03-14-2019, 09:51 AM | #2 |
523
Rep 1,105
Not sure if you are referring to the crank bolt or do you mean ' to fix this screw-up'? Anyway there are multiple threads about this issue. As far as a I know to completely correct this you are going to need a Crank Bolt Capture (such as the one from VTT) in combination with a one piece crank hub (such as the one from Gintani).
KoonerzF8019.00 |
03-14-2019, 11:40 PM | #3 |
1935
Rep 1,532
Best chance for success it to take care of things before they go south. At a minimum, a Crank Bolt Capture, but ideally our Spline Lock Hub and a CBC together. If you already slipped your hub, you must replace all compromised parts.
03-30-2019, 01:50 AM | #5 |
2023 M5
177
Rep 191
Honestly its just something that happens unfortunately, I had a 2018 m4 had about 4-5k miles and my crank hub spun I wasn't speeding/racing or anything like that. Was cruising to a meet and my engine light went off took it to bmw and my crank hub was spun. Went to maximum psi and got the upgraded fix and I've been running 600whp since then 7k miles on the car and not a single issue
03-30-2019, 02:22 PM | #6 | |
267
Rep 436
03-30-2019, 03:01 PM | #7 |
2023 M5
177
Rep 191
My car was flagged one week prior to spinning my crank hub I was dumb and didn't flash back to stock when I brought my car so when my crank hub spun I did try to bring it ti BMW first and I talked to my SA and he tried to talk to the tech but they were not having it he didn't wanna give the okay to fix the car so I took it over too bimmerclinic in Jersey and got the upgraded part from maximum psi and the rest is history
Harpinc94.00 |
03-30-2019, 03:03 PM | #8 |
2023 M5
177
Rep 191
But I'm sure if you still have warranty and you got it upgraded they wouldn't say anything its not affecting your car in a negative way but at the same time every bmw is different so it wouldn't hurt too ask your sa. My sa let me come in with my dp and mid pipe no problem just that the car was flagged so couldn't really do much about that
03-30-2019, 03:04 PM | #9 |
121
Rep 250
yeah, that's what i did, install the crank bolt capture.
03-30-2019, 04:56 PM | #10 | |
267
Rep 436
Some you win and some we dont . |
03-30-2019, 04:58 PM | #11 |
267
Rep 436
Hi, didnt one of yours spin the hub on a N54 engine.
03-30-2019, 08:11 PM | #12 | |
1583
Rep 1,977
At first I thought a SCH was catastrophic but seems like people are getting this fixed with no further issues. |
03-30-2019, 08:14 PM | #13 | ||
2023 M5
177
Rep 191
03-30-2019, 08:20 PM | #14 | |
646
Rep 1,336
Seems very suspicious to me, and likely was an intentional attempt to damage VTT's reputation |
03-30-2019, 08:36 PM | #15 | |
1583
Rep 1,977
If you don’t mind, how much was it to fix it? If you don’t feel comfortable disclosing the amount, what was the range? From your SCH, it seems like it can randomly fail but more catastrophic engine failure ca happen should you be rompimg on the gas. |
03-30-2019, 09:41 PM | #16 | |
267
Rep 436
Just looking for the best on market , If i go down that route. |
03-31-2019, 01:59 AM | #17 |
IG @bmwF9xG80
3813
Rep 7,593
Drives: G80 M3, X4M, G07 X7m50
+1 at least do the Crank Bolt Capture
60-130mph 6.5s X4M #HCP
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce IG: @bmwF9XG80 |
Chris@VargasTurboTech1934.50 |
03-31-2019, 03:22 PM | #18 | |
2023 M5
177
Rep 191
03-31-2019, 05:50 PM | #19 | |
1583
Rep 1,977
I’m glad it was all sorted out though! |
03-31-2019, 07:52 PM | #20 | |
17639
Rep 10,720
Drives: M4 CS. Former G82, x2 F82, F80
melvyn267.00 |
