03-30-2019, 02:20 AM | #1 |
6090
Rep 3,629
LCI tail light retrofit not flush
bought some lci tails from iND for my f80. everything is working and coded correctly. but no matter what i do i can't get the inner tail light part to sit flush, its like sticking up 1-2mm too high. Anyone else have this issue?
i'll try going back in and maybe tightening that 8mm nut a bit more, but i already have tightened to the same height as before (as high as my ratchet and 8mm socket allows and i'm already getting resistance) i can physically push the tail back in with some force to make it flush, but it'll push right back out i took a short video:
2018 Porsche GT3 6MT 2021 M2C DCT Previous: Ferrari 458 | R35 GTR | F80 M3 | E46 M3 | E36 M3 | Scion FRS |
04-01-2019, 07:00 AM | #3 |
2892
Rep 2,147
I'll take a look at mine tonight, but from what I remember, the trunk lights were a PITA compared to the body panel lights. I do recall having the same problem - it took me about 20 minutes per side. The way you have to finagle them in is moronic, but it eventually does fit correctly.
04-01-2019, 01:40 PM | #4 | |
6090
Rep 3,629
all the clips are in place. the only adjustment is the screw on the inner side of the inner tail light. that will push the inner side down (side closest to the license plate), but the outer portion is still protruding out.
the outer tails have no adjustment. just a clip on the outer edge and two nuts to secure it on the side closest to the trunks Quote:
other than that i'm not sure. maybe the weather stripping along the edge of the light is causing the issue. all I know is the lci car I saw at the dealer did not have this same problem.
04-01-2019, 04:09 PM | #5 |
2892
Rep 2,147
Here's what mine looks like. I guess it's the same as yours. I never noticed it. But the driver's side is more inward with respect to the fender light. Maybe it is the trunk alignment. I guess I never noticed it until now. Definitely doesn't bother me though haha.
04-01-2019, 04:20 PM | #6 | |
6090
Rep 3,629
i'll check that in a few days when I have time. right now I'm so tired of pulling that trunk liner out over and over. but yeah when you go to a dealer and run your finger across the tails on a factory lci car there is no 'drop off' or step inbetween the inner and out tail light.
04-01-2019, 08:12 PM | #7 |
smoke if ya got 'em
1070
Rep 2,179
You have to work with the plastic clamp. It’s easy for it not to sit well which will obviously not slow the light to sit flush as you tighten it. Loosen the screw as much as possible without removing the clamp. Jiggle the light when it’s seated in the trunk lid. Took me a couple tries when I installed the MP blacklines.
04-02-2019, 12:37 PM | #9 | |
6090
Rep 3,629
someone mentioned that on the f30 page. https://f30.bimmerpost.com/forums/sh....php?t=1599349
04-02-2019, 08:20 PM | #10 | |
smoke if ya got 'em
1070
Rep 2,179
04-06-2019, 12:01 PM | #11 |
Specialist
1312
Rep 2,708
I remember there was like just a minor little adjustment to do with the trunk lights. I think maybe that rear clamp was prematurely locked down. It sucks to open everything up again but I would do it.
04-09-2019, 06:18 PM | #13 |
smoke if ya got 'em
1070
Rep 2,179
04-10-2019, 11:49 AM | #14 |
162
Rep 346
https://www.motortrend.com/news/conf...for-l-a-debut/
hyundai it first for once in their lives lol |
04-10-2019, 01:53 PM | #15 | |
A family of bimmers
2748
Rep 7,742
2018 PB/Black G01 X3M40i | 699M | ZDA | ZPP | ZPX | Maxton front lip | X3M vents | 15mm Spacers | Diamond G20 style grills |
04-10-2019, 06:12 PM | #16 | |
smoke if ya got 'em
1070
Rep 2,179
He’s talking about the shape of the red light. Last edited by shay2nak; 04-10-2019 at 06:18 PM.. |
Madvillain161.50 |
04-17-2019, 07:15 PM | #18 |
smoke if ya got 'em
1070
Rep 2,179
04-19-2019, 10:25 AM | #20 |
Specialist
1312
Rep 2,708
I could NOT pass up the opportunity. Yes, my car is filthy lmao.
I have to return my M3 now since its equipped with Hyundai tail lights.
05-05-2019, 08:04 PM | #21 |
60
Rep 112
05-28-2019, 09:44 PM | #22 | |
Blocked from G80/G82 for having an opinion
3498
Rep 3,729
shay2nak1070.00 |
