03-01-2019, 11:44 AM | #1 |
54
Rep 127
mixing race fuel and ethanol yourself
does any1 know if you mix 15% 91octane(ethanol free) with 85% pure e98 give you the same effect as 15% 98 octane(sunoco 260 gtx ) with 85% e98...the difference in octane is 1.5 .
15% is a small variant wether it 91 or 98 race gas mixed in with 85% ethanol. for maximum power or safety would the actual gas matter? |
03-01-2019, 11:55 AM | #2 | |
732
Rep 3,972
Here is a calculator I use. http://www.georgebelton.com/E85Calculator.php I run 2 gallons of VP 101 Octane (available from the pump here in Cali) with 2 gallons of E85 and it gets me to around 94 octane. E85 not only is great for its octane but its cooling properties, especially during summer months. If you aren't running a E85 tune I wouldn't run past 3 gallons in a tank as driveability issues may ensue. Dave
2020 Ford Mustang GT 6MT PP1 444rwhp
(Sold)2013 M3 Coupe-MR/BLK ZCP, 2011 M3 Coupe-MR/Blk 2007 Porsche 997C2S Speed Yellow/Blk sport seats 2004 BMW M3 Imola/Blk |
03-01-2019, 11:59 AM | #3 | ||
54
Rep 127
I got a e85 tune and want absolute performance even if I get a extra 5whp with using a high octane ethanol race gas in my 15% mixture |
03-01-2019, 12:30 PM | #5 |
54
Rep 127
03-01-2019, 06:01 PM | #6 |
233
Rep 1,673
The gtx mix will take another .5 degree of timing vs the 91 mix
THE 260GT makes more power than gtx and gt plus is even more than the gt. The car will adapt since it uses lambda and not a/f
Electronics Junkie, Engine Builder.
03-01-2019, 06:03 PM | #7 |
54
Rep 127
03-01-2019, 06:09 PM | #8 |
233
Rep 1,673
Would rely in the dyno for that though, just because you add more timing doesn't mean it will make more power. If peak cylinder pressure starts occurring faster than around 6 degrees atdc then it will beat the pistons and pin bores out of it.
The green e15 is really good too, it is way up there on o2 content so it runs better than what you would think.
03-02-2019, 01:07 AM | #9 | |
54
Rep 127
