ZPOST
Go Back   ZPOST > BMW Z4 Roadster and Coupe > General BMW Z4 Forum
  TireRack
      03-20-2019, 07:58 AM   #1
musmand
Drives: 2003 Z4 2.5i Toledo Blue
Outside temperature
I purchased a used 2003 Z4 2.5i that was used to run drugs. They tore apart the inside to hide drugs and they trashed the suspension trying to escape the cops. I am working on fixing it up. The problem I'm having right now is with the AC. The outside temperature is reading as -40 degree F. It hasn't moved since I bought the car. The AC doesn't blow cold air. It is charged. Any thoughts?
StickMon636.00
      03-20-2019, 09:35 AM   #2
garz747
286
Drives: 07 Z4MC 01 330i 18 X3 M40i
the sensor wire(s) running thru wheelwell to front bumper is likely disconnected or damaged.
kaybat125.50
      03-20-2019, 11:15 AM   #3
StickMon
My other car is on Mars
StickMon's Avatar
636
Drives: 2006 MR
There should be one of these sticking down in a pocket in the plastic piece under the front bumper in front of the driver side front wheel.
https://www.ecstuning.com/b-genuine-...e/65816936953/
From your description I wouldn't be surprised if the entire plastic trim piece is gone, sensor and all.
Good luck with the project. Maybe you'll find a wad of cash hidden somewhere.
Warning: May contain traces of nuts.
      03-20-2019, 11:57 AM   #4
Lucky1
647
Drives: '08 128i Coupe SGM 6MT
Were they successful or did they get caught?
      03-20-2019, 11:59 AM   #5
KevinC
your average JAMF
KevinC's Avatar
3101
Drives: '21 M2 Comp, '19 Golf R
I could never own that car down here near the border! I drive through Border Patrol checkpoints all the time, and they usually have a drug-sniffing dog walking around cars as they creep through. That thing is probably forever tainted to a trained nose like that.
That sensor should be an easy (if not particularly cheap) fix.
'21 M2 Comp
'19 Golf R
      03-20-2019, 02:01 PM   #6
Huz-Z
Huz-Z's Avatar
851
Drives: Z4 3.0si, 328 XDrive, X5 35i
As KevinC said, that should be a straightforward fix if you are handy, assuming that the sensor is the culprit.
How is the car otherwise? I can't imagine that its previous owners were very kind to it. But maybe its finally found a home where it will get some much needed and deserved TLC.
Huz-Z
BMW Z4 3.0si Roadster. Montego Blue Metallic. Premium and Sport Package.
      03-20-2019, 07:06 PM   #7
musmand
I've replaced the tires, struts, tie-rods, sway bars and rear shocks. The top doesn't work. Replaced the stereo. Need to replace half the speakers. Still need to fix the top. Can't get trunk to open. Need to replace the front bumper. Might need to replace some hoses or radiator, I think I have a coolant leak. I filled it when I first got it a month ago and had to refill this week. Engine is running great. But I only paid $2,000. And it only has 120,000 miles.
      03-20-2019, 07:45 PM   #8
StickMon
StickMon's Avatar
636
Drives: 2006 MR
Sounds like a fun project. Keep us updated.
      03-20-2019, 08:07 PM   #9
Huz-Z
Huz-Z's Avatar
851
Ditto . Weird about the trunk. Did you try the key in the trunk lock or just the button up front? Yeah I know, dumb question. Geez I hope there’s nothing wonky going on there too from the previous owners.
      03-23-2019, 11:02 AM   #10
Clearancediver
90
Drives: 2004 Z4
Google getting into trunk via rear trunk vent. You need to take rear bumper cover off to do so.
I've read numerous posts on gaining access to trunk via this method
Sent from my smart phone...
      03-25-2019, 12:54 PM   #11
ShakyDog
ShakyDog's Avatar
183
Drives: 2007 Z4 3.0i Alpine White/Red
Hmm, might want to video the trunk opening. If it is full of drugs you at least would have video evidence of its discovery.
Steve
zpost
