proTUNING Freaks
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > Engine / Drivetrain / Exhaust / Bolt-ons / Tuning
      03-21-2019, 03:29 PM   #1
Dr._Who
125
Drives: Tardis
Hey,
Originally Posted by Dr._Who View Post
Hey,
I finally was able to get my Dyno. run in!
It wasn't as simple as most make it out to be, at least not in my case.
It's very difficult to get all of the "electronic nanny's" off and to stay off!
* There's a "Secret Menu".
* Your car will Heat up.
* You need to wait for the car to cooldown - with the engine on - before actually turning the ignition off.
* You will need to turn the car off and on again, at least a few times, as more than a few lights on your
instrument panel will go off on your initial run(s)!
I received the following error codes:
- Brake
- Chassis
- Rear Differential
You will need to re-cycle (on/off) and wait a bit for these to clear, before you can try another run.
**404 Rear Wheel (All Wheel?) Hp.!!**
Within the "Secret Menu" there's a Dyno ("03 - Roller") Mode one needs to access and go through a whole process
of forcing the DSC off and keeping "Sports+" from resetting (to "efficient") at every ignition re-cycle.
Oh! And it only went smoothly when all 4 wheels were rolling!?!
The operator finally had to break out something (Bosch Code Reader) called "The Hammer" and plug it into my OBDII
port in order to completely block the car from throwing out any error codes and obviate the electronic nannies!
This is how I got the additional +10Hp. Unfortunately, after 2 1/2 plus hours, The Dyno's system (and/or the guy's laptop)
went into meltdown and I couldn't get a proper & final print out!
Cheers!
f80post
