04-01-2019, 12:00 AM | #1 |
139
Rep 103
BMS OR SSR?
Can’t decide between BMS intakes or SSR? Which ones do you guys prefer? Doing this solely for sound I know I won’t be getting power out of it. Let me know which one you guys prefer and why. Thanks!
04-01-2019, 12:38 AM | #4 |
139
Rep 103
04-01-2019, 03:07 AM | #5 |
31
Rep 136
I wouldn't go with either because they're open air intakes located in the hot engine bay which is ultimately defeating the purpose of intakes in the first place. If you get intakes get front mount intakes. I just installed the Agency Power intakes and they are louder than my friends SSR intakes. They also look pretty good from the front of the car as well
tebbnsx719.00 |
04-01-2019, 06:47 AM | #6 |
2892
Rep 2,147
I also ran SSR intakes for about 3 thousand miles and 9 months. Makes all the fast and furious noises you'd expect. No CEL or any issues on stock tune. Only side effect was a higher/jumpy idle during cold start for a few seconds, but then it ran and drove normally from then on.
I eventually took them off just in case I'd ever run into an engine issue that needed warranty. I was also mildly paranoid of the filter design - it's just metal mesh, and although they were always dry after driving in the rain, I drive through a lot of construction areas, and the dust being kicked up into the air freaked me out. I was always going into neutral and coasting through the dust spots at idle so I wouldn't pick up any dust or dirt in the engine. In the end, the anxiety wasn't worth it for me. I'm on stock intake again with carbon filters removed, and am enjoying the car with no headaches. |
04-01-2019, 08:15 AM | #7 | |
105
Rep 136
Also what is this about the carbon filter removal I am hearing about? What are the benefits to sound? |
04-01-2019, 08:27 AM | #8 | |
2892
Rep 2,147
Of course the front mount intakes get wet - don't let anyone try to convince you otherwise. You're running 16+ PSI through 2 filters that are exposed during rain, and if the filter is the metal mesh type like SSR, it's only a matter of time before problems happen. I was paranoid enough about them in the engine bay, but the surrounding area was always 100% dry even after a heavy rain, so I didn't worry as much. I could maybe see this not being a problem on a naturally aspirated engine, but on with twin turbos @ 16 or more PSI? not a chance. Regarding carbon filter removal - I don't remember which thread I found it on, but I think it's just something for US market. Need to take off cf brace to get to them, but it's a couple screws away and you can toss them. I haven't noticed any change in sound to be honest, but I hear the stock intake well enough with windows open. |
JayZap16104.50 |
04-01-2019, 09:46 AM | #9 | |
255
Rep 490
04-01-2019, 10:09 AM | #10 | |
139
Rep 103
04-01-2019, 10:32 AM | #11 | |
2892
Rep 2,147
Agree with you on the noise, sounds great, and I never got sick of the sounds. But yes, aside from the cold start jumpy idle, which isn't really a big deal, there's no difference once you're driving - feels the same as stock, other than the whooshes basically always audible. Again, never had a CEL over 3,000 miles. Anything over 10% throttle will make some noise, but it's easily overcome by the stereo at low volume. My wife noticed the sound after I installed them, but it never bothered her. For what it's worth, a CEL from an intake was the last thing I was worried about - these engines aren't nearly as fragile with intakes as untuned Subarus for example. I was more worried about a spun crank hub or anything else happening while running an aftermarket intake. It's a conversation that I just don't want to have with a dealer should something go wrong. I paid too much for the car to prove the parts I installed didn't break it. |
04-01-2019, 10:44 AM | #12 |
40
Rep 64
Maximum PSI posted a video a while ago about the mesh cones/filters some of the companies use and it does a terrible job filtering. BMS' intakes and filters are more than enough for sound and eye candy in my opinion.
04-01-2019, 12:42 PM | #14 |
139
Rep 103
So are the BMS filters one of the filters that does a bad job of filtering? Or do they filter pretty well?
04-01-2019, 12:58 PM | #15 |
40
Rep 64
They're good filters. They're not the wire mesh kind. Spectre also makes different diameter flange filters that'll work with BMS piping in case the blue filter isn't what you're looking for. They have white, red, black and blue. I haven't tried Spectre filters yet, but will once my BMS ones get dirty. Their filters aren't wire mesh either. Anyone else feel free to chime in and comment on the wire mesh filters vs BMS'. After seeing Max PSI's video and commentary on the wire mesh ones, I knew I didn't want to go down that route. Max PSI is a shop in Jersey that is always breaking 1/4 mile time records so their word is pretty trustworthy.
04-01-2019, 01:10 PM | #16 |
IG @bmwF9xG80
3813
Rep 7,593
Drives: G80 M3, X4M, G07 X7m50
SSR or CTS Turbo for me
60-130mph 6.5s X4M #HCP
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce IG: @bmwF9XG80 |
04-01-2019, 01:11 PM | #17 | |
139
Rep 103
04-01-2019, 01:15 PM | #18 | ||
ECUTek Master Tuner
10447
Rep 1,735
Drives: F80 M3 YMB
PLZ_M340.00 |
04-01-2019, 02:28 PM | #20 |
BimmerPost Supporting Vendor
8271
Rep 18,856
Drives: BMW
BMC filters
PLZ_M340.00 |
04-01-2019, 03:10 PM | #21 |
719
Rep 785
Drives: F80 M3
That’s an interesting looking engine bay.
