04-19-2019, 06:08 PM | #1 |
16
Rep 13
06 z4 roadster with M seat seat belt question
I bought a Z4 roadster over the winter, it has M seats. Had it parked for the winter and I just start driving it a lot and noticed that the shoulder part of the seat belt rubs against my neck and is uncomfortable. I'm 6'.
Any one else have a similar issue, if so how did you get around it? I'm thinking a seat belt extender to move the buckle to the left. Thanks. |
04-19-2019, 06:38 PM | #2 | |
2286
Rep 12,565
Drives: Z4 M, X5, GX460
04-19-2019, 07:50 PM | #4 |
your average JAMF
3101
Rep 4,094
Drives: '21 M2 Comp, '19 Golf R
"tiddy" bear. Brilliant!
'21 M2 Comp
'19 Golf R |
04-19-2019, 08:52 PM | #5 |
36
Rep 210
This always annoyed me so I put a small bolt through the guide holding it lower, it helps keep it away from my neck. Also it does need impede the function of the seat belt at all.
04-20-2019, 01:28 AM | #6 |
45
Rep 384
I just use a simple seat belt clip fromWalmart, It holds the shoulder strap at my stomach and over my shoulder away from my neck.
https://www.walmart.com/ip/WalterDra...-of-2/37284474
The Internet said it. I believe it. That settles it!
04-21-2019, 07:02 PM | #8 |
851
Rep 4,057
Roadster Solutions sells seatbelt pads that cushion the belt against the occupants’ shoulder. See:
http://www.roadstersolutions.com/cgi...33787c9eeb1551 Scroll down to see them. $49 for a set I think. There are a number of different ones on eBay like this https://www.ebay.ca/itm/2Pcs-Black-C...0AAOSwrmRb~qtQ Last edited by Huz-Z; 04-21-2019 at 07:09 PM.. |
04-21-2019, 07:06 PM | #9 |
#buildnotbought
10859
Rep 4,893
There are 2 types of belt deflectors made for the m seats.
Do you have the old or new style. I dont know if they make any difference (I have the old, never tried the new, but don't have any problems), but if you have the old, you could try the new (not vice versa, the old one is not sold anymore afaik but I might be wrong) I'm taller than 6' though.
Z4 3.0i | ESS TS2+ supercharger | Quaife ATB LSD | Brembo/BMW performance BBK front/rear | Schrick FI cams | Schmiedmann headers+cats | Powerflex/strongflex PU bushings | Vibra-technics engine mounts | H&R anti rollbars | KW V3 coilovers/KW camber plates | Sachs race engineering clutch | tons of custom sh#t
04-22-2019, 07:42 AM | #10 |
Rep 1
Just picked up a set of these as I find the belt gets pretty tight and uncomfortable (also 6' so know what you're talking about!)
https://www.aliexpress.com/item/Onev...1af04c4dip0XZq |
04-22-2019, 01:52 PM | #12 |
226
Rep 1,130
Drives: '11 E92 328i LCI & '06 Z4MR
5'10 reporting here....wait, we're talking about heights right?
All jokes aside, the seat belt also rubs on my neck, itches pretty bad once i get home after a 30 minute drive
2014 BMW X5 Sdrive35i F15
2011 BMW 328i E92 LCI 2006 BMW Z4 M Roadster E85 2013 BMW S1000RR K46 R.I.P. 1998 BMW Z3 Roadster 1.9L E36 SOLD |
04-22-2019, 04:56 PM | #13 |
dances with roads
4732
Rep 4,096
I had someone give me one of the pad-style items. I hated it. All it did was make the bad thing worse. I also tried lodging things in the guide on the seat in an attempt to keep the belt a bit lower. It might work for a 6-footer but I'm 5'10" and it did nothing for me.
I just reach up and move it occasionally. I've driven 10+ hours without being overly bothered. |
04-22-2019, 05:31 PM | #14 |
My other car is on Mars
636
Rep 3,124
I have wraps similar in design to the ///M wraps linked in post #8, but mine are plush and fluffy generic black. Feels kinda nice.
Probably came from Walmart or Target. Not sure. Wife bought a sack of them years ago for all of the cars/trucks.
Warning: May contain traces of nuts.
