BMW X5 and X6 Forum 2014-Current
      04-30-2019, 09:58 AM   #1
5HOUT
29
Drives: BMW 2018 X5 50i
Hey y'all. '18 50i. Every time I go through the car wash, the dryer blowers open the fuel door. Sometimes aggressively and it slams shut. Other times I need to close it myself. I've tried locking from the inside door and from the key fob (with me inside). The fuel door does lock with the normal park and lock routine. Suggestions? Thanks
      04-30-2019, 10:41 AM   #2
TOPEC
<3 Flat Four
217
Drives: 335is LM Blue
mine does the same thing, gets blown open from drive through car washes. i believe it only locks when the vehicle is off.
2011 335is Le Mans Blue
2016 X5 xdrive 35i Alpine White
      05-02-2019, 10:30 AM   #3
Qsilver7
Qsilver7's Avatar
4448
Drives: F06 650ix GC / F15 X5 50i
Interesting...all the BMWs I've owned, the fuel door was under some type of tension from a spring/clip designed into the fuel door flap hinge. Is your flap "loose" or does it still have tension when trying to open it?
My f06 is the 1st of my BMWs where the fuel flap operates slightly different...it requires pressing down on the left side, and it pops the flap open. All the previous models you'd press on the right side of the flap to open it.
{e53 X5 - press on the right side}
{e38/e39 - press on the right side}
{f06 6GC - press on the left side}
The central locking system only locks the fuel filler flap when you use the remote fob or the driver's exterior door lock cylinder. Using the central locking button inside the car doesn't lock the fuel filler door. This is to allow a fuel attendant (in states or countries that still have them) to access and refuel your vehicle while you and your occupants can remain safe & secure inside the vehicle.
2015 F06 650ix Gran Coupe`(Moonstone/Cohiba Brown)| 2014 F15 X5 50i MSport (Space Gray/Mocha)
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral.
      05-05-2019, 02:58 AM   #4
geedup35
216
Drives: 14 X5 50i - DHP
Mostly useless video to start off with, but this kid's first hack addresses the fuel door by adding a small magnet to the inside of the door.
It's odd the there is no actual latch holding it closed when the car is unlocked with ours.
      05-05-2019, 07:37 PM   #5
5HOUT
29
Thanks for the magnet idea in the video, unfortunately the fuel door is aluminum.
xbimmers
