03-26-2019, 05:31 PM | #1 |
1498
Rep 1,297
Crank hub install
Found a shop willing to install the capture from vtt for 800. They’ve never done it but have a bmw certified tech with over 15 years experience that used to work at a bmw plant
Should I do this? This isn’t going to require timing or anything since it’s just the bolt capture but god always so scared of someone screwing the car up. I’ve called many shops and most shops don’t seem to have experience with this which tells me that this issue isn’t as widespread as the forums make it out to be
2022 M3 xDrive Comp
2020 M2 CS (retired) 2018 M3 Comp (retired) 2015 335i (retired) Last edited by gemini.m3; 03-26-2019 at 05:41 PM.. |
03-26-2019, 05:41 PM | #2 |
247
Rep 466
Any decent BMW mechanic can install the bolt capture. Many shadetree mechanics could. I plan on self installation... 800$ in labor is a little bit high. What is his hourly rate?
03-26-2019, 07:05 PM | #7 |
227
Rep 369
You don’t put a socket on the crank bolt, so why would you?
///M3
03-27-2019, 03:09 AM | #9 |
508
Rep 648
Drives: 2016 F15, 2015 F83
The pulley has enough belt tension on it that it's not likely to move during installation.
2016 F15 X5 50i M-Sport
2015 F83 M4 |
03-27-2019, 09:15 AM | #10 |
Rep 35
My pulley came out as soon as I remove the last bolt. The CBC installation took me 3 hours. This was my first time working on a S55 and no lift. A shop should be able to do it in 2 hours if they had done it before.
03-27-2019, 10:28 PM | #11 |
1498
Rep 1,297
what did you do when that happened? easy to put back on?
2022 M3 xDrive Comp
2020 M2 CS (retired) 2018 M3 Comp (retired) 2015 335i (retired) |
03-29-2019, 06:35 AM | #12 |
Rep 35
Not that easy but, doable. I kept the water pump belt in the pulley since I did not knew how to remove the tension off the pulley. That made it hard to put everything back. I searched online for half an hour, how to remove the tension but, failed. I removed the oil cooler, intercooler pump and fan from the bottom. From the top, I just removed the left air box to gain access to the fan plug, clips and hose clips.
If someone knows how to remove the water pump belt, please post the steps. |
FSociety3812.50 |
03-29-2019, 07:15 AM | #13 | |
758
Rep 1,337
https://www.newtis.info/tisv2/a/en/f...per/1VnXHhBoUs
https://www.newtis.info/tisv2/a/en/f...per/1VnXbKmxyA Quote:
Previous Rides: 13' 135i, 08' 130i, 03' HKS Turbo'd 350z, Modded GC8 WRX, NA MX5
03-31-2019, 02:19 AM | #14 | |
IG @bmwF9xG80
3813
Rep 7,593
Drives: G80 M3, X4M, G07 X7m50
Crank Bolt Capture by itself is not a full crankhub install but yes $800 is pretty high. Where do u live?
60-130mph 6.5s X4M #HCP
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce IG: @bmwF9XG80 |
