03-18-2019, 05:16 PM | #1 |
17
Rep 107
Complete power off for cleaning interior?
I've searched quite a bit and either I'm searching the wrong stuff in the manual and online, or I'm overlooking this. Is there a way to completely power down the car in order to clean the interior without triggering every computerized function to kick on? I tried keeping the key in the house but regardless if you push this or that then boom it kicks on something which then reacts via the NAV, AC, etc for stuff getting pushed. I just picked up a 2016 750i this weekend and while the dealer had it cleaned well, there are some streaks and stuff on the interior screens and buttons that I want to get cleaned better.
03-19-2019, 11:53 AM | #2 | |
736
Rep 1,604
Drives: '23 760ix; '23 X3; '23 MB wgn
BMWCCA
Current: 23 760ix (Carbon Black/Tartufo) (after first one totaled) '23 X3; '23 MB E Wagon Prior: BMWs (3,5,7 & 8 series (2x!)) X3, MB (C, E, and S), Alfa GTV, MGB, Audi (A4, A6), Saab, Volvo, Toyota, Lincoln, Chrysler, Oldsmobile, Chevy, Rambler. |
03-19-2019, 11:57 AM | #3 |
17
Rep 107
03-19-2019, 04:53 PM | #4 | ||
17
Rep 107
Well nevermind. That didn't work. I wrapped the key fob in 3 layers of aluminum foil and put it inside a large fire safe (concrete and steel) inside the house. So apparently it doesn't have anything to do with the fob. |
03-26-2019, 03:18 PM | #5 |
57
Rep 47
Drives: 2023 BMW X4M Competition
Put the key far away. Touch and hold the radio volume to turn everything completely off
03-26-2019, 03:28 PM | #6 |
17
Rep 107
Tried that, including wrapping the key in foil and placing it in a fire safe. The radio button "shuts it down" but everything fires back up immediately once you push any buttons.
03-26-2019, 03:49 PM | #7 |
Barge driver
8658
Rep 12,425
Agreed I just ignore what's going on (everything kicking off on the dash) and continue to clean the dash and the buttons.
730d/Z4C
03-30-2019, 02:35 PM | #8 |
4470
Rep 7,506
Not sure if this will work or not because I only have a 2013 F series...so my iDrive may not work the same since its an older version...but I thought I read somewhere that the new iDrive can be shut down by moving the iDrive contoller knob forward (hold it there for a second or more) then turn it to make a selection that allows you to power down the car. Or it may have been to press the OPTION button and you get a screen that says shut car off.
Again, I have no verification of this because I have an older version of iDrive. It does work...please post back if you get a screen that allows you to select some type of powering down feature. EDIT. Found a video on YouTube & took 2 screen shots. The first is the driver pressing the OPTION button on a G chassis 5 series...which brings up a screen (2nd pic) that shows a selection to turn off the car:
2015 F06 650ix Gran Coupe`(Moonstone/Cohiba Brown)| 2014 F15 X5 50i MSport (Space Gray/Mocha)
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 03-30-2019 at 03:03 PM.. |
03-30-2019, 05:09 PM | #9 |
The Professor
162
Rep 826
I-drive menu: vehicle settings/doors and locks/ then select "turn car off when door open"
2010 BMW M6 2007 BMW 335i,2012 Audi S4-retired 2016 BMW 750i M-Sport 2015 BMW M235i-retired, 2022 M240i |
03-31-2019, 06:41 AM | #10 |
17
Rep 107
I've already got the option turned on to turn off the car when you open the door, and I've also done the iDrive menu that does the "car shutdown". The problem is that while these things, similar to the other ways of shutting down the car, turn the car "off", the electronics instantly fire up as soon as you push a button on the iDrive, steering wheel or HVAC. The best result I've found was to keep the key inside the house, get into the car and shut the door, then remote lock the car using my phone app. That disabled some of the buttons, but not everything. It works well enough for cleaning, it just seems like there should be some sort of option to make it be completely powered down aside from pulling a battery cable.
03-31-2019, 02:03 PM | #11 | |
4470
Rep 7,506
There's a delay of approx 20 seconds after locking the vehicle with the remote or manually locking the driver's door from the exterior lock cylinder...that allows the IMS (interior motion sensor) & Tilt sensors to set-up.
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. |
03-31-2019, 04:17 PM | #12 | |
17
Rep 107
04-22-2019, 12:55 AM | #13 |
Rep 2
This makes it difficult to take our car to the local car wash since those guys just wipe everything down quickly and not being careful with what they touch.
I just got my 2016 740 last month...it’s fully loaded with lots of buttons....buttons that love being pushed and moved! I love my new car, but dread the idea of taking it to a car wash! |
04-22-2019, 08:27 AM | #14 | |
Barge driver
8658
Rep 12,425
The metal buttons do show up every mark though so I tend to find I'm cleaning them more often.
730d/Z4C
