05-04-2019, 07:32 PM | #1 |
1692
Rep 685
Tired of This Car Already
Update on my 08 Z4 3.0si coupe. I've been having a lurching feeling under 3k rpms, bouncy rpms on start up and sometimes the car doesn't want to up shift 4th to 5th. Shifts in manual mode fine but still has the lurch. Drives fine if I keep it under 3k the whole time but as soon as it goes over, game on it's been triggered for once I go back under 3k rpms.
I took the car to the bmw shop and it had no codes. They recommended a trans flush, filter, pan, and seals, also did a diff fluid change. $900 later still broken. So I thought maybe plugs and coils, changed them, still broken. Maybe it's the vanos solenoids, cleaned them, still no dice. Ran injector cleaner, no help. Checked the hose clamps and for breaks in the intake with no issues found. Please, any advice at all would be a huge help! At this point I'm pretty ticked at myself for buying this turd. |
05-04-2019, 09:04 PM | #2 |
Down Under!!
1621
Rep 4,294
Checked fuel trims/px?
Stock tune? If not, I'd look at going to a stock tune and seeing what's what. Checked the MAF? Suprised there are no codes, esp when it's not shifting 4 to 5.. |
05-04-2019, 09:17 PM | #3 |
77
Rep 177
A little while back, I had the MAF changed because previous owner used an oil filter and that "supposedly" destroyed the MAF. One of my throttle position sensors were out as well.
When the problem happened I couldn't rev the engine past 3k without a lot of bucking and never got a check engine light either. I know you have a 3.0si, but I hope that this helps. |
05-04-2019, 09:32 PM | #4 |
1692
Rep 685
The car is totally stock. Almost thinking I should take it to Bmw to have them reprogram everything or just buy an Ess ecu tune. The shop checked everything an nothing was out of line. Thank you for the reply!
05-04-2019, 09:36 PM | #5 | |
1692
Rep 685
The previous owner had it in to the same shop for a cam shaft position sensor which caused a check light. Car runs great over 3k. But if you do run it over 3k it sets something into motion that when you come back down below 3k it has issues. It's either drive hard 100% or below 3k 100% of the time. Drove 160 miles today with no issues until I had to pull out fast and went above 3k. Cruising after 3k sucks so had to drive it like it's hot the rest of the drive. I will check the Maf. Thanks for your reply! |
05-04-2019, 10:13 PM | #7 |
1692
Rep 685
05-04-2019, 11:36 PM | #8 |
2286
Rep 12,565
Drives: Z4 M, X5, GX460
You should hit up the N52 forum on e90post, a lot of good info there.
05-05-2019, 08:18 AM | #10 |
1692
Rep 685
05-05-2019, 09:12 AM | #11 |
1692
Rep 685
Well unplugged the MAF, seemed to make a very slight difference at start up and triggered a cel almost instantly. Drove a short distance to see if there was a difference to no avail. Back to square one and another possibility off the list.
05-05-2019, 09:18 AM | #12 |
17315
Rep 18,737
Try running it with the MAF unplugged (it will trigger the SES light). The stored engine maps should make it run better, which will let you know if the intake system is operating to spec. Also, I'd have a smoke test done to see if there is a vacuum leak somewhere.
When you say the shop didn't find any codes, did they check the car with a BMW scan tool or just OBD2? Any issue like you have needs a scan tool that records the engine running parameters to find out how all the systems are operating. It sounds like the fuel injection system is running lean or rich somewhere in the RPM range.
05-05-2019, 09:28 AM | #13 | |
1692
Rep 685
What do you all think about taking it to BMW for a total re-programming? |
05-05-2019, 10:35 AM | #14 | |
17315
Rep 18,737
It almost sounds like a Valvetronic problem.
05-05-2019, 01:34 PM | #15 | |
1692
Rep 685
Unfortunately I disconnected the battery as the first step. Even changed it just in case something was wrong with it. Valvetronic is how I've been leaning too. Thanks for the reply! |
05-05-2019, 02:24 PM | #16 |
851
Rep 4,057
Has the car been exhibiting this particular problem since you got it or is a new issue?
My first thought Is that its either bad gas, dirty fuel filter, dirty air filter or dirty spark plugs. My 3.0si (2006 that I’ve owned since 2009) is also an automatic and it’s never done this. |
05-05-2019, 04:29 PM | #17 |
your average JAMF
3101
Rep 4,094
Drives: '21 M2 Comp, '19 Golf R
I would find a solid local indy BMW mechanic and take it there for diagnosis. BIMRS is a solid organization and will help you find a good shop locally...
https://www.bimrs.org
'21 M2 Comp
'19 Golf R |
05-05-2019, 08:11 PM | #18 | |
1692
Rep 685
05-05-2019, 08:13 PM | #19 | |
1692
Rep 685
05-06-2019, 05:34 AM | #20 |
17315
Rep 18,737
Just worth a shot, but have you pulled the connector to the Eccentric Shaft Sensor (ESS) to check for oil contamination?
05-06-2019, 06:53 AM | #21 |
1692
Rep 685
05-06-2019, 10:02 AM | #22 |
Master Wagon Builder
409
Rep 877
See if you can datalog the throttle body angle. The lurching you're talking about is usually a result of tb plates moving to try and compensate for a vacuum leak somewhere, or maybe even a faulty TB.
I wish cars would still have tb cables |
