KEEP M3POST ALIVE BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER LINK! |
02-14-2019, 09:47 PM | #1 |
98
Rep 615
Need Help re fitment please e46 m3 to e93 m3
Hi guys I found used work vs-xx rims that fit a e46 m3 very aggressively and im wondering if they fit a e93 m3.. the rears stock are 4mm different the fronts are way off but I can use spacers. The listing states specs are as follows
Fronts 20x9.5 +52 offset and rears 20x11 +19 He has a picture with the wheels on and the rims sit aggressive but flush on a e46 m3 I know the hub size is bigger but I can get hubcentric rings Any offset pros and fitment pros , your info is appreciated |
02-19-2019, 04:02 PM | #4 |
Save the manuals!
6020
Rep 6,751
The front is +52? You would need at least a 20mm spacer for good fitment on the E92, wrapped in a 245/35/19 or 265/30/19 or 275/30/19 tires.
The rear is aggressive but doable. A 285/30/19 tires should suffice.
'16 M3 | '23 718 Spyder Past: E92 M3, F87 M2, E39 M5, etc |
02-19-2019, 04:21 PM | #5 |
1341
Rep 1,881
not really ideal. to get nice fitment with 9.5 on the front i have run et15. et20 would still be good, but at et52 the front is going to be goofy. the rear is also pretty damn aggressive, probably will end up with a 275 stretched on the rear.
I am never able to post pictures on forums, all my pics are on IG @baye30 https://www.instagram.com/baye30/
Current Garage - [2011 E90 M3 ZCP] [2005 E53 X5 3.0 Sport] [1988 E30 325IS 24V] |
02-19-2019, 05:10 PM | #6 |
367
Rep 1,036
I would pass on those and find a set that fits the car better. Even with spacers, it won't be ideal as others have stated above. IMO 20s are too large for the E9x M3 anyways, so I would go with 19s max, personally.
Akrapovic | AngeliBright | APEX | Hankook | IND | JRZ RS1 | Macht Schnell | Mode Carbon | Vorsteiner |
02-19-2019, 06:46 PM | #7 |
2741
Rep 6,734
Drives: 'E46 M3 Race Car, '23 X7
Are you sure that the wheel isn't et25? et52 would likely rest on the strut even with a 10mm spacer.
Not sure what you mean about the hub size. E46 and e92 have same hub diameter. Only the e39 is unique.
'23 X7
'04 M3 - Fall Line Motorsports Built Race Car - S65 swap, Dry Sump, Bosch Stand-Alone ECU, Drenth Sequential Trans, MCS 3-Way, Flossmann Wide Body, Brembo Motorsports Brakes, Drexler LSD, BBS E88 Etc. INSTAGRAM - @Slicer_M |
