BMW X5 and X6 Forum 2014-Current
Go Back   BMW X5 and X6 Forum (F15/F16) > BMW X5 (F15) and BMW X6 (F16) Forum > BMW X5 and X6 (F15/F16) Forum
      04-22-2019, 11:46 AM   #1
CoffeeBean
226
Drives: 640i M-Sport GC
Has anyone coded the Sport mode configuration screen into iDrive?
Hey guys,
I'm wanting to code in the Sport mode configuration screen as seen below. I know certain F30s and I believe the F15 M-sport with adaptive suspension has it. The reason is to be able to adjust the steering level to the "sport" setting, but leave the rest in their "comfort" settings. I find the comfort setting of the steering to be too twitchy because of a dead spot in the center at interstate speeds. It makes it difficult to keep it in the center of the lane. I could just put it in sport mode, but I don't want it to downshift and stay in a lower gear on the interstate.
So, I've found the following threads discussing it and it looks like it can be done with the Bimmercode app. In the demo I have no problem getting to the first setting in the Head unit module, but the other setting in Integrated Chassis Management (ICM) module there's no expert mode. Can anyone confirm it does give an expert mode in the ICM module before I pay for the license?
https://f30.bimmerpost.com/forums/sh....php?t=1086229
https://f30.bimmerpost.com/forums/sh...0&postcount=26
Thanks!!
      04-22-2019, 12:12 PM   #2
BobBeau
BobBeau's Avatar
174
Drives: X5 50i
Subscribing
      04-22-2019, 12:38 PM   #3
CatalinP
590
Drives: BMW X5 F15 2014 3.0xd
No Expert Mode for ICM Module as of now. It used to be, it was disabled during a previous app update, but the developer promised that will re-enable it in a future update.
      04-22-2019, 01:28 PM   #4
CoffeeBean
226
Very interesting, I wonder why. Any other options out there that will work, Carly maybe?
EDIT: Actually I think I just hit the jackpot: https://apkpure.com/bimmercode-for-b...rcode/versions
Here's the changelog for the version where they added it.
BimmerCode 1.12.0-2750 (2750)
Update on: 2018-04-19
Requires Android: Android 4.2+ (Jelly Bean MR1, API 17)
Signature: 97d192c2d117a4d5aab3d24d506e57da0805dec3 BimmerCode 1.12.0-2750(2750) safe verified
Screen DPI: 120-640dpi
Architecture: arm64-v8a,armeabi,armeabi-v7a,mips,mips64,x86,x86_64
File SHA1: 57c7135d4b689da3d7bda2ae89b5a24db0743940
File Size: 3.4 MB
What's new:
- Updated coding data for cars that received a software update at the dealership recently
- Added Angel Eyes brightness coding options for cars equipped with TMS modules
- Added side marker coding option for cars equipped with TMS modules (US cars only)
- Improved Brake Force Display coding options
- Enabled expert mode for ICM
- Allow coding of all 8HP transmissions
      04-22-2019, 01:30 PM   #5
CatalinP
590
Carly can't do it. Esys works.
      04-22-2019, 01:54 PM   #6
Maverik259
Maverik259's Avatar
4140
Drives: F90 M5 / F15 50i
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
File Size: 3.4 MB
What's new:
He took it away for "safety" concerns. He said.
'07 Yamaha R1 (sold)
'06 C55 AMG (sold)
‘?20 M5, MP Carbon Pro Spoiler, MP Carbon Diffuser, MP Black grille and gills, MP Carbon Mirrors, CF side sills, 789M w/ Ti studs, eventuri, Dinan X pipe
'14 X5 50i (wife’s now)
      04-23-2019, 02:15 PM   #7
CoffeeBean
226
A little update: Bimmercode requires you to update it before it'll even connect to the car, so there's no way to get expert coding with an old version. I'm tempted to try E-Sys, but afraid I'll brick something with it.
      04-23-2019, 05:42 PM   #8
MizikeTSK
144
Drives: 2015 XDrive 50i MSport
Can't you also just hold down the DSC off button for a few seconds while in comfort mode? That will give you the "Sport Oriented Chassis settings" which I think tightens up the steering a little.
2015 F15 XDrive 50i MSport
      04-23-2019, 06:41 PM   #9
CoffeeBean
226
No that will actually turn off DSC and DTC. Well it does in my E90, unless the F15 is different. It may tighten the steering, but I definitely don't want DSC and DTC off.
      04-23-2019, 07:05 PM   #10
MizikeTSK
144
IC, Got it. I thought you just wanted the tighter steering.
      04-23-2019, 10:10 PM   #11
CoffeeBean
226
Well I just figured out the genesis of the whole issue. Not sure how I didn't see this before.
https://f15.bimmerpost.com/forums/sh....php?t=1469160
And there's a recall.
https://static.nhtsa.gov/odi/rcl/201...6V704-7084.pdf
Mine was CPO so if there was an open recall it would have been done, and there's no open ones now. However, it's still under factory warranty so it should be fixed under that.
xbimmers
