising.
2015 X5 XDrive 35i - 2004 Z4 3.0 Sport
      05-15-2019, 11:34 AM   #11
MizikeTSK
144
Was told from Bilstein that they shoud be available late this Summer
See above
Maybe the question to ask was the comparison the the B4 (OE replacement per their site) to the B6. Bilstein is just down the street from where I live, maybe I'll go and pay a visit to see if I can find a better answer for ya.
1norseman398.00
      05-15-2019, 12:50 PM   #12
MizikeTSK
144
My response from Bilstein when comparing the B4 to B6:
Hello,
B4 is a twin tube unit that is most like the OE dampers from the chassis manufacturer. B6 is a monotube damper tuned for more spirited handling, really favors the enthusiast that want to “feel” the road and better overall control.
Coils we would recommend are the H&R or Eibach.
1norseman398.00
      10-08-2019, 11:07 AM   #13
MJRPA
29
Drives: BMW X5
Hello,
B4 is a twin tube unit that is most like the OE dampers from the chassis manufacturer. B6 is a monotube damper tuned for more spirited handling, really favors the enthusiast that want to "feel" the road and better overall control.
I'm wondering how the B6's would run on the OEM springs in case I go back to stock to sell car in future. I have rear air suspension so just trying to address my front suspension issue. I was told my the person that installed my H&R VTFs that my right front strut is blown causing the car to sit lower on the right side. Hoping that's the real issue. So if I'm having to change struts, going for the B6's since they seem popular on the forums. Hoping that will solve my issue. Any other ideas what could have my front right side sitting lower? The coilovers are adjusted exactly the same. I saw car lifted with mechanic
      10-08-2019, 01:11 PM   #14
menelaos
menelaos's Avatar
1226
Drives: 2015 BMW X5 F15
I have them on order, currently waiting since 8/7. Was told they're on the boat to USA recently.
Not sure if these are meant for rear air-suspension vehicles.
I asked sales rep and they confirmed that the set up has to be B6 all around for their I impact to be "felt". Hope I got correct info!
MJRPA28.50
      10-08-2019, 02:57 PM   #15
1norseman
398
Drives: X5 50i
Awesome! Hope they will show up soon!
Looking forward to see a review.
My understanding is that they are the same for rear air as for rear springs, but don't quote me on that.
Since I'm too lazy to search do you have lowering springs or stock springs?
Thnx!
      10-08-2019, 03:34 PM   #16
menelaos
menelaos's Avatar
1226
Thnx!
I got Eibach, which should pair well.
Appears that the fronts have identical part #s and the rears have separate ones. Don't ask me why!
At this point, I will keep the order live, but if they extend the wait, that'll mean they lied to me....unless the boat that brings them across the Atlantic sank of something!
1norseman398.00
      10-08-2019, 09:10 PM   #17
r33_RGSport
r33_RGSport's Avatar
12971
Drives: G09 XM, G05 X5 40, 991.2 T
Thnx!
Here is the clarification on the part numbers.
Front shocks are interchangeable between both sides.
While the rear, they are technically interchangeable, but just because of the brake line bracket, it has to be 2 different part number.
The orientation of brake line bracket is mirror between left and right side.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com
PM for Everyday DEALS!!
MSS • iSweep • RaceChip • Sterckenn • AutoTecknic • Akrapovic • Vossen Wheels • Eventuri
Active Autowerke • KW • H&R • Ohlins • Remus • and more...
Appreciate 3
menelaos1226.00
1norseman398.00
MJRPA28.50
      10-09-2019, 06:35 AM   #18
menelaos
menelaos's Avatar
1226
Thank you sir!
If I did not have a daughter coming, I'd be visiting LA to have you install it, plus see a couple of CA friends!
r33_RGSport12971.00
xbimmers
