R44 Performance
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics
      03-23-2019, 04:02 PM   #1
M3anth
11
Drives: F80
Question Bimmertech MMI Reverse Camera - Manual Transmissions help?
The instructions are lacking regarding the steps needed for a manual transmission car. I'm guessing the extra wire harness that has a gray and purple wire (gray wire is extended by a black wire, purple wire is capped at the end and has a "safe" sticker on it) should be run along side the camera wire that goes from the trunk to the MMI unit? Then this gets plugged into the "M/T" port on the MMI? Then in the trunk the black wire (again, coming from gray wire on the small harness plugged into "M/T" ) should be spliced into the black w/blue wire on the harness plugged into the trunk (picture is in instructions, I believe this is reverse light wire)?
The only thing the instructions say is to attach the gray wire to the black/blue wire on the one harness in the trunk. Nothing about routing it to the MMI or plugging it into "M/T. " I'm just making guesses on what makes sense to me.
      03-25-2019, 11:54 AM   #2
M3anth
11
Drives: F80
Just an update - Bimmertech emailed me back over the weekend and answered all of my questions. The backup camera is fully installed and working flawlessly.
      03-25-2019, 04:39 PM   #3
RRedline
208
Drives: M3 ZCP MN6
What was the job like? I've got a 17 6MT and was contemplating doing this myself.
I'm comfortable with most DIYs...more about time availability.
Any words of wisdom following your installation experience? How long did it take?
      03-28-2019, 11:08 PM   #4
M3anth
11
Drives: F80
With proper instructions it's really simple. It took me longer than it should have because I didn't realize dropping the glove box was necessary (I tried to avoid it for some stupid reason but it was necessary to find a place to fit the MMI box). And the instructions didn't clearly address wiring for 6MT, and some of the clips and harnesses I was unfamiliar with and didn't want to break anything. I also only had chunks of time to work on it over the weekend. I'd estimate I ended up with 4-5 hours in it start to finish and clean up.
If I did it again it would take 2 hours max. I'll post some specific additional instructions when I have some time. Honestly anyone that can use a screwdriver properly should be able to handle it.
      03-28-2019, 11:25 PM   #5
x.shell
x.shell's Avatar
6582
Drives: ▋ ▉▉
Which color wire did you end up tapping for the reverse light?
      03-29-2019, 07:55 AM   #6
M3anth
11
Drives: F80
There are 3 harness connectors above the battery. On the middle one, it's the black wire with blue stripe going to pin 3. There is a fairly decent picture on page 33 of the instructions. And Bimmertech includes a simple wire splice / tap in connector to make that very easy.
f80post
