02-20-2019, 08:55 PM | #1 |
74
Rep 145
DIY How to perform iSTEP UPDATES on NBTEVO (for enabling fullscreen CarPlay)
In order to enable fullscreen CarPlay via a 3rd party .BIN solution, you need to be running on [18-07-549 / NBTevo_O] or greater. For reference, my MY2018 F80 was running [iSTEP 17-07-507 / NBTEvo_L].
This PDF covers the entire process of how to update your NBTevo headunit. Fully documented with photos, screenshots and even a process log so you can follow step by step. This same guide can technically be used to update any module in your car --as always, do your research as your conditions may differ than mine. You assume all responsibility and risk. This guide is for educational purposes only. Please PM me if you have any feedback. Last edited by Deleted-User; 02-21-2019 at 12:04 AM.. |
02-24-2019, 08:44 PM | #2 |
Zymurgist
89
Rep 161
Thanks for sharing this. I'm looking at buying the full screen patch by itself, which requires CarPlay to be installed and activated. I was hoping that flashing HU_NBT2 wouldn't require reactivating CarPlay, but I guess that's not the case. Does CarPlay need to be reinstalled or reactivated after flashing and, if so, how do you do that (where would I get the .bin file needed)?
bordins145.00 |
02-24-2019, 09:04 PM | #3 | |
74
Rep 145
sdbmwcoding185.00 |
03-19-2019, 01:55 AM | #4 |
197
Rep 535
thanks for this, i will upgrade atm and nbthu2 isteps for full screen carplay this weekend. how long did the update take for you? any idea how to activate full screen carplay using fsc since the bin method wont work with the latest isteps?
03-19-2019, 12:00 PM | #5 | |
74
Rep 145
Also, hit up wibbles for fullscreen activation with the latest istep. |
05-03-2019, 10:22 AM | #6 | |
419
Rep 771
2020 BMW M340ix Dravit Grey
2018 BMW M3 Alpine White |
wilbur_the_goose353.00 |
06-10-2019, 05:17 PM | #10 | |
Zymurgist
89
Rep 161
The full-screen patch takes about 6 minutes and requires a strong internet signal. Assuming you'll be using your wired port for connecting to the car, you'll need a strong wireless internet connection. |
goosey209913.00 |
12-06-2019, 01:39 PM | #12 |
BimmerPost Supporting Vendor
1792
Rep 3,059
You need to have OABR(Ethernet to Gateway) connected.
Apple CarPlay Fullscreen for NBTEVO / ENTRYNAV2 / Anti-Dazzle F/G
CS FLASH G8X /GTS FLASH F8X / F8X Ultimate PACK / NBTEVO iDrive 6 FLASH iDrive Firmware Update + CarPlay Fullscreen -> Video Process Visit BIMMER-REMOTE.com - 10% OFF with BIMMERPOST_10 promocode info@bimmer-remote.com or PM |
05-20-2020, 01:37 PM | #14 |
172
Rep 435
just wanted to throw it out there, i have found that to not be overly critical. if you calculate everything and the hwel is black it will update without issue. I tested mine and found a handfull of istep shipment versions that all resulte din hwel being black. its possible there were no nbt evo updates through those various istep shipment builds, or perhaps it isnt that sensitive. Either way my evo came from a 2019 car, every istep shipment variation i tried from late 2018 had the same result.
08-12-2020, 07:37 AM | #15 |
-1
Rep 19
Hi all
I have esys 3.30.1 with v.4.24.31_PSdZData_Lite.rar This is what i use for Coding. Now i want to do the iStep for my NBTevo ID4 to ID6 and to install carplay. i saw that there are 2 versions of FULL PSdZData: For i.e: v.4.23.12_PSdZData_Full and v.63.3_PSdZData_Full What are the diferences between the 2? which one to use for the flashing from id4 to id6? do anyone have a guide to do this? Thanks! Last edited by flashxcode; 08-12-2020 at 07:42 AM.. |
08-12-2020, 10:24 AM | #16 |
1792
Rep 3,059
They are different versions.
After flash you would need to get Full FSC PACK to activate all features as well as proper coding. Thanks
09-05-2020, 10:18 AM | #18 | |
35
Rep 277
01-29-2021, 09:41 AM | #19 | |
Rep 55
01-30-2021, 04:10 AM | #21 | |
1792
Rep 3,059
Thanks
TopJimmy5479.00 |
01-31-2021, 08:55 PM | #22 |
Rep 20
Tags |
carplay, diy, e-sys, istep |
