04-19-2019, 05:49 PM | #1 |
93
Rep 142
Hitch question
I have read through most of the prior forums and wanted to inquire what are people's thoughts about U-Hauls hitches ? I have m sport 2017. I read about invisihitch even spoke to them but reviews are mixed. I heard U-Haul are more stable thought they have to slightly trim bumper, oem is not worth it. What do you all think and what is more stable to get ? Not planning on returning my vehicle so don't mind minor cut. Thank you in advance for your responses!
04-19-2019, 06:25 PM | #2 |
190
Rep 271
Draw Tite hitch is a straight bolt on install for regular or m sport line, no trimming required. Also, it allows you to keep the existing metal bumper re enforce bar. Curt hitch does not allow that. To me, that's a biggie.
04-19-2019, 06:36 PM | #3 |
93
Rep 142
Thank you I will look into it. I agree with you on that point as well
04-19-2019, 07:49 PM | #4 |
250
Rep 748
Reese Towpower 44590 is a bolt-on install. You keep original re-enforcement bar, and no bumper trimming. I am happy.
Ones drove a Reliant Robin. )))
04-19-2019, 08:01 PM | #5 | |
4140
Rep 7,160
Drives: F90 M5 / F15 50i
'07 Yamaha R1 (sold)
'06 C55 AMG (sold) ‘?20 M5, MP Carbon Pro Spoiler, MP Carbon Diffuser, MP Black grille and gills, MP Carbon Mirrors, CF side sills, 789M w/ Ti studs, eventuri, Dinan X pipe '14 X5 50i (wife’s now) |
04-19-2019, 08:27 PM | #6 |
190
Rep 271
04-19-2019, 10:16 PM | #8 |
93
Rep 142
04-20-2019, 05:13 AM | #9 |
Reads books at a 4th grade level; I'm an enabler
78
Rep 116
Drives: X5 35d, 335i Msport, X3, 325iX
Garage List 1993 BMW 525iT [0.00]
1989 BMW 325iX [0.00] 2015 BMW 335i M-Sport [0.00] 2007 BMW X3 M-Sport [0.00] 2015 BMW X5 [0.00] |
The info is in this thread https://f15.bimmerpost.com/forums/sh...1508166&page=2
I have the Curt, WGXDZ has the Reese on his MSport |
04-20-2019, 08:55 AM | #10 |
88
Rep 276
I have a 2014 F15 M-Sport. I'll probably go with the Draw-Tite as it looks decent and doesn't require cutting of the bumper. My question is on the wiring. What all do I need? I know my vehicle has the "tow preparation" option, which I believe just makes the wiring a little simpler. But what harness/modules do I need? Thanks!
04-20-2019, 09:39 AM | #11 |
20
Rep 71
I have to get a hitch as well. I have a 2018 X6; thought I'd head up to BMW to ask a few warranty questions since the truck is under a year old. Apparently BMW won't install outside parts (knew that already), and of anything goes quirky with the lights or anything electrical from the install of the commercial wiring harness, the warranty stands risk of being voided because it was modified from an outside source. So a towing hitch/wiring harness package that was for $262 has risen to over 1K
04-20-2019, 01:45 PM | #12 | |
93
Rep 142
04-21-2019, 07:16 AM | #13 | |
78
Rep 116
Hitch of your choosing 1x 82 71 2 349 500 - Electronics Installation Kit, Towing 1x 71 60 6 884 357 - Control Unit 8x 07 11 9 906 050 - Hex Nut 8x 07 14 7 293 278 - Rivet, Black or 07 14 7 391 324 - Rivet, White And then some programming work. I prefer to add 3AC to Options List and then switch the power folding options back to fixed. Other folks code K235 as an HO-Wort |
04-21-2019, 11:08 AM | #14 | |
320
Rep 1,061
04-21-2019, 05:30 PM | #15 | |
19
Rep 39
04-21-2019, 11:14 PM | #16 | ||
93
Rep 142
04-22-2019, 04:01 AM | #17 | |
<3 Flat Four
217
Rep 754
1: no bumper trimming is required, MAYBE the 2014MY only, i believe 2015MY+ already has the bumper cut out, my bumper (2016MY) already has an oval shape cut out to clear any hitch. look at the following pic for reference from google 2: anyone who does the hitch install themselves will realize how much MORE beefier a hitch is when comparing to the oem bumper beam/re-enforcement bar, which is stamped thin steel and bent with me pushing down on it. TLR, the oem bumper beam is thin and light, dont bother looking for hitches that specifically keeps the bumper beam in place. i will gladly replace it with any aftermarket hitches, WAY more sturdy.
2011 335is Le Mans Blue
2016 X5 xdrive 35i Alpine White Last edited by TOPEC; 04-22-2019 at 04:15 AM.. |
04-22-2019, 08:33 AM | #18 | |||
19
Rep 39
04-22-2019, 11:35 AM | #19 |
78
Rep 116
Because I was able to use the NCD/CAFD compare tool to look at all the changes it propagated, where I can't do that with changing the HO-Wort.
I would still be willing to try the comparo between the 3AC and the HO-Wort methods if someone wants to send over their CAFD files from an HO-Wort coded car. |
04-22-2019, 12:08 PM | #20 | ||||
93
Rep 142
04-23-2019, 09:06 PM | #21 | |
320
Rep 1,061
I will caution that ISTA codes a lot more than just AAG and PDC that is documented in the linked thread. In particular, the ISTA/K235 method communicates with the transmission when there is a trailer attached to modify shift points. With the 3AC method, I would VO code the entire car to make sure everything is in sync and you will likely end up with the same outcome as ISTA/K235 but will of course have to code out the folding options for the hitch. |
04-23-2019, 11:39 PM | #22 | ||
20
Rep 71
