04-25-2019, 05:39 AM | #1 |
12
Rep 84
Conv Top not working after dead battery
I don't understand these cars!!
My battery was 6 years old and died. I replaced it with a new battery detailed on this forum. Perfect fit!!! Now, however, my top is stuck in the down position. The buttons just flash red. I have purchased a code reader/reset tool, Amazon Prime will deliver in 2 days. Suggestions on why the top has stopped working?????? |
04-25-2019, 07:13 AM | #2 |
851
Rep 4,057
My bet is a code issue associated with the new battery. It would be an incredible coincidence if the top motor failed at the same time that you replaced the battery. And it is unlikely to be the micro switches in the trunk - they prevent the top from lowering when the shelf between the roll hoops and the rear window is raised . In your case the top is already lowered. However, it couldn't hurt to take a look at them - open the trunk and see the black plastic knobs near the trunk hinges.
Out of curiosity, do you drive the car in the rain or leave it parked outside where the car could get rained on, potentially flooding the top motor? Or, do you wash the car with a power washer? The top motor doesn't like those things.
Huz-Z
BMW Z4 3.0si Roadster. Montego Blue Metallic. Premium and Sport Package. |
04-25-2019, 07:19 AM | #3 |
15
Rep 66
Drives: 06 Z4M Roadster; 2012 Cayenne
Try resetting your windows. Hold the window-up control for 10 seconds past when the window reaches the top. Do this for both windows then try the top.
04-25-2019, 12:22 PM | #4 | |
12
Rep 84
I am going to try resetting the windows as was detailed. That does make sense. |
04-25-2019, 01:17 PM | #5 | |
851
Rep 4,057
That's good - I expect that the likelihood of this being a failed top motor is very low. Re your comment that "It is garaged 24/7 and only driven on nice days with the top down", so is mine. Unfortunately in my case, that means I can drive it on 15 or 20 days a year. Let us know if the window reset does the trick.
Huz-Z
04-26-2019, 03:12 PM | #7 |
15
Rep 66
Glad to hear resetting windows worked. I have some sort of undiagnosed drain on mine too; I've seen several reports of that issue here. I keep mine on a battery tender when it is parked at home. I use a CTEK with a cig lighter adapter so it is easy to connect.
04-26-2019, 03:25 PM | #8 |
12
Rep 84
This car has been perfect since 2016, now a cascade of issues.
I read a suggestion about locking the car doors which should shut off the bluetooth which may be draining the battery. |
04-30-2019, 08:27 AM | #9 |
2286
Rep 12,565
Drives: Z4 M, X5, GX460
Bluetooth is not going to drain a new battery
04-30-2019, 10:18 AM | #10 |
851
Rep 4,057
Is the light staying lit in the storage compartment between the seats when the door of the compartment is closed? Sometimes a tab breaks and that light stays on, that could be one thing to check. If so, maybe just pull out the bulb to prevent further battery drain and recharge the battery.
05-01-2019, 07:59 AM | #11 |
12
Rep 84
I finally got frustrated and called the indie dealer. They have always been great.
The shop owner told me the new battery must be registered with the car? I have been searching the forums and can't find info on battery registration. Help? |
05-01-2019, 08:34 AM | #12 | |
851
Rep 4,057
Good luck!
Huz-Z
05-01-2019, 07:31 PM | #13 |
My other car is on Mars
636
Rep 3,124
There's no coding for the battery needed on the Z4.
Other BMW models, yes, which is why they incorrectly assume it's needed.
Warning: May contain traces of nuts.
05-02-2019, 04:22 AM | #14 |
12
Rep 84
This is not the first issue of where I have been questioning the indie shop's knowledge.
They are telling me the passenger seat occupancy mat needs to be replaced, as my seat belt light (not airbag) light is on. INPA shows the driver's seat belt sensor isn't registering closed when the driver's belt is buckled. INPA shows the mats and airbag sensors are perfectly fine. I am looking for another shop. |
05-02-2019, 07:22 AM | #15 |
15
Rep 66
I've seen other posts here that mention registering the battery on Z4Ms. I believe it is claimed to let the computer know a new battery is in so it can adjust the amount of charge the alternator sends to the battery. I have had my current battery in the car for nearly 4 years and have not registered it. Registering a battery may extend the life, but would not drain a new battery in a short amount of time. I've heard the bluetooth claim too. I believe locking the car shuts down most systems sooner than if you don't lock the car, but those systems eventually shut down when unlocked.
What I know from my own experience is without a trickle charger my previous battery died in less than one year and with my CTEK I'm coming up to four on this one. |
05-02-2019, 07:47 AM | #16 | |
2286
Rep 12,565
Stupid question OP, you sure the knobs aren’t turned by the shelf? |
05-02-2019, 08:04 AM | #17 |
851
Rep 4,057
Yes - the two black knobs in the trunk near each hinge should be positioned so that the shelf between the roll hoops and the back window is in the lowered position. If the shelf is raised (to make more cargo space in the trunk) it would occupy the area that the roof does when its lowered. So the knobs have lock outs to prevent the roof from lowering into the raised shelf and causing damage.
Huz-Z
05-02-2019, 07:25 PM | #18 | |
636
Rep 3,124
I was having a hard time putting these together. You replaced the battery with the top down? I can't see replacing the battery without raising the "tea tray".
05-03-2019, 07:01 AM | #19 |
851
Rep 4,057
In a non-M, you have full access to the battery whether the tray / shelf is raised or lowered.
Huz-Z
05-03-2019, 09:10 AM | #20 |
Rep 27
I have the battery out of mine now. It was five years old according to the sticker so I guess that wasn't abnormal.
Autozone gave me the wrong battery at first... long story. One thing I noticed that might be related: Before pulling the old battery I read 1.7V across the charge ports under the hood. Once I got the battery out, it was reading 4V right on the terminals. That seems like a lot of voltage drop to me just for a few feet of cabling... has anyone else measured this? Does this seem normal? |
05-03-2019, 10:50 AM | #21 |
636
Rep 3,124
All the major chains will give you an H5 when you're supposed to have an H6.
They apparently all work from the same flawed database.
05-03-2019, 11:52 AM | #22 |
Rep 27
Yep, that is exactly what happened to me.
Update on mine: Installed new battery, and I'm reading over 12V on the charge ports under the hood. So not seeing a >2V drop anymore with the new battery. I have it on the tender now just to make sure it is fully topped off, and I'll take it for a spin later this afternoon... Sorry not meaning to hijack the thread here... But is there a complete list of things you have to do after completely cutting and restoring power? I saw a window index operation mentioned above, hold the window switch up for 10 seconds after the window is closed. Is there anything else? Thanks for the input. |
