BMW X5 and X6 Forum 2014-Current
      04-25-2019, 05:05 PM   #1
ask499
Drives: 2018 x5 5.0 saphire black
PLEASE HELP! ECS Spacers causing vibration
Hey all,
I have a pair of 15mm spacers in the front and a pair of 20mm in the back. The look of the car is fantastic with the 20 inch wheels. The one problem I am having is I feel a vibration in my steering wheel and when I hit acceleration for take off the entire front end starts to vibrate and even felt in the passenger side.
Any suggestions as what can be wrong?
these are the spacers below
https://www.ecstuning.com/b-ecs-part...003990ecs03kt/
https://www.ecstuning.com/b-ecs-part...003990ecs04kt/
      04-25-2019, 05:18 PM   #2
Maverik259
Maverik259's Avatar
4140
Drives: F90 M5 / F15 50i
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
Originally Posted by ask499 View Post
Hey all,
Check the torque on the bolts. Did you install extended bolts? May need to send em back. Try and narrow down which ones are doing it. You sure it's the spacers?
'07 Yamaha R1 (sold)
'06 C55 AMG (sold)
‘?20 M5, MP Carbon Pro Spoiler, MP Carbon Diffuser, MP Black grille and gills, MP Carbon Mirrors, CF side sills, 789M w/ Ti studs, eventuri, Dinan X pipe
'14 X5 50i (wife’s now)
      04-25-2019, 05:29 PM   #3
ask499
Yes they came with the extended bolts. I hand screwed in the bolts and then torqued to 90. What is the correct torque amount you guys suggest?
are the lugs what can be the only concern?
      04-25-2019, 05:48 PM   #4
Maverik259
Maverik259's Avatar
4140
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
Ya unless they're not balanced. Then that would require you to get them replaced. But take em off and see if it still does it.
'06 C55 AMG (sold)
      04-25-2019, 06:08 PM   #5
ask499
Took them off today and the car rides so much better..... IDK what to do cause I miss the look already :-(
      04-25-2019, 06:44 PM   #6
Maverik259
Maverik259's Avatar
4140
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
Tell ECS and have em ship you a new set....
'06 C55 AMG (sold)
      04-25-2019, 06:51 PM   #7
sj22
197
Drives: 14 F15 50I
Hey all,
Are they hub centric? get a new set and try and eliminate the issue.
I have H&R spacers and absolutely no issues.
      04-25-2019, 10:30 PM   #8
r33_RGSport
r33_RGSport's Avatar
12971
Drives: G09 XM, G05 X5 40, 991.2 T
That's why I only sell H&R.
Got a few companies offering me their product or even private labeling, but I don't trust their quality and I don't want to risk you guys and my business.
Making a spacer is not hard.
Finding a good source of material are hard these days.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com
PM for Everyday DEALS!!
MSS • iSweep • RaceChip • Sterckenn • AutoTecknic • Akrapovic • Vossen Wheels • Eventuri
Active Autowerke • KW • H&R • Ohlins • Remus • and more...
Appreciate 7
maDjzo861.50
1norseman398.00
alphaod1149.50
mrod81207.50
HJ478.00
      04-26-2019, 04:31 AM   #9
Mega-Ken
77
Drives: BMW 88 M3, BMW 2015 X6
Quality parts from a reputable vendor and thats how you run a business.
Appreciate 3
r33_RGSport12971.00
alphaod1149.50
      04-26-2019, 09:43 AM   #10
alphaod
Mmmmm…
alphaod's Avatar
1150
Drives: F15
Well the inside of the wheel rim and the rotor hub are both rough and together they fit together fine. Assuming the face of the rotor hubs are probably also kind of rusty, I would suggest cleaning the mating surfaces (both rotor side and rim side) then try again. First start with a rust remover on a rag, even a wire brush on the rotor side. The anodized finish of those spacers you posted wouldn't sit very well on a rough surface perhaps being just a little unevenly sitting can be a problem. Cleaning it would let it sit much closer. I'm pretty sure ECS would want you to do this before letting you exchange it (they have a reputation they need to hold as well).
2015 BMW X5 xDrive50i
BMW CCA 509766
r33_RGSport12971.00
      04-26-2019, 09:58 AM   #11
Googone20
Googone20's Avatar
176
Drives: 2015 X5, 2007 M6
I use a wire brush attachment on a drill to clean the hubs and rotor face every time I mount my wheels. I also coat the hubs and faces with Anti-seize. This prevents the surfaces from bonding to each other and becoming stuck, and it also sucks the spacers down tight to the hubs when you torque them down.
2015 BMW X5 35d Msport Carbon Black/Mocha Nappa
2013 Cadillac Escalade Platinum Diamond White Pearl/Cocoa
2007 BMW M6 Sapphire Black Metallic/Black
2005 Ninja 636 Lime Green
      04-26-2019, 10:00 AM   #12
1norseman
398
Drives: X5 50i
Hey all,
Those kits states:
Expand your wheel options by dialing in fitment of 72.6mm centerbore wheels on your 74.1mm hub
If that is what you have, they are not hubcentric fit to your stock F15 wheels.
Edit: I have used ECS spacers in the past and they are good quality, but ECS is not always on top of what you actually need, like Ben (r33_RGSport) is.
If you are using 74.1mm centerbore wheels on spacers made for 72.6mm centerbore wheels, it will explain your problem.
You will either need to buy new spacers, or buy hubcentric rings. (Not sure if Ben sells the hubcentric rings or not).
In my opinion, you are better off trying to sell the ECS spacers, and buy new correctly matched sets from Ben!
r33_RGSport12971.00
      04-26-2019, 10:07 AM   #13
alphaod
Mmmmm…
alphaod's Avatar
1150
Drives: F15
I would suggest doing a clean mounting first to see if there is anything wrong with the spacers. After everything is deemed fine, then put the anti-seize on there.
BMW CCA 509766
      04-26-2019, 10:50 AM   #14
Googone20
Googone20's Avatar
176
Originally Posted by 1norseman View Post
Those kits states:
This may actually be your problem. ECS does sell two different sets of spacers for the X5’s. Make sure you are using the 74.1mm to 74.1mm ones. If your one side is a 72.56mm hub, that is why you have issues. BMW’s are very sensitive to hubcentric issues.
      04-26-2019, 12:05 PM   #15
ferrarif1
320
Drives: F85, G05, E46M3
Only coat the hub. The mechanical clamping force of the wheel mounting face against the brake rotor is what supports the wheel and it's critical this area is free of any lubricant.
      04-26-2019, 01:31 PM   #16
Googone20
Googone20's Avatar
176
I agree with you there. I use a couple of swipes just to prevent the spacer from bonding to the rotor surface. Not sure if you have every had this happen, but it can be a nightmare situation to get off.
      04-26-2019, 01:42 PM   #17
parkstr8
parkstr8's Avatar
562
Drives: 2020 BMW X5 MSport Arctic Grey
Having had spacers of some sort on almost every of my last 25 or so cars...I can say a few things:
1: hub centric is a must if at all possible. And I mean an exact fit.
2: Hub rings are ok, but if they are plastic they wear out and have to be replaced depending on how often they are on and off the car.
3: Quality of the spacer material/manufacture matters. Some are softer aluminum, and when they get torqued, or over torqued, or over torqued on one of the bolts, it can cause super small surface variances that are exaggerated when the wheel in spinning.
4: Wheel size, tire size, combined weight and size of the spacer all make a relative difference. See 1-3 above.
I have had lots of brands, H&R, Ichiba, ECS, China direct, a few others I can't remember.
Only go with top brand names and make sure they are not fakes, and this will reduce the issues. I have had a car that no matter what brand, what ever I did - there was always a vibration as long as a spacer was on.
Appreciate 2
r33_RGSport12971.00
HJ478.00
      04-26-2019, 08:46 PM   #18
turboawd
1636
Drives: 2015 X5 35i
Take the spacer and place on the hub. Is there any play?
Then take spacer and set it inside the wheel bore. Is there any play there?
If no and no. Then you should be ok.
      04-26-2019, 09:03 PM   #19
r33_RGSport
12971
I include a packet of anti-seize for each pair of spacer order. For free.
Appreciate 3
1norseman398.00
alphaod1149.50
      04-27-2019, 11:12 AM   #20
wearenh
158
Drives: 2015 x5 x35i DHP
1. this is not a rust/ antiseize / torque problem
2. the OP gave us the part numbers of the spacers he bought
3. those spacers have an carside 74.1 diameter, wheelside 72.6 diameter
4. the OEM F15 wheels have a 74.1 diameter
5. therefore, there is 74.1 - 72.6 = 1.5mm gap between spacers and wheel
6. a gap allows the wheel to be offcenter, causing massive vibration
7. you bought the wrong spacers
8. return these, sell them, or trash them ... buy correct spacers
      04-27-2019, 02:42 PM   #21
turboawd
1636
Drives: 2015 X5 35i
Yes. Ok. But i was just suggesting a visual method of seeing if the spacers are the right size.
1norseman398.00
      04-27-2019, 05:14 PM   #22
wearenh
158
I agree, no issues
xbimmers
