04-24-2019, 01:11 PM | #1 |
163
Rep 317
Coated or uncoated OEM wheels . . .
What are the stock aluminum wheels considered on my 2016 X5? I've been using McGuire's G14324 Aluminum Wheel cleaner on them but noticed the bottle says "harmless for uncoated wheels" . . .
Don't the OEM wheels have some type of clear coat on them? Is that considered a coated wheel? I use Jescar Powerlock sealant followed by PS2 carnauba on my paint, but I'd like to use the Powerlock on my wheels too. Is this advisable? I just had my daughter's highlander allloy wheels all 4 re-finished as they were corroding and she said she read that we are not supposed to use anything on them? Thx
2016 X5 35i color: Jet Black
2014 Audi Q5 Premier Plus color: Ibis White Last edited by expidia; 04-24-2019 at 06:12 PM.. |
04-25-2019, 02:32 PM | #2 |
163
Rep 317
No responses! Everyone must be gearing up for the Audi A8 for their next vehicle
2014 Audi Q5 Premier Plus color: Ibis White |
04-25-2019, 02:36 PM | #4 |
176
Rep 401
Which OEM wheel do you have? Stock X5’s come with several different wheel choices. All BMW wheels are aluminum on the X5. They are never uncoated from the factory. Even the machined face wheels have a clear coating on them to prevent corrosion. All are coated in some way.
2015 BMW X5 35d Msport Carbon Black/Mocha Nappa 2013 Cadillac Escalade Platinum Diamond White Pearl/Cocoa 2007 BMW M6 Sapphire Black Metallic/Black 2005 Ninja 636 Lime Green Last edited by Googone20; 04-25-2019 at 06:23 PM.. |
04-25-2019, 05:31 PM | #5 | |
4140
Rep 7,160
Drives: F90 M5 / F15 50i
And sounds like you're using cleaner designed for straight chromed or polished not painted (clear coat) wheels. Not good. It'll be too harsh on the paint. Chemical guys and ammo make good wheel cleanwrs for painted rims. Which is all the X5 bmw oem rims.
'07 Yamaha R1 (sold)
'06 C55 AMG (sold) ‘?20 M5, MP Carbon Pro Spoiler, MP Carbon Diffuser, MP Black grille and gills, MP Carbon Mirrors, CF side sills, 789M w/ Ti studs, eventuri, Dinan X pipe '14 X5 50i (wife’s now) |
04-25-2019, 06:05 PM | #6 |
163
Rep 317
OK thanks for those responses. Thats what I figured that they are clear coated and the McGuires product was too harsh for clear coat.
I'll check out the Ammo products and Chemical Guys.
04-25-2019, 06:28 PM | #7 |
163
Rep 317
Actually, the MGuires product I've been using a blue spray foaming liquid "does not" say safe for factory coated wheels.
They have a "red" spray foaming liquid that says safe for factory coated wheels which can also be used on the tires too (product: G9524): Description: Xtreme Cling foam vigorously clings to vertical surfaces and dissolves brake dust and grime Safe and effective on factory painted and clear coated rims, and tires as well Visually see dirt and grime lifting off the wheel & tire Easy to use and convenient trigger spray, spray-on and hose-off with water Leaves rims with a brilliant shine while effectively cleaning
