04-16-2019, 08:04 PM | #1 |
721
Rep 2,342
F15 10.25 Screen retrofit question
So I've started the retrofit and before trimming the plastic back on the F15 display I wanted to see how much is needed to trim.
But before I can even get that far I'm experiencing that the rear aluminum tabs that slot into the dash do not line up at all. Indicated in yellow on the display does not slide into indicated in green on the dash. To make sure I wasn't insane the standard display fits just fine. Any guidance from someone that's done this is greatly appreciated. |
04-16-2019, 10:49 PM | #4 |
721
Rep 2,342
There won't be any. I gave up about an hour ago. There's no way to do it without cutting the dash and/or taking big chunks of material off the display.
I'm not cutting my dash and don't have the means to modify the display properly. The plastic bezel in front (not only the back) needs to be modified. I don't see any other way. |
05-03-2019, 01:45 AM | #5 | |
4490
Rep 10,473
Not like you will take the screen out to sale. Only cutting is to slightly widen the holes already there....if that is the route of the 2 you decide to take. If you want to try trimming the CID instead, I have a box of dead CIDs to practice on for $30 each. |
05-03-2019, 10:17 AM | #7 | |
516
Rep 1,247
Drives: 2022 Taycan GTS, 2018 M4, 2016
05-03-2019, 10:45 AM | #8 |
4022
Rep 3,540
Drives: 328d Wagon, M2 Comp, i4 eD35
A G30 5-series screen doesn't require any cutting of the dash or screen, but requires a bit of creativity in mounting it.
You can see where I am in making it work here. I'm going to try making some mount extensions out of thermo-formable plastic so I can use the screw mounts. Also going to try and make a back panel cover to close the gap and slot into the rear mounts the same way.
-328d Wagon Build Log (with helpful reference links)
-My YouTube Channel for some of the best DIYs and in depth information Please don't PM me for suspension recommendations unless interested in paid private consultations. |
05-03-2019, 10:49 AM | #9 |
721
Rep 2,342
I won't cut my dash since I prefer any modification I do to be 100 percent reversible - whether it can be seen or not.
I had a screen from a MY2015 F15. I sold it already. They bring good money on eBay. |
