04-24-2019, 01:16 PM | #1 |
Rep 24
Wireless Charging Retrofit
I've seen the posts before where people talked about retrofitting wireless charging onto the 6 series using the BMW OEM part no. 84102449887.
Basically this replaces the existing phone mount with a snap in dock that will wirelessly charge the phone. However, it still has the problem of occupying a large amount of space in the console. I note there appears to be a second type of OEM wireless charger release by BMW which is seen in the link below. This one is more like a pocket that the phone slides into and seems far more space efficient. https://www.autoevolution.com/news/b...28.html#agal_2 There are three questions ultimately for this: 1. Can this part be retrofitted onto a 2013 F06 (or any pre face-lift 6 series)? 2. If so, what part number is this? 3. Has anyone done this before? I searched on here and found no examples. |
04-24-2019, 02:44 PM | #2 |
4446
Rep 7,488
Click the link below and scroll down to the wireless charging case info...click and you'll be presented with a vehicle information drop-down box to see if it fits your BMW. The part 11 digit BMW part nbr listed on shopbmwusa.com is 84212449610:
EDIT: did a bit more searching...it seems to be in the early stages of being released. The "wireless charging case" appears in the diagram for the G chassis 7 series as item #2...but item #2 is NOT listed in the part nbr index below the diagram.
2015 F06 650ix Gran Coupe`(Moonstone/Cohiba Brown)| 2014 F15 X5 50i MSport (Space Gray/Mocha)
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 04-24-2019 at 03:07 PM.. |
04-24-2019, 08:05 PM | #3 |
4985
Rep 11,891
Considering it's a $500 battery and easily $1000 of other power equipment, I wouldn't use the car to charge a phone.
I never charge my phone in the car. It's cheaper to use a separate power bank
22 Phytonic/Coffee X5 45e (CoVID-free)
08 Speed Yellow 911 GT3 Sharkwerks 12 AW/Cinnamon X5d Sports Pkg (retired) 14 AW/Beige M6GC ZCP, MPE, V2 steering wheel, vorsteiner (retired) 08 SSII/Black E90 M3 (retired) |
04-24-2019, 10:08 PM | #4 |
1316
Rep 2,349
At the moment my built in USB port always has a lightning cable connected to it to connect to my iPhone and I use the cigarette lighter in the centre console to charge power banks that I use if I'm going away for a week, going on a hike, or need to charge my Cygnett 27,000mah USB C power bank that can charge my X1 Carbon via USB C)
I don't see an issue with using either port while the car is running but I'm definitely worried about using it if the car isn't running and draining the battery.
SCOTT26 "So as an admirer of the M5 and a potential customer of an M5 Touring. I would run naked around the streets of Garching if they were to offer one."
