04-08-2019, 04:42 PM | #1 |
76
Rep 152
BMW Update UPD05081
I have been having tons of issues with USB Audio playing back and dealer told me there was an software update.
After update my info are as following MN-002.034.071 TN-002.034.070 HN-003.255.080 However, this did NOT solve any problem and now i think it's more frequently. Did some search, most of you F15s are MN-003.xxx TN-003.xxx did I miss an update? mine are still 002 not 003. Is this just because mine is 2014? Thanks
Jeff
Current Ride - 2016 Toyota RAV4 Hybrid - 2014 X5 xDrive35 M - 2013 ML-350 (Gone) - 2012 Audi Q7 TDI (Gone) |
04-08-2019, 05:12 PM | #2 |
862
Rep 885
I have a 15' 35i and my UPD05081 package sits at:
MN-002.255.071 TN-002.255.080 HN-003.255.080 I believe that if the dealership does the update it will bump you to 003.. , it's worth a shot considering you're having audio issues, and it's gotten worse. The UPD pkg on the website seems to be old. https://f15.bimmerpost.com/forums/sh....php?t=1459801 |
04-08-2019, 08:08 PM | #3 | |
4140
Rep 7,160
Drives: F90 M5 / F15 50i
'07 Yamaha R1 (sold)
'06 C55 AMG (sold) ‘?20 M5, MP Carbon Pro Spoiler, MP Carbon Diffuser, MP Black grille and gills, MP Carbon Mirrors, CF side sills, 789M w/ Ti studs, eventuri, Dinan X pipe '14 X5 50i (wife’s now) |
04-08-2019, 10:31 PM | #4 |
Rep 28
What kind of issues? I've been having issues with mine as well. When I plug in my iPhone via the usb, it connects and disconnects, connects and disconnects. It's really annoying. Finally just put a cigarette lighter adapter in to charge the phone and use Bluetooth for all the audio. Would prefer a better solution than this though.
04-08-2019, 11:13 PM | #5 | |
231
Rep 1,066
Drives: 2015 X5 50i M Sport
2019 Cayenne Turbo
Gone but not forgotten: 2006 2.0T A4 Avant, 2007 Z4 Roadster 3.0si, 2006 M Roadster, 2013 550i M Sport, 2015 Cayman S, 2015 X5 50i M Sport |
04-09-2019, 12:33 AM | #6 |
1059
Rep 2,511
I have 2014 as well, dealer got mine updated about a year ago, no issues since. Check here too:
04-09-2019, 05:23 AM | #7 | ||
Rep 28
04-09-2019, 11:45 AM | #8 |
Mmmmm…
1150
Rep 2,426
Drives: F15
My original iDrive head unit had a problem with charging my iPhone X and audio playback issues. The dealer tried updating the software to no avail.
I read on the forum that they revised the hardware in the head units that in post late 2016 builds, they fixed this problem. I was getting a "No Signal" problem, so my dealer was able to replace the head unit under warranty with a newer one. This new unit does not have any problems with charging my phone nor any audio playback issues. Might not be the kind of solution you want to hear, but it might a hardware problem.
2015 BMW X5 xDrive50i
BMW CCA 509766 |
04-10-2019, 03:05 AM | #10 | |
11
Rep 40
The problem started with an Apple OEM cable that got squeezed between the armrest a couple of times. At first it would still work depending on how I held it but in the end it didn't matter anymore, same problems as you describe... About UPD05081: downloaded the package from the German BMW website(*) and updated: installed 26 Sept 2016 --> 9 April 2019 (UPD05081) MN-003.001.002 --> 003.009.004 TN 003.001.002 --> 003.255.080(-013.039) HN (didn't show at the time) --> 003.255.080 * bmw.com/update -> entered all 17 digits VIN -> stated car was up to date... https://www.bmw.de/de/topics/faszina...es-update.html -> entered last 7 digits VIN -> states this update (UPD05081) is only valid for cars with production date between Nov 2012 and Feb 2013... The related PDF however includes the versions stated above, and as they're newer than the ones I had my the car, I ignored this info and performed the update without issues... Last edited by BBDDVV; 04-10-2019 at 04:03 AM.. |
04-10-2019, 10:58 AM | #11 | |
Rep 28
04-10-2019, 11:29 AM | #12 |
862
Rep 885
Have a service appointment tomorrow, wondering if I should see if they'll update my firmware as I'm sitting on UPD05081 from the website myself. Haven't had any issues with anything/coding.. Hmm
04-10-2019, 01:11 PM | #13 |
1059
Rep 2,511
04-29-2019, 09:29 AM | #14 |
Rep 31
Hi
I update my X5 F15 with UPD 05080 it works properly . no change with the MN: 003.001.002 However i see that where is a more recent MN version than mine which is 003.001.002 , the latest wrote on the PDF document is MN 003.013.001 . How to do to obtain this latest version? |
04-29-2019, 11:58 AM | #15 |
Rep 31
Hi
I update my X5 F15 with UPD 05080 it works properly . no change with the MN: 003.001.002 However i see that where is a more recent MN version than mine which is 003.001.002 , the latest listed on the PDF document is MN 003.013.001 . How to do to obtain this latest version? |
07-07-2019, 05:48 AM | #17 |
Rep 36
Just received my F11 LCI 2015 after the retrofit of the PPK B47
It received the latest I-step. MN-003.013.001 TN 003.255.080 HN 003.255.080 No issues with iPhone anymore, let’s see on the next iOS update Needed to put new disks brakes, so I did the PPK that brings the entire front brakes. After the PPK it’s a new car |
08-23-2019, 11:36 AM | #18 |
Rep 11
I know this thread is a little old, but I just traded my 16 340i in for a 16 x5 35i m sport. I love everything about it and even the tech seems newer despite the same model year. However, on my 340i, I had full visibility and control of my Spotify and other apps from the iDrive system. With the new x5, I have no control or visibility. It's pretty frustrating overall.
I did do an update by thumb drive from the website, but I'm wondering if a dealer update might be warranted. I've searched the site and can't find info on how to fix this. I'm using an Android (One+ 7) and have tried both over USB (only get destinations, no apps), and Bluetooth (I get sound, but no control or info). TIA |
08-23-2019, 12:25 PM | #19 | |
[Oo=||=oO]
1103
Rep 2,470
08-23-2019, 04:46 PM | #20 | |
Rep 11
I have connected drive (currently subscribed) and I had connected drive. However, that is not what I was using. I was simply using Bluetooth through my "Media" option on my iDrive. So, when I would load "Media" and selected my BT device, my track, album, and artist would show up and I could use steering wheel controls as well as my dash buttons to move forward and backward. It's not Connected Drive where I have full control of the app. Now, all I see is "Unknown Album, Unknown Artist, Unknown Track" and I cannot skip nor reverse. Thanks for your help! |
08-23-2019, 04:50 PM | #22 | |
103
Rep 893
