03-04-2019, 09:59 PM | #1 |
87
Rep 375
Question for all the 6MT owners, clutch inconsistency
Hello fellow F8X owners,
I purchased a used one owner 2016 F82 3 months ago and it had about 9k miles at the time. I've put 2.5k miles on the car in the past 3 months and I'm starting to notice this issue more and more in my everyday driving. I've read up on how the clutch engages weird and differently while the car is cold but I live in California where it's never really "Cold" and this happens even when the car is warmed up after 20-30min of driving. The issue is that the clutch catch point is a lot higher and feels a bit more stiff than normal during random times of my everyday drive and it causes these clunky and super jerky shifts where it feels like I'm dumping the clutch but the reality is it's just catching differently, but then it goes away immediately after I come to a dead stop and go back to 1st gear..... Currently not seeing anybody with this issue so just want to see if this is something serious or if it's normal? Maybe something similar? Please chime in guys, thanks a lot! |
03-05-2019, 09:39 AM | #2 |
5461
Rep 8,818
I do not experience this with my 18 M3.
The only thing i notice that requires me to change the way i let the clutch out slightly is between engine modes Comfort/Sport/Sport+. Never experienced it changing on me at random throughout the day.
03-05-2019, 10:08 AM | #4 |
1109
Rep 1,304
I'm not sure if this would explain your issue, but by any chance do you have your A/C turned on all the time? For me, when the A/C compressor is kicked in, there is a noticeable impact on engine load and RPM behavior when I'm in-between gears... I notice during upshifts that the engine RPMs definitely fall quicker as a result of the increased engine load. I therefore need to adjust my clutching to accommodate this change (i.e., be faster) in order to maintain smoothness. In theory, I suppose this could be perceived as a change in the "catch point" -- again, not sure if this describes your situation, but worth considering.
03-05-2019, 11:10 AM | #5 |
4999
Rep 4,139
i used to have a lot of clutch issues as such you describe...theres sooo many factors that can influence how the car chooses to behave...
I would say that trying to drive in between normal(DD) vs balls to the wall is diffcult. ie. you cant give a decent push in a gear; than slowly shift into the next, it just wont be smooth. rev- matching is evil....you'll tend to forget that you need to SLIP the clutch in vs waiting for rev-match to get there and then dumping clutch. Tips: shift early. before 3k rpms...1st and 2nd gear. forget about the rev-matching even tho its there....youll begin to rely on it too much and begin dumping clutch and then punching gas...when those two actions should be done together. just let certain days when its acting up, just be....people on the road are unpredictable; and if you live in a congested area...it can become very difficult to drive smoothly; like you speed up in second and get ready for 3rd; at that split second you gotta let off the throttle since the guy infront of you is doing dumbshit(texting, lost, whatever) My biggest pet peeve if people who tailgate me from 0-25mph. Like its impossible to shift as fast as a 10-speed automatic. And if I punch it in first and second; its racecar and Im not trying to do all that. Then i punch it in 3rd to get them off my ass...slow down to speed limit and they up my ass again. SMH. I've stopped tailgating and in general try to be the nicest person on the road; and its made my drives so much better. TL;DR...car is a trackrat at heart; but does function very well as a daily. My boys miata is straight butter rowing through the gears no matter what. really fun car; very underestimated. might want to drop it off at service...only to get...could not duplicate customer complaint...checked clutch..OK...updated idrive and computer so a mechanical system will shift better |
Lee808230.50 |
03-05-2019, 12:28 PM | #6 | |
87
Rep 375
Here's a better way to put it, I feel like the clutch is shifting without the rev match like it's in Sport+ when I'm in just normal Sport mode. Which tends to throw me off because I'm so use to rev matching being there in regular sport mode. Maybe a ECU malfunction that it forgets to rev match occasionally? |
03-05-2019, 12:29 PM | #7 | |
87
Rep 375
The rev match goes away for like 30 seconds then it comes back. Weird as hell |
03-05-2019, 12:31 PM | #8 |
87
Rep 375
I drive in Sport 80% of the time, and to summarize my point. I'm confused as to why my car's rev match goes away when going from 1-2. 2-3, 3-4, 4-5 etc but rev match is there on the downshifts. Also the second I come to a dead stop the car rev matches again when up shifting in sport.
03-05-2019, 12:35 PM | #9 | |
4999
Rep 4,139
As to your post above...the rev-matching will only hold so long..If you go into neutral(clutch in) before a turn its not going to hold it forever..you have to clutch out and clutch back in for the rev-match. so i typically either shift into second before the turn; or shift during the turn...after 3 years with this car...I honestly wish it never rev-matched because its made me a worse manual driver; further it disconnects the feel of the manual |
03-05-2019, 01:13 PM | #10 |
493
Rep 467
Drives: F80 AW 6MT
This doesn’t have as much to do with weather, as it does with operating temperatures.
Gabe - F80 AW Cloth 6MT - HRE 520 - OEM GTS Hood - CS lip/spoiler/diffuser - Status Gruppe SRS Coilovers - Nose Lift - Full Suspension - OEM Alcantara & Carbon interior - BM3 - IKON |
03-05-2019, 04:21 PM | #12 |
87
Rep 375
03-05-2019, 05:08 PM | #13 | |
#LSBM3
1420
Rep 1,973
Drives: 2016 BMW M3
Garage List 1984 BMW R65 [0.00]
2020 Ford F-150 XLT ... [0.00] 2003 Mitsubishi Evo ... [0.00] 2016 M3 Competition ... [10.00] |
Could be part of the problem. No complaints with my 6MT and I almost never have my foot on the clutch at a light. In neutral and only press the clutch when necessary.
/// M3 |
03-06-2019, 12:40 AM | #14 | |
87
Rep 375
I had just came back from a nice long local drive to run some errands. I find that the car did not rev match when in sport or efficient mode after driving for about 15-20 min, the car drove smooth for the first 15-20min and then after sitting in a drive thru (Maybe too much 1st gear?), I had switched the car into efficient mode which did not rev match anymore like it's suppose to and then samething in sport mode. Is this some type of soft ware issue? Or is this common after a long local drive? I'm actually starting to like the car without the rev match lol but I don't think this is normal. |
03-06-2019, 07:53 AM | #15 | |
#LSBM3
1420
Rep 1,973
Drives: 2016 BMW M3
/// M3 |
03-06-2019, 09:09 AM | #16 | |
346
Rep 366
Basically, you pick a gear, rev match adjusts RPMs IF needed. One of the rev match gurus will correct me if I'm wrong on that, but I'm pretty sure that's the gist of it. |
03-06-2019, 07:34 PM | #17 | |
1538
Rep 1,665
I don’t understand what you mean by the car rev matches when you’re at a dead stop. My car never automatically revs when I’m at a dead stop. Why? Because even in the lowest gear - 1st gear, from a dead stop you don’t need more than idle RPM to get the car rolling forward. It won’t rev match at dead stop because if it did, it would overrev as you engage 1st gear. It would overrev even more if you engaged a higher gear from a dead stop. |
03-06-2019, 07:47 PM | #18 |
/M Enthusiast
1600
Rep 1,619
At a dead stop when I release the clutch slowly the car controls the rpms and slowly accelerates the car.
I'm guessing that's what he means.
2019 M2 Comp, Alpine White, DCT, track car build, 1/2 cage, AP Racing Brakes & Nitron Coilovers, BM3 Stage 1 93 Oct.
2018 Porsche Cayman GTS, Night Blue Metalic, PDK, COBB tuned 93 Oct. 2004 Audi A4 Avant USP 6mt, RS4 clutch, built motor, Garrett GT3071r "Big Ass Turbo" Motoza Tune |
03-06-2019, 09:02 PM | #19 | |
87
Rep 375
03-07-2019, 12:40 AM | #20 | |
1538
Rep 1,665
I think your definition of a rev match may not be the same as mine. |
03-07-2019, 12:43 AM | #21 | |
1538
Rep 1,665
This is a basic technique people use to help others learn how to drive a manual transmission car. Don't touch accelerator, release clutch slowly and learn the engagement point of the clutch and try to get the car moving without blipping the throttle. No rev matching involved. |
03-07-2019, 12:55 AM | #22 | ||
147
Rep 244
